查看: 4729|回复: 2
STM32103四轴步进减速控制
ID:123763 发表于 2016-10-14 20:08 | 显示全部楼层 |阅读模式
  * @file    Project/Template/main.c
  * @author  MCD Application Team
  * @version V3.0.0
  * @date    04/06/2009
  * @brief   Main program body
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2009 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "misc.h"
#include "stm32f10x_conf.h"
#include "stdio.h"
#include "stdlib.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define SYSCLK_FREQ_HSE
#define TIMx_PRE_EMPTION_PRIORITY 1
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
#define  CONTROL_PORT    GPIOE
#define  AXIS_PULSE_1    GPIO_Pin_0
#define  AXIS_PULSE_2    GPIO_Pin_2
#define  AXIS_PULSE_3    GPIO_Pin_4
#define  AXIS_PULSE_4    GPIO_Pin_6
#define  AXIS_DIR_1    GPIO_Pin_1
#define  AXIS_DIR_2    GPIO_Pin_3
#define  AXIS_DIR_3    GPIO_Pin_5
#define  AXIS_DIR_4    GPIO_Pin_7
#define  AXIS_LMTPOS_1    GPIO_Pin_8
#define  AXIS_LMTNEG_1    GPIO_Pin_9
#define  AXIS_LMTPOS_2    GPIO_Pin_10
#define  AXIS_LMTNEG_2    GPIO_Pin_11
#define  AXIS_LMTPOS_3    GPIO_Pin_12
#define  AXIS_LMTNEG_3    GPIO_Pin_13
#define  AXIS_LMTPOS_4    GPIO_Pin_14
#define  AXIS_LMTNEG_4    GPIO_Pin_15
#define  AXIS_HOME_1    GPIO_Pin_0
#define  AXIS_HOME_2    GPIO_Pin_1
#define  AXIS_HOME_3    GPIO_Pin_2
#define  AXIS_HOME_4    GPIO_Pin_3
#define POSITIVE        1
#define NEGATIVE        -1
#define CW  0
#define CCW 1
typedef struct {
  //! What part of the speed ramp we are in.
  u8 run_state ;
  //! Direction stepper motor should move.
  u8 dir ;
  //! Peroid of next timer delay. At start this value set the accelration rate.
  s32 step_delay;
  //! What step_pos to start decelaration
  u32 decel_start;
  //! Sets deceleration rate.
  s32 decel_val;
  //! Minimum time delay (max speed)
  s32 min_delay;
  //! Counter used when accelerateing/decelerateing to calculate step_delay.
  s32 accel_count;
} speedRampData;
GPIO_InitTypeDef GPIO_InitStructure;
#define T1_FREQ 1000000
#define SPR 1600
// Maths constants. To simplify maths when calculating in AxisMoveRel().
#define ALPHA (2*3.14159/SPR)                    // 2*pi/spr
#define A_T_x100 ((long)(ALPHA*T1_FREQ*100))     // (ALPHA / T1_FREQ)*100
#define T1_FREQ_148 ((int)((T1_FREQ*0.676)/100)) // divided by 100 and scaled by 0.676
#define A_SQ (long)(ALPHA*2*100000*100000)         //
#define A_x20000 (int)(ALPHA*20000)              // ALPHA*20000
// Speed ramp states
#define STOP  0
#define ACCEL 1
#define DECEL 2
#define RUN   3
s32 steps[4]={150000, 150000, 150000, 150000};//运动距离
u32 accel[4]={10000,10000, 10000, 10000};//加速度
u32 decel[4]={10000, 10000, 10000, 10000};//减速度
u32 speed[4]={10000, 10000, 10000, 10000};//速度
s32 stpdecel[4]={65000, 65000, 65000, 65000};//急停减速度
u8 addr485=0;
u8 LmtSnsPos[4]={1,1,1,1};//正限位电平
u8 LmtSnsNeg[4]={1,1,1,1};//负限位电平
u8 HomeSns[4]={1,1,1,1};//回零电平
s32 position[4]={0,0,0,0};//当前位置
s32 HomePos[4]={0,0,0,0};//
s32 SoftLmtPos[4]={0x7fffffff, 0x7fffffff, 0x7fffffff, 0x7fffffff};
s32 SoftLmtNeg[4]={0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff};
u16 AxisPulsePin[4]={AXIS_PULSE_1, AXIS_PULSE_2, AXIS_PULSE_3, AXIS_PULSE_4};
u16 AxisDirPin[4]={AXIS_DIR_1, AXIS_DIR_2, AXIS_DIR_3, AXIS_DIR_4};
u16 LmtPosPin[4]={AXIS_LMTPOS_1, AXIS_LMTPOS_2, AXIS_LMTPOS_3, AXIS_LMTPOS_4};
u16 LmtNegPin[4]={AXIS_LMTNEG_1, AXIS_LMTNEG_2, AXIS_LMTNEG_3, AXIS_LMTNEG_4};
u16 HomePin[4]={AXIS_HOME_1, AXIS_HOME_2, AXIS_HOME_3, AXIS_HOME_4};
u16 AddrPin[4]={GPIO_Pin_7, GPIO_Pin_6, GPIO_Pin_15, GPIO_Pin_14};
GPIO_TypeDef *AxisLmtPosPort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *AxisLmtNegPort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *AxisPulsePort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *AxisDirPort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *HomePort[4]={GPIOC, GPIOC, GPIOC, GPIOC};
GPIO_TypeDef *AddrPort[4]={GPIOC, GPIOC, GPIOB, GPIOB};
uint32_t AxisEXTILine[4]={EXTI_Line0, EXTI_Line1, EXTI_Line2, EXTI_Line3};
uint8_t AxisEXTIPinSource[4]={GPIO_PinSource0, GPIO_PinSource1, GPIO_PinSource2, GPIO_PinSource3};
bool bLmtPos[4]={FALSE, FALSE, FALSE, FALSE};
bool bLmtNeg[4]={FALSE, FALSE, FALSE, FALSE};
bool bStopCmd[4]={FALSE, FALSE, FALSE, FALSE};
bool bEmgStopping[4]={FALSE, FALSE, FALSE, FALSE}; //是否碰限位急停
bool bEnableSoftLmt[4]={FALSE, FALSE, FALSE, FALSE};
bool bHomeOK[4]={FALSE, FALSE, FALSE, FALSE};
bool bZeroCapture[4]={FALSE, FALSE, FALSE, FALSE};
s32 ZeroDir[4]={POSITIVE, POSITIVE, POSITIVE, POSITIVE};          //回零方向
s32 ZeroOffset[4]={1000, 1000, 1000, 1000}; //零点偏移
u32 ZeroBackDistance[4]={6400, 6400, 6400, 6400}; //回零回退距离
u8 ZeroStep[4]={0, 0, 0, 0};
u32 HomeFastSpeed[4]={10000, 10000, 10000, 10000};//回零快搜速度
u32 HomeSlowSpeed[4]={2000, 2000, 2000, 2000};//回零慢搜速度
        speedRampData srd[4];
enum
        IDEL,
        FASTSEEK,
        FASTSEEKSTOP,
        FASTSEEKBACK,
        SLOWSEEK,
        SLOWSEEKSTOP,
        MOVETOZERO
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void NVIC_Configuration(void);
void Timer_Init(void);
void EXTILine_Config(void);
void GPIO_Configuration(void);
int fputc(int ch, FILE *f);
u8 MotionStatus[4]={0, 0, 0, 0};//是否在运动?0:停止,1:运动
bool bDataOK;
USART_InitTypeDef USART_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
uint8_t RxBuffer[12];
uint8_t RxCounter;
void AxisMoveRel(u32 axis, s32 step, u32 accel, u32 decel, u32 speed);
void AxisMoveAbs(u32 axis, s32 step, u32 accel, u32 decel, u32 speed);
u32 sqrt(u32 x);
void LimitDetect(u8 axis);
void USART_Configuration(void);
void AxisHome(u8 axis);
#define EnableHomeCapture1        EXTI->IMR |= GPIO_Pin_0
#define DisableHomeCapture1        EXTI->IMR &=~GPIO_Pin_0
#define EnableHomeCapture2        EXTI->IMR |= GPIO_Pin_1
#define DisableHomeCapture2        EXTI->IMR &=~GPIO_Pin_1
#define EnableHomeCapture3        EXTI->IMR |= GPIO_Pin_2
#define DisableHomeCapture3        EXTI->IMR &=~GPIO_Pin_2
#define EnableHomeCapture4        EXTI->IMR |= GPIO_Pin_3
#define DisableHomeCapture4        EXTI->IMR &=~GPIO_Pin_3
void EnableHomeCapture(u8 axis) {EXTI->IMR |=HomePin[axis];}
void DisableHomeCapture(u8 axis)        {EXTI->IMR &=~HomePin[axis];}
  * @brief  Main program.
  * @param  None
  * @retval : None
int main(void)
  /* Setup STM32 system (clock, PLL and Flash configuration) */
        u8 axis=0;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA  | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO, ENABLE);
        for(axis=0; axis<4; axis++)
                GPIO_InitStructure.GPIO_Pin = AxisPulsePin[axis];
                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
                GPIO_Init(AxisPulsePort[axis], &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin = AxisDirPin[axis];
                GPIO_Init(AxisDirPort[axis], &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin=LmtPosPin[axis];
                GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
                GPIO_Init(AxisLmtPosPort[axis], &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin=LmtNegPin[axis];
                GPIO_Init(AxisLmtNegPort[axis], &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin=HomePin[axis];
                GPIO_Init(HomePort[axis], &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin=AddrPin[axis];
                GPIO_Init(AddrPort[axis], &GPIO_InitStructure);
        Timer_Init();
        EXTILine_Config();
  NVIC_Configuration();
//    AxisMoveRel(1, 550000, 25000, 25000, 50000);
//    AxisMoveRel(2, 550000, 32000, 32000, 40000);
//    AxisMoveRel(3, 550000, 20000, 20000, 60000);
//          AxisMoveRel(4, 550000, 30000, 30000, 45000);
  while (1)
                LimitDetect(1);
                LimitDetect(2);
                LimitDetect(3);
                LimitDetect(4);
                AxisHome(1);
                AxisHome(2);
                AxisHome(3);
                AxisHome(4);
  USART_SendData(USART1, (uint8_t) ch); /*发送一个字符函数*/
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)/*等待发送完成*/
  return ch;
//   GPIO_InitTypeDef GPIO_InitStructure;
//   /* GPIOA Configuration:TIM2 Channel1, 2, 3 and 4 as alternate function push-pull */
//   GPIO_InitStructure.GPIO_Pin =AXIS_PULSE_1 | AXIS_PULSE_2 |AXIS_PULSE_3 | AXIS_PULSE_4 | AXIS_DIR_1 | AXIS_DIR_2 | AXIS_DIR_3 | AXIS_DIR_4;
//   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
//   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
//   GPIO_Init(CONTROL_PORT, &GPIO_InitStructure);
//    GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
//    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
//    GPIO_Init(MACHINPUT_PORT, &GPIO_InitStructure);
void Timer_Init(void)//定时器配置
        uint16_t PrescalerValue;
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);
  TIM_TimeBaseStructure.TIM_Period =65535;
  TIM_TimeBaseStructure.TIM_Prescaler =0;    //1 MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure);
        PrescalerValue=(uint16_t) ((SystemFrequency_SysClk / 2) / 1000000) - 1;
        TIM_PrescalerConfig(TIM2, PrescalerValue, TIM_PSCReloadMode_Immediate);
        TIM_PrescalerConfig(TIM3, PrescalerValue, TIM_PSCReloadMode_Immediate);
        TIM_PrescalerConfig(TIM4, PrescalerValue, TIM_PSCReloadMode_Immediate);
        TIM_PrescalerConfig(TIM5, PrescalerValue, TIM_PSCReloadMode_Immediate);
  /* Output Compare Active Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Active;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 10;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM2, &TIM_OCInitStructure);
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1Init(TIM4, &TIM_OCInitStructure);
  TIM_OC1Init(TIM5, &TIM_OCInitStructure);
        TIM_ClearFlag(TIM2, TIM_FLAG_Update);
        TIM_ClearFlag(TIM3, TIM_FLAG_Update);
        TIM_ClearFlag(TIM4, TIM_FLAG_Update);
        TIM_ClearFlag(TIM5, TIM_FLAG_Update);
  /* TIM IT enable */
  TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
  TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
  TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
  TIM_ITConfig(TIM5, TIM_IT_Update, ENABLE);
void NVIC_Configuration(void)//中断向量配置
          NVIC_InitTypeDef NVIC_InitStructure;
           NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
           //设置向量表的位置和偏移
        #ifdef  VECT_TAB_RAM
                /* Set the Vector Table base location at 0x20000000 */
                NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);                 //向量表位于RAM
        #else  /* VECT_TAB_FLASH  */
                /* Set the Vector Table base location at 0x08000000 */
                NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);   //向量表位于FLASH
        #endif
          /* Enable the TIM2 Interrupt */
          NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
//          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
          NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
          NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn;
        NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
     /* Enable the USART1 Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
//          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
          NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;                        //使能按键所在的外部中断通道
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;        //先占优先级4位,共16级
//        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;                                        //先占优先级0位,从优先级4位
        NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
void EXTILine_Config(void)//外部中断配置
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, AxisEXTIPinSource[0]);
        EXTI_InitStructure.EXTI_Line = AxisEXTILine[0] | AxisEXTILine[1] | AxisEXTILine[2] | AxisEXTILine[3];
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
void LimitDetect(u8 axis)//限位开关检测,axis参数是轴号
                if(GPIO_ReadInputDataBit(AxisLmtPosPort[axis-1], LmtPosPin[axis-1]))
                        if(LmtSnsPos[axis-1]==0)
                                bLmtPos[axis-1]=FALSE;
                                bLmtPos[axis-1]=TRUE;
                if(GPIO_ReadInputDataBit(AxisLmtNegPort[axis-1], LmtNegPin[axis-1]))
                        if(LmtSnsNeg[axis-1]==0)
                                bLmtNeg[axis-1]=FALSE;
                                bLmtNeg[axis-1]=TRUE;
void AxisHome(u8 axis)//轴回零程序,axis参数是轴号
        axis--;
        switch(ZeroStep[axis])
                case IDEL:
                        break;
                case FASTSEEK:
                        if(!MotionStatus[axis])
                                        if(bZeroCapture[axis])
                                                ZeroStep[axis]=FASTSEEKBACK;
                                                bZeroCapture[axis]=FALSE;
                                                AxisMoveRel(axis+1, (position[axis]-HomePos[axis]+ZeroBackDistance[axis])*ZeroDir[axis]*-1, accel[axis], decel[axis], HomeFastSpeed[axis]);
                                                ZeroStep[axis]=IDEL;
                        break;
                case FASTSEEKSTOP:
                        break;
                case FASTSEEKBACK:
                                switch(axis)
                                        case 0:
                                                EnableHomeCapture1;
                                                break;
                                        case 1:
                                                EnableHomeCapture2;
                                                break;
                                        case 2:
                                                EnableHomeCapture3;
                                                break;
                                        case 3:
                                                EnableHomeCapture4;
                                                break;
                                AxisMoveRel(axis+1, 0x7FFFFFFF*ZeroDir[axis], accel[axis], decel[axis], HomeSlowSpeed[axis]);
                                ZeroStep[axis]=SLOWSEEK;
                        break;
                case SLOWSEEK:
                                        ZeroStep[axis]=MOVETOZERO;
                                        AxisMoveRel(axis+1, (position[axis]-HomePos[axis]+ZeroOffset[axis])*ZeroDir[axis]*-1, accel[axis], decel[axis], HomeFastSpeed[axis]);
                        break;
                case SLOWSEEKSTOP:
                        break;
                case MOVETOZERO:
                                position[axis]=0;
                        break;
void AxisMoveAbs(u32 axis, s32 step, u32 accel, u32 decel, u32 speed)//绝对运动,axis参数是轴号,step是目标位置,accel是加速度,decel是减速度,speed是速度
  //! Number of steps before we hit max speed.
  u32 max_s_lim;
  //! Number of steps before we must start deceleration (if accel does not hit max speed).
  u32 accel_lim;
        float ftemp=0.0;
        step=step-position[axis-1];
   if(step <0)
                                        return;
                                        return;
      srd[axis-1].dir = CCW;
      GPIO_ResetBits(AxisDirPort[axis-1], AxisDirPin[axis-1]);
                        step =-step;
                                return;
                                return;
    srd[axis-1].dir = CW;
          GPIO_SetBits(AxisDirPort[axis-1], AxisDirPin[axis-1]);
  if(step == 1)
    // Move one step...
    srd[axis-1].accel_count = -1;
    // ...in DECEL state.
    srd[axis-1].run_state = DECEL;
    // Just a short delay so main() can act on 'running'.
    srd[axis-1].step_delay = 1000;
                switch(axis)
                        case 1:
                                 TIM2->CCR1=10;
                                 TIM2->ARR=10;
                                 break;
                        case 2:
                                 TIM3->CCR1=10;
                                 TIM3->ARR=10;
                                 break;
                        case 3:
                                 TIM4->CCR1=10;
                                 TIM4->ARR=10;
                                 break;
                        case 4:
                                 TIM5->CCR1=10;
                                 TIM5->ARR=10;
                                 break;
                MotionStatus[axis-1] = 1;
                switch(axis)
                        case 1:
                                 TIM_Cmd(TIM2, ENABLE);
                         break;
                        case 2:
                         TIM_Cmd(TIM3, ENABLE);
                         break;
                        case 3:
                                 TIM_Cmd(TIM4, ENABLE);
                         break;
                        case 4:
                                 TIM_Cmd(TIM5, ENABLE);
                         break;
  // Only move if number of steps to move is not zero.
  else if(step != 0)
    // Refer to documentation for detailed information about these calculations.
    // Set max speed limit, by calc min_delay to use in timer.
    // min_delay = (alpha / tt)/ w
    srd[axis-1].min_delay = T1_FREQ/speed/2;
    // Set accelration by calc the first (c0) step delay .
    // step_delay = 1/tt * sqrt(2*alpha/accel)
    // step_delay = ( tfreq*0.676/100 )*100 * sqrt( (2*alpha*10000000000) / (accel*100) )/10000
    srd[axis-1].step_delay = ((long)T1_FREQ*0.676* sqrt(2000000 / accel))/1000/2;
    // Find out after how many steps does the speed hit the max speed limit.
    // max_s_lim = speed^2 / (2*alpha*accel)
    max_s_lim = speed*speed/(2*accel);
    // If we hit max speed limit before 0,5 step it will round to 0.
    // But in practice we need to move atleast 1 step to get any speed at all.
    if(max_s_lim == 0){
      max_s_lim = 1;
    // Find out after how many steps we must start deceleration.
    // n1 = (n1+n2)decel / (accel + decel)
    if((accel+decel)>step)
//                        accel_lim = step*decel/(accel+decel);
                        ftemp=(float)decel/(float)(accel+decel);
                        accel_lim = (float)step*ftemp;
                        accel_lim = step/(accel+decel)*decel;
    // We must accelrate at least 1 step before we can start deceleration.
    if(accel_lim == 0){
      accel_lim = 1;
    // Use the limit we hit first to calc decel.
    if(accel_lim <= max_s_lim){
      srd[axis-1].decel_val = accel_lim - step;
    else{
      srd[axis-1].decel_val =-(s32)(max_s_lim*accel/decel);
    // We must decelrate at least 1 step to stop.
    if(srd[axis-1].decel_val == 0){
      srd[axis-1].decel_val = -1;
    // Find step to start decleration.
    srd[axis-1].decel_start = step + srd[axis-1].decel_val;
    // If the maximum speed is so low that we dont need to go via accelration state.
    if(srd[axis-1].step_delay <= srd[axis-1].min_delay)
      srd[axis-1].step_delay = srd[axis-1].min_delay;
      srd[axis-1].run_state = RUN;
    else{
      srd[axis-1].run_state = ACCEL;
    // Reset counter.
    srd[axis-1].accel_count = 0;
    //OCR1A = 10;
        switch(axis)
          case 1:
                   TIM2->CCR1=10;
                 TIM2->ARR=10;
                 break;
          case 2:
                 TIM3->CCR1=10;
                 TIM3->ARR=10;
                 break;
          case 3:
             TIM4->CCR1=10;
                 TIM4->ARR=10;
                 break;
          case 4:
             TIM5->CCR1=10;
                 TIM5->ARR=10;
                 break;
    // Set Timer/Counter to divide clock by 8
    //TCCR1B |= ((0<<CS12)|(1<<CS11)|(0<<CS10));
        switch(axis)
          case 1:
                 break;
          case 2:
                 break;
          case 3:
                 break;
          case 4:
                 break;
void AxisMoveRel(u32 axis, s32 step, u32 accel, u32 decel, u32 speed)//相对运动
  u32 max_s_lim;
  u32 accel_lim;
        float ftemp=0.0;
   if(step <0)
                                        return;
                                        return;
                        step =-step;
                                return;
                                return;
  if(step == 1)
    // Move one step...
                switch(axis)
                        case 1:
                                 TIM2->CCR1=10;
                                 TIM2->ARR=10;
                                 break;
                        case 2:
                                 TIM3->CCR1=10;
                                 TIM3->ARR=10;
                                 break;
                        case 3:
                                 TIM4->CCR1=10;
                                 TIM4->ARR=10;
                                 break;
                        case 4:
                                 TIM5->CCR1=10;
                                 TIM5->ARR=10;
                                 break;
                switch(axis)
                        case 1:
                         break;
                        case 2:
                         break;
                        case 3:
                         break;
                        case 4:
                         break;
  else if(step != 0)
    if(max_s_lim == 0){
      max_s_lim = 1;
    if(accel_lim == 0){
      accel_lim = 1;
    else{
    else{
    // Reset counter.
    //OCR1A = 10;
        switch(axis)
          case 1:
                   TIM2->CCR1=10;
                 TIM2->ARR=10;
                 break;
          case 2:
                 TIM3->CCR1=10;
                 TIM3->ARR=10;
                 break;
          case 3:
             TIM4->CCR1=10;
                 TIM4->ARR=10;
                 break;
          case 4:
             TIM5->CCR1=10;
                 TIM5->ARR=10;
                 break;
        switch(axis)
          case 1:
                 break;
          case 2:
                 break;
          case 3:
                 break;
          case 4:
                 break;
void TIM2_IRQHandler(void)//1轴定时器中断处理
  // Holds next delay period.
  u16 new_step_delay;
  // Remember the last step delay used when accelrating.
  static u16 last_accel_delay;
  // Counting steps when moving.
  static u32 step_count = 0;
  // Keep track of remainder from new_step-delay calculation to incrase accurancy
  static s32 rest = 0;
  static u8 i=0;
  if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
    /* Clear TIM2 Capture Compare1 interrupt pending bit*/
    TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
          TIM2->CCR1=srd[0].step_delay;
        TIM2->ARR=srd[0].step_delay;
// OCR1A = srd.step_delay;        //
  if(srd[0].run_state)
          if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_1)==1)
                   GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_1);
                        GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_1);
        //PORTD^=BIT(5);
  i++;
  if(i==2)
         i=0;
  switch(srd[0].run_state)
    case STOP:
      step_count = 0;
      rest = 0;
                        TIM_Cmd(TIM2, DISABLE);
      MotionStatus[0] = 0;
                        bEmgStopping[0]=FALSE;
      break;
    case ACCEL:
      //sm_driver_StepCounter(srd.dir);
      step_count++;
                        if(srd[0].dir==CW)
                                position[0]++;
//                                  if(bLmtPos[0])
//                                          srd[0].run_state = STOP;
//                                          break;
                                position[0]--;
//                                  if(bLmtNeg[0])
//                                          break;
      srd[0].accel_count++;
      new_step_delay = srd[0].step_delay - (((2 * (long)srd[0].step_delay) + rest)/(4 * srd[0].accel_count + 1));
      rest = ((2 * (long)srd[0].step_delay)+rest)%(4 * srd[0].accel_count + 1);
                        if(step_count >= srd[0].decel_start  || bStopCmd[0] || (bLmtPos[0] && srd[0].dir==CW) || (bLmtNeg[0] && srd[0].dir==CCW))
                                if(bStopCmd[0])
                                        bStopCmd[0]=FALSE;
                                        srd[0].accel_count = T1_FREQ/2/stpdecel[0]*T1_FREQ/srd[0].step_delay/srd[0].step_delay*-1;
                                else if((bLmtPos[0] && srd[0].dir==CW) || (bLmtNeg[0] && srd[0].dir==CCW))
                                        bEmgStopping[0]=TRUE;
                                        srd[0].accel_count = srd[0].decel_val;
        srd[0].run_state = DECEL;
      else if(new_step_delay <= srd[0].min_delay)
        last_accel_delay = new_step_delay;
        new_step_delay = srd[0].min_delay;
        rest = 0;
        srd[0].run_state = RUN;
      break;
    case RUN:
      step_count++;
                        if(srd[0].dir==CW)
                                position[0]++;
//                                 if(bLmtPos[0])
//                                         break;
                                position[0]--;
//                                 if(bLmtNeg[0])
//                                         break;
                                if(bStopCmd[0])
                                        bStopCmd[0]=FALSE;
        // Start decelration with same delay as accel ended with.
        new_step_delay = last_accel_delay;
      break;
    case DECEL:
      step_count++;
                        if(srd[0].dir==CW)
                                position[0]++;
//                                 if(bLmtPos[0])
//                                         break;
                                position[0]--;
//                                 if(bLmtNeg[0])
//                                         break;
       if(bStopCmd[0])
                                bStopCmd[0]=FALSE;
                        else if(!bEmgStopping[0] && ((bLmtPos[0] && srd[0].dir==CW) || (bLmtNeg[0] && srd[0].dir==CCW)))
                        if(srd[0].accel_count >= 0)
      break;
  srd[0].step_delay = new_step_delay;
void TIM3_IRQHandler(void)//2轴定时器中断处理
  u16 new_step_delay;
  static u8 i=0;
  if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
    TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
          TIM3->CCR1=srd[1].step_delay;
        TIM3->ARR=srd[1].step_delay;
  if(srd[1].run_state)
          if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_2)==1)
                   GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_2);
                        GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_2);
  i++;
  if(i==2)
         i=0;
  switch(srd[1].run_state)
    case STOP:
      step_count = 0;
      rest = 0;
                        TIM_Cmd(TIM3, DISABLE);
      MotionStatus[1] = 0;
                        bEmgStopping[1]=FALSE;
      break;
    case ACCEL:
      step_count++;
                        if(srd[1].dir==CW)
                                position[1]++;
//                                 if(bLmtPos[1])
//                                         srd[1].run_state = STOP;
//                                         break;
                                position[1]--;
//                                 if(bLmtNeg[1])
//                                         break;
      srd[1].accel_count++;
      new_step_delay = srd[1].step_delay - (((2 * (long)srd[1].step_delay) + rest)/(4 * srd[1].accel_count + 1));
      rest = ((2 * (long)srd[1].step_delay)+rest)%(4 * srd[1].accel_count + 1);
                        if(step_count >= srd[1].decel_start  || bStopCmd[1] || (bLmtPos[1] && srd[1].dir==CW) || (bLmtNeg[1] && srd[1].dir==CCW))
                                if(bStopCmd[1])
                                        bStopCmd[1]=FALSE;
                                        srd[1].accel_count = T1_FREQ/2/stpdecel[1]*T1_FREQ/srd[1].step_delay/srd[1].step_delay*-1;
                                else if((bLmtPos[1] && srd[1].dir==CW) || (bLmtNeg[1] && srd[1].dir==CCW))
                                        bEmgStopping[1]=TRUE;
                                        srd[1].accel_count = srd[1].decel_val;
        srd[1].run_state = DECEL;
      else if(new_step_delay <= srd[1].min_delay)
        new_step_delay = srd[1].min_delay;
        rest = 0;
        srd[1].run_state = RUN;
      break;
    case RUN:
      step_count++;
                        if(srd[1].dir==CW)
                                position[1]++;
//                         if(bLmtPos[1])
//                                 break;
                                position[1]--;
//                         if(bLmtNeg[1])
//                                 break;
      // Chech if we should start decelration.
                                if(bStopCmd[1])
                                        bStopCmd[1]=FALSE;
      break;
    case DECEL:
      step_count++;
                        if(srd[1].dir==CW)
                                position[1]++;
//                                 if(bLmtPos[1])
//                                         break;
                                position[1]--;
//                                 if(bLmtNeg[1])
//                                         break;
      if(bStopCmd[1])
                                bStopCmd[1]=FALSE;
                        else if(!bEmgStopping[1] && ((bLmtPos[1] && srd[1].dir==CW) || (bLmtNeg[1] && srd[1].dir==CCW)))
                        if(srd[1].accel_count >= 0)
      break;
  srd[1].step_delay = new_step_delay;
void TIM4_IRQHandler(void)//3轴定时器中断处理
  u16 new_step_delay;
  static u8 i=0;
  if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
    TIM_ClearITPendingBit(TIM4, TIM_IT_Update);
  TIM4->CCR1=srd[2].step_delay;
        TIM4->ARR=srd[2].step_delay;
  if(srd[2].run_state)
          if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_3)==1)
                   GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_3);
                        GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_3);
  i++;
if(i==2)
         i=0;
  switch(srd[2].run_state)
    case STOP:
      step_count = 0;
      rest = 0;
                        TIM_Cmd(TIM4, DISABLE);
      MotionStatus[2] = 0;
                        bEmgStopping[2]=FALSE;
      break;
    case ACCEL:
      step_count++;
                        if(srd[2].dir==CW)
                                position[2]++;
        //                         if(bLmtPos[2])
        //                                 srd[2].run_state = STOP;
        //                                 break;
                                position[2]--;
        //                         if(bLmtNeg[2])
        //                                 break;
                        srd[2].accel_count++;
                        new_step_delay = srd[2].step_delay - (((2 * (long)srd[2].step_delay) + rest)/(4 * srd[2].accel_count + 1));
                        rest = ((2 * (long)srd[2].step_delay)+rest)%(4 * srd[2].accel_count + 1);
                        if(step_count >= srd[2].decel_start  || bStopCmd[2] || (bLmtPos[2] && srd[2].dir==CW) || (bLmtNeg[2] && srd[2].dir==CCW))
                                if(bStopCmd[2])
                                        bStopCmd[2]=FALSE;
                                        srd[2].accel_count = T1_FREQ/2/stpdecel[2]*T1_FREQ/srd[2].step_delay/srd[2].step_delay*-1;
                                else if((bLmtPos[2] && srd[2].dir==CW) || (bLmtNeg[2] && srd[2].dir==CCW))
                                        bEmgStopping[2]=TRUE;
                                        srd[2].accel_count = srd[2].decel_val;
        srd[2].run_state = DECEL;
      else if(new_step_delay <= srd[2].min_delay)
        new_step_delay = srd[2].min_delay;
        rest = 0;
        srd[2].run_state = RUN;
      break;
    case RUN:
      step_count++;
                        if(srd[2].dir==CW)
                                position[2]++;
//                                 if(bLmtPos[2])
//                                         break;
                                position[2]--;
//                                 if(bLmtNeg[2])
//                                         break;
                                if(bStopCmd[2])
                                        bStopCmd[2]=FALSE;
      break;
    case DECEL:
      step_count++;
                        if(srd[2].dir==CW)
                                position[2]++;
//                                 if(bLmtPos[2])
//                                         break;
                                position[2]--;
//                                 if(bLmtNeg[2])
//                                         break;
      new_step_delay = srd[2].step_delay - (2*srd[2].step_delay+rest)/(4*srd[2].accel_count+1);
      rest = (2 * srd[2].step_delay+rest)%(4 * srd[2].accel_count + 1);
      if(bStopCmd[2])
                                bStopCmd[2]=FALSE;
                        else if(!bEmgStopping[2] && ((bLmtPos[2] && srd[2].dir==CW) || (bLmtNeg[2] && srd[2].dir==CCW)))
                        if(srd[2].accel_count >= 0)
      break;
                srd[2].step_delay = new_step_delay;
void TIM5_IRQHandler(void)//4轴定时器中断处理
  u16 new_step_delay;
  static u8 i=0;
  if (TIM_GetITStatus(TIM5, TIM_IT_Update) != RESET)
    TIM_ClearITPendingBit(TIM5, TIM_IT_Update);
          TIM5->CCR1=srd[3].step_delay;
                TIM5->ARR=srd[3].step_delay;
  if(srd[3].run_state)
          if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_4)==1)
                   GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_4);
                        GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_4);
        //PORTD^=BIT(5);
  i++;
  if(i==2)
{i=0;
  switch(srd[3].run_state)
    case STOP:
      step_count = 0;
      rest = 0;
                        TIM_Cmd(TIM5, DISABLE);
      MotionStatus[3] = 0;
                        bEmgStopping[3]=FALSE;
      break;
    case ACCEL:
      step_count++;
                        if(srd[3].dir==CW)
                                position[3]++;
//                                 if(bLmtPos[3])
//                                         srd[3].run_state = STOP;
//                                         break;
                                position[3]--;
//                                 if(bLmtNeg[3])
//                                         break;
      srd[3].accel_count++;
      new_step_delay = srd[3].step_delay - (((2 * (long)srd[3].step_delay) + rest)/(4 * srd[3].accel_count + 1));
      rest = ((2 * (long)srd[3].step_delay)+rest)%(4 * srd[3].accel_count + 1);
                        if(step_count >= srd[3].decel_start  || bStopCmd[3] || (bLmtPos[3] && srd[3].dir==CW) || (bLmtNeg[3] && srd[3].dir==CCW))
                                if(bStopCmd[3])
                                        bStopCmd[3]=FALSE;
                                        srd[3].accel_count = T1_FREQ/2/stpdecel[3]*T1_FREQ/srd[3].step_delay/srd[3].step_delay*-1;
                                else if((bLmtPos[3] && srd[3].dir==CW) || (bLmtNeg[3] && srd[3].dir==CCW))
                                        bEmgStopping[3]=TRUE;
                                        srd[3].accel_count = srd[3].decel_val;
        srd[3].run_state = DECEL;
      else if(new_step_delay <= srd[3].min_delay)
        new_step_delay = srd[3].min_delay;
        rest = 0;
        srd[3].run_state = RUN;
      break;
    case RUN:
      step_count++;
                        if(srd[3].dir==CW)
                                position[3]++;
//                                 if(bLmtPos[3])
//                                         break;
                                position[3]--;
//                                 if(bLmtNeg[3])
//                                         break;
                                if(bStopCmd[3])
                                        bStopCmd[3]=FALSE;
      break;
    case DECEL:
      step_count++;
                        if(srd[3].dir==CW)
                                position[3]++;
//                                 if(bLmtPos[3])
//                                         break;
                                position[3]--;
//                                 if(bLmtNeg[3])
//                                         break;
      if(bStopCmd[3])
                                bStopCmd[3]=FALSE;
                        else if(!bEmgStopping[3] && ((bLmtPos[3] && srd[3].dir==CW) || (bLmtNeg[3] && srd[3].dir==CCW)))
                        if(srd[3].accel_count >= 0)
      break;
  srd[3].step_delay = new_step_delay;
void EXTI0_IRQHandler(void)//1轴回零开关触发,记录触发时的位置值
  if(EXTI_GetITStatus(EXTI_Line0) != RESET)
    HomePos[0]=position[0];
                bZeroCapture[0]=TRUE;
                if(MotionStatus[0])
                        bStopCmd[0]=TRUE;
    EXTI_ClearITPendingBit(EXTI_Line0);
                DisableHomeCapture1;
void EXTI1_IRQHandler(void)//2轴回零开关触发,记录触发时的位置值
  if(EXTI_GetITStatus(EXTI_Line1) != RESET)
    HomePos[1]=position[1];
                bZeroCapture[1]=TRUE;
                if(MotionStatus[1])
                        bStopCmd[1]=TRUE;
    EXTI_ClearITPendingBit(EXTI_Line1);
                DisableHomeCapture2;
void EXTI2_IRQHandler(void)//3轴回零开关触发,记录触发时的位置值
  if(EXTI_GetITStatus(EXTI_Line2) != RESET)
    HomePos[2]=position[2];
                bZeroCapture[2]=TRUE;
                if(MotionStatus[2])
                        bStopCmd[2]=TRUE;
    EXTI_ClearITPendingBit(EXTI_Line2);
                DisableHomeCapture3;
void EXTI3_IRQHandler(void)//4轴回零开关触发,记录触发时的位置值
  if(EXTI_GetITStatus(EXTI_Line3) != RESET)
    HomePos[3]=position[3];
                bZeroCapture[3]=TRUE;
                if(MotionStatus[3])
                        bStopCmd[3]=TRUE;
    EXTI_ClearITPendingBit(EXTI_Line3);
                DisableHomeCapture4;
u32 sqrt(u32 x)//开方
  register u32 xr;  // result register
  register u32 q2;  // scan-bit register
  register u8 f;   // flag (one bit)
  xr = 0;                     // clear result
  q2 = 0x40000000L;           // higest possible result bit
  do
    if((xr + q2) <= x)
      x -= xr + q2;
      f = 1;                  // set flag
    else{
      f = 0;                  // clear flag
    xr >>= 1;
    if(f){
      xr += q2;               // test flag
  } while(q2 >>= 2);          // shift twice
  if(xr < x){
    return xr +1;             // add for rounding
  else{
    return xr;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
