前段日子自己发去打样了个板子,充分利用了现有的12864屏幕,编写了一些原创程序,为鼓励大家的学习热情,将原理图,及源程序,打包送上!欢迎研究。闲话不说,都在图里:
呵呵,它的主功能是个时钟,背光软件可调。
特意设计了两套不一样的时钟,互刷不影响时间。
我编的钢琴程序,按对应的按键,屏幕上会动态显示,而且有音调发出
TTL传输功能,将信息传至电脑。电脑端会显示如下:
呵呵,其实这只是个平台,软件可以任意发挥:
其实就是一块小板子而已。
不多说,发上源文件,原理图!多多支持啊!
祝大家制作成功,电路还是比较简单的!
- 程序名: MUSIC 电子琴程序
- 编写人: droomfly
- 编写时间:
- 硬件支持: STC12c5a60s2 外部12MHZ晶振 电源5V
- void INIT(void);
- #include <STC12C5A60S2.h>
- #include <intrins.h>
- sbit SPEAKER = P1^0;//扬声器,低使能
- sbit LED = P1 ^ 4; //液晶屏背光定义(PWM控制,不能更改)
- sbit SID = P3 ^ 3; //数据 //LCD接口定义
- sbit SCLK = P3 ^ 2; //时钟 //LCD接口定义
- //键盘引脚定义
- sbit KEY_1 = P0^0; //A
- sbit KEY_1_GND = P0^2; //地
- sbit KEY_2 = P0^5; //B
- sbit KEY_2_GND = P0^7; //地
- sbit KEY_3 = P2^7; //C
- sbit KEY_3_GND = P2^5; //地
- sbit KEY_4 = P2^2; //D
- sbit KEY_4_GND = P2^0; //地
- unsigned char MUSIC;
- unsigned char STH0,STL0;
- unsigned int code tab[]={ //音阶表
- 63628,63835,64021,64103,64260,64400,64524, //低音1-7
- 64580,64684,64777,64820,64898,64968,65030, //中音1-7
- 65058,65110,65157,65178,65217,65252,65283 //高音1-7
- 数组图片字模
- 宽度x高度=128x64 魔音开机图
- unsigned char code tab1[]={
- /*-- 调入了一幅图像:C:\Users\Administrator\Desktop\MUSIC\logo-music-0.bmp --*/
- /*-- 宽度x高度=128x64 --*/
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xC0,0x0F,0xFF,0xFC,0x00,0x7F,0xFF,0xE0,0x07,0xFF,0xFE,0x00,0x1F,0xFF,0xC0,0x03,
- 0xC0,0x00,0xFF,0xE0,0x00,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x00,0x07,0xFF,0x00,0x03,
- 0xC0,0x00,0xFF,0xE0,0x00,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x00,0x00,0x00,0x00,0x03,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0E,0xCC,0xD8,0x63,0xE0,0xD9,0xD9,0x9C,0xC3,0x80,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0A,0x44,0x6C,0x91,0x00,0x66,0x48,0x94,0x44,0x80,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0C,0x44,0x44,0xF1,0x00,0x44,0x48,0x98,0x44,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x02,0x44,0x44,0x81,0x00,0x44,0x48,0x84,0x44,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0A,0x44,0x44,0x91,0x00,0x44,0x48,0x94,0x44,0x80,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0E,0x7E,0x78,0x63,0x80,0xEE,0xEF,0xDC,0xE3,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 数组图片字模
- 宽度x高度=128x64 魔音按键1
- unsigned char code tab2[]={
- /*-- 调入了一幅图像:C:\Users\Administrator\Desktop\MUSIC\logo-music-1.bmp --*/
- 0xC0,0x03,0xFF,0xF8,0x00,0x7F,0xFF,0xE0,0x07,0xFF,0xFE,0x00,0x3F,0xFF,0xF0,0x03,
- 0xC0,0x00,0x00,0x00,0x00,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x00,0x07,0xFF,0x00,0x03,
- 数组图片字模
- 宽度x高度=128x64 魔音按键2
- unsigned char code tab3[]={
- /*-- 调入了一幅图像:C:\Users\Administrator\Desktop\MUSIC\logo-music-2.bmp --*/
- 0xC0,0x0F,0xFF,0xFC,0x00,0x3F,0xFF,0x80,0x07,0xFF,0xFE,0x00,0x3F,0xFF,0xF0,0x03,
- 0xC0,0x00,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x7F,0xF0,0x00,0x07,0xFF,0x00,0x03,
- 数组图片字模
- 宽度x高度=128x64 魔音按键3
- unsigned char code tab4[]={
- /*-- 调入了一幅图像:C:\Users\Administrator\Desktop\MUSIC\logo-music-3.bmp --*/
- 0xC0,0x0F,0xFF,0xFC,0x00,0x7F,0xFF,0xE0,0x01,0xFF,0xFC,0x00,0x3F,0xFF,0xF0,0x03,
- 0xC0,0x00,0xFF,0xE0,0x00,0x0F,0xFE,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0x00,0x03,
- 数组图片字模
- 宽度x高度=128x64 魔音按键4
- unsigned char code tab5[]={
- /*-- 调入了一幅图像:C:\Users\Administrator\Desktop\MUSIC\logo-music-4.bmp --*/
- 数组图片字模
- 宽度x高度=128x64 魔音按键归位
- unsigned char code tab6[]={
- /*-- 调入了一幅图像:C:\Users\Administrator\Desktop\MUSIC\logo-music1.bmp --*/
- 0xC0,0x0F,0xFF,0xFC,0x00,0x7F,0xFF,0xE0,0x07,0xFF,0xFE,0x00,0x3F,0xFF,0xF0,0x03,
- void delay1ms (unsigned int a){ // 1ms延时程序(12MHz 10倍于51单片机速度时)
- unsigned int i;
- while( --a != 0){
- for(i = 0; i < 600; i++);
- 函数名:LCD12864底层驱动程序(串行接口)
- 调 用:lcm_w_byte();
- 参 数:要发送的字节数据
- 返回值:无
- 结 果:发送一个字节给LCM
- 备 注:
- //发送一个字节(底层函数)
- void lcm_w_byte(unsigned char bbyte) {
- unsigned char i;
- for(i=0;i<8;i++){
- SID=bbyte&0x80; //取出最高位
- SCLK=1;
- SCLK=0;
- bbyte<<=1; //左移
- 函数名:写指令或数据函数
- 调 用:lcm_w_test(?,?);
- 参 数:(位,字节);位:0指令,1数据;
- 返回值:无
- 结 果:
- 备 注:
- void lcm_w_test(bit start, unsigned char ddata) {
- unsigned char start_data,Hdata,Ldata;
- if(start==0){
- start_data=0xf8; //0:写指令
- }else{
- start_data=0xfa; //1:写数据
- Hdata=ddata&0xf0; //取高四位
- Ldata=(ddata<<4)&0xf0; //取低四位
- lcm_w_byte(start_data); //发送起始信号
- delay1ms(1); //延时是必须的
- lcm_w_byte(Hdata); //发送高四位
- lcm_w_byte(Ldata); //发送低四位
- //清屏函数
- void lcm_clr(void){
- lcm_w_test(0,0x01);
- delay1ms(20); //启动等待,等LCM讲入工作状态
- //向LCM发送一个字符串,长度64字符之内。
- //应用:lcm_w_word("您好!");
- void lcm_w_word(unsigned char *str){
- while(*str != '\0'){
- lcm_w_test(1,*str++);
- } *str = 0;
- //全屏绘图函数 FT4增加函数
- //应用:定义tab[],,直接调用LCD_12864_P(tab);
- void LCD_12864_P(unsigned char *a) //显示图片函数 (a的长度一定要大于64*16)
- unsigned char i,j,k,temp;
- lcm_w_test(0,0x34);//扩充指令
- lcm_w_test(0,0x36);//绘图显示开
- for(i=0;i<2;i++)
- if(i==0) //画上半屏
- temp=0;
- else
- temp=8; //画下半屏
- for(j=0;j<32;j++)
- lcm_w_test(0,(0x80+j)); //设置垂直地址(以位为单位,对应的行号)
- lcm_w_test(0,(0x80+temp));//设置水平地址(以字节单位,对应的列号)指针可自增
- for(k=0;k<16;k++)
- lcm_w_test(1,*a++);
- lcm_w_test(0,0x30);//基本指令
- //初始化LCM
- void lcm_init(void) {
- delay1ms(200); //启动等待,等LCM讲入工作状态
- lcm_w_test(0,0x30); //8 位介面,基本指令集
- lcm_w_test(0,0x0c); //显示打开,光标关,反白关
- lcm_w_test(0,0x01); //清屏,将DDRAM的地址计数器归零
- void INIT(void){//初始化程序
- TMOD=0x11;
- ET0=1;
- ET1=1;
- EA=1;
- P3M0 = 0xFF;//强推
- P3M1 = 0x00;//高阻
- P1M0 = 0xF7;//强推
- P1M1 = 0x00;//高阻
- P1ASF= 0x00;
- P4SW = 0XFF;
- P4M1 = 0x00;//强推
- P4M0 = 0x60;//高阻
- KEY_1_GND = 0;
- KEY_2_GND = 0;
- KEY_3_GND = 0;
- KEY_4_GND = 0;
- SPEAKER = 1;
- LED = 0;
- void main(void){ //MUSIC值域0~20
- INIT(); //初始化
- lcm_init();//初始化液晶显示器
- lcm_clr();//清屏
- LCD_12864_P(tab1);
- delay1ms(1000);
- while(1){
- if(KEY_1 == 0){delay1ms(20);if(KEY_1 == 0){MUSIC = 15;LCD_12864_P(tab5);}} //高音B(37)
- if(KEY_2 == 0){delay1ms(20);if(KEY_2 == 0){MUSIC = 13;LCD_12864_P(tab4);}}
- if(KEY_3 == 0){delay1ms(20);if(KEY_3 == 0){MUSIC = 20;LCD_12864_P(tab3);}}
- if(KEY_4 == 0){delay1ms(20);if(KEY_4 == 0){MUSIC = 19;LCD_12864_P(tab2);}}
- if(MUSIC != 0xff){ //如果有音阶数值(非0XFF时)
- STH0=tab[MUSIC]/256; //将音阶的频率值装入定时器T0
- STL0=tab[MUSIC]%256;
- TR0=1; //启动定时器
- MUSIC = 0xff; //清除寄存器
- }else{ //否则
- SPEAKER = 1; //关扬声器
- TR0=0; //关定时器
- LCD_12864_P(tab6);
- void t0(void) interrupt 1 using 0{//定时器0产生音频
- TH0=STH0;
- TL0=STL0;
- SPEAKER=~SPEAKER; //取反频率产生音调
- * 杜洋工作室
复制代码 |
