- #include <reg51.h>
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define noACK 0
- #define ACK 1
- #define STATUS_REG_W 0x06
- #define STATUS_REG_R 0x07
- #define MEASURE_TEMP 0x03
- #define MEASURE_HUMI 0x05
- #define RESET 0x1e
- enum {TEMP,HUMI};
- typedef union
- unsigned int i;
- float f;
- value;
- sbit lcdrs=P2^0;
- sbit lcdrw=P2^1;
- sbit lcden=P2^2;
- sbit SCK = P1^0;
- sbit DATA = P1^1;
- uchar table2[]="SHT11 ";
- uchar table3[]="";
- uchar table4[]="";
- uchar table5[]=".";
- uchar wendu[6];
- uchar shidu[6];
- void delay(int z)
- int x,y;
- for(x=z;x>0;x--)
- for(y=125;y>0;y--);
- void delay_50us(uint t)
- uint j;
- for(;t>0;t--)
- for(j=19;j>0;j--);
- void delay_50ms(uint t)
- uint j;
- for(;t>0;t--)
- for(j=6245;j>0;j--);
- void write_12864com(uchar com)
- lcdrs=0;
- lcdrw=0;
- delay_50us(1);
- P0=com;
- lcden=1;
- delay_50us(10);
- lcden=0;
- delay_50us(2);
- void write_dat(uchar dat)
- lcdrs=1;
- lcdrw=0;
- delay_50us(1);
- P0=dat;
- lcden=1;
- delay_50us(10);
- lcden=0;
- delay_50us(2);
- void init12864lcd(void)
- delay_50ms(2);
- write_12864com(0x30);
- delay_50us(4);
- delay_50us(4);
- write_12864com(0x0f);
- delay_50us(4);
- write_12864com(0x01);
- delay_50us(240);
- write_12864com(0x06);
- delay_50us(10);
- write_12864com(0x0c);
- delay_50us(10);
- void display1(void)
- uchar i;
- write_12864com(0x80);
- for(i=0;i<18;i++)
- write_dat(table2[i]);
- delay_50us(1);
- void display2(void)
- uchar i;
- write_12864com(0x90);
- for(i=0;i<18;i++)
- write_dat(table3[i]);
- delay_50us(1);
- void display3(void)
- uchar i;
- write_12864com(0x88);
- for(i=0;i<8;i++)
- write_dat(table4[i]);
- delay_50us(1);
- void displaywendu(void)
- uchar i;
- write_12864com(0x94);
- for(i=0;i<3;i++)
- write_dat(wendu[i]);
- delay_50us(1);
- for(i=0;i<1;i++)
- write_dat(table5[i]);
- delay_50us(1);
- for(i=4;i<5;i++)
- delay_50us(1);
- void displayshidu(void)
- uchar i;
- write_12864com(0x8C);
- for(i=0;i<3;i++)
- write_dat(shidu[i]);
- delay_50us(1);
- for(i=0;i<1;i++)
- delay_50us(1);
- for(i=4;i<5;i++)
- delay_50us(1);
- char s_write_byte(unsigned char value)
- unsigned char i,error=0;
- for (i=0x80;i>0;i>>=1)
- if (i&value) DATA=1;
- else DATA=0;
- SCK=1;
- _nop_();
- _nop_();
- _nop_();
- SCK=0;
- DATA=1;
- SCK=1;
- error=DATA;
- _nop_();
- _nop_();
- _nop_();
- SCK=0;
- DATA=1;
- return error;
- char s_read_byte(unsigned char ack)
- unsigned char i,val=0;
- DATA=1;
- for(i=0x80;i>0;i>>=1)
- SCK=1;
- if(DATA) val=(val|i);
- SCK=0;
- DATA=!ack;
- SCK=1;
- _nop_();
- _nop_();
- _nop_();
- SCK=0;
- _nop_();
- _nop_();
- _nop_();
- DATA=1;
- return val;
- void s_transstart(void)
- DATA=1; SCK=0;
- _nop_();
- SCK=1;
- _nop_();
- DATA=0;
- _nop_();
- SCK=0;
- _nop_();
- _nop_();
- _nop_();
- SCK=1;
- _nop_();
- DATA=1;
- _nop_();
- SCK=0;
- void s_connectionreset(void)
- unsigned char i;
- DATA=1; SCK=0;
- for(i=0;i<9;i++)
- SCK=1;
- SCK=0;
- s_transstart();
- char s_measure(unsigned char *p_value, unsigned char *p_checksum,unsigned char mode)
- unsigned error=0;
- unsigned int i;
- s_transstart();
- switch(mode)
- //case TEMP : error+=s_write_byte(MEASURE_TEMP); break;
- case HUMI : error+=s_write_byte(MEASURE_HUMI); break;
- default : break;
- for (i=0;i<65535;i++) if(DATA==0) break;
- if(DATA) error+=1;
- *(p_value) =s_read_byte(ACK);
- *(p_value+1)=s_read_byte(ACK);
- *p_checksum =s_read_byte(noACK);
- return error;
- void calc_sth10(float *p_humidity ,float *p_temperature)
- const float C1=-4.0;
- const float C2=+0.0405;
- const float C3=-0.0000028;
- const float T1=+0.01;
- const float T2=+0.00008;
- float rh=*p_humidity;
- float t=*p_temperature;
- float rh_lin;
- float rh_true;
- float t_C;
- t_C=t*0.01 - 40;
- rh_lin=C3*rh*rh + C2*rh + C1;
- rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;
- if(rh_true>100)rh_true=100;
- if(rh_true<0.1)rh_true=0.1;
- *p_temperature=t_C;
- *p_humidity=rh_true;
- void main(void)
- unsigned int temp,humi;
- value humi_val,temp_val;
- unsigned char error;
- unsigned char checksum;
- init12864lcd();
- display1();
- display2();
- display3();
- s_connectionreset();
- while(1)
- error=0;
- error+=s_measure((unsigned char*)&temp_val.i,&checksum,TEMP);
- error+=s_measure((unsigned char*)&humi_val.i,&checksum,HUMI);
- if(error!=0) s_connectionreset();
- else
- humi_val.f=(float)humi_val.i;
- temp_val.f=(float)temp_val.i;
- calc_sth10(&humi_val.f,&temp_val.f);
- temp=temp_val.f*10;
- humi=humi_val.f*10;
- wendu[0]=temp/1000+'0';
- wendu[1]=temp%1000/100+'0';
- wendu[2]=temp%100/10+'0';
- wendu[3]=0x2E;
- wendu[4]=temp%10+'0';
- displaywendu();
- shidu[0]=humi/1000+'0';
- shidu[1]=humi%1000/100+'0';
- shidu[2]=humi%100/10+'0';
- shidu[3]=0x2E;
- shidu[4]=humi%10+'0';
- displayshidu();
- delay(800);
复制代码 |
