查看: 2437|回复: 5
请教一下这个程序几处不懂的地方
ID:143848 发表于 2016-10-29 09:29 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是个热敏电阻3950的测温单片机里程序,不过有几个地方不太明白,还望请教。第一个code        uint VOL[]和code        uint Temper[]中的数据是怎么计算查表得到的。第二个问题         result=(uint)((res/2048.0-1.0)*500.0);
                 temp1=abs(result-VOL[0]);
                 for(i=1;i<150;i++)
                         temp2=abs(result-VOL[i]);
                        if(temp1>=temp2)
                                temp1=temp2;
                                flag=i;
                 }这一部分,我最不明白,还有那个公式是什么意思?
请看程序:#include <reg52.h>
#include <intrins.h>
#include <math.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
code        uint VOL[]={                343,        339,        339,        335,        332,        332,        328,        324,        320,        320,
                                                        316,        312,        312,        308,        304,        300,        300,        296,        292,        292,
                                                        289,        285,        285,        281,        277,        273,        273,        269,        265,        265,
                                                        261,        257,        257,        253,        250,        250,        246,        242,        242,        238,
                                                        234,        234,        230,        230,        226,        222,        222,        218,        218,        214,
                                                        210,        210,        207,        207,        203,        199,        199,        195,        195,        191,
                                                        191,        187,        187,        183,        179,        179,        175,        175,        171,        171,
                                                        167,        167,        164,        164,        160,        160,        160,        156,        156,        152,
                                                        152,        148,        148,        144,        144,        140,        140,        140,        136,        136,
                                                        132,        132,        132,        128,        128,        125,        125,        125,        121,        121,
                                                        121,        117,        113,        109,        109,        105,        101,        101,        97,                97,
                                                        93,                89,                89,                85,                85,                82,                82,                78,                78,                74,
                                                        74,                70,                70,                66,                66,                66,                62,                62,                58,                58,
                                                        58,                54,                54,                54,                50,                50,                50,                46,                46,                46,
                                                        42,                42,                42,                42,                39,                39,                39,                39,                35,                35};
code        uint Temper[]={                100,        150,        200,        250,        300,        350,        400,        450,        500,        550,
                                                        600,        650,        700,        750,        800,        850,        900,        950,        1000,        1050,
                                                        1100,        1150,        1200,        1250,        1300,        1350,        1400,        1450,        1500,        1550
                                                        1600,        1650,        1700,        1750,        1800,        1850,        1900,        1950,        2000,        2050,
                                                        2100,        2150,        2200,        2250,        2300,        2350,        2400,        2450,        2500,        2550,
                                                        2600,        2650,        2700,        2750,        2800,        2850,        2900,        2950,        3000,        3050,
                                                        3100,        3150,        3200,        3250,        3300,        3350,        3400,        3450,        3500,        3550,
                                                        3600,        3650,        3700,        3750,        3800,        3850,        3900,        3950,        4000,        4050,
                                                        4100,        4150,        4200,        4250,        4300,        4350,        4400,        4450,        4500,        4550,
                                                        4600,        4650,        4700,        4750,        4800,        4850,        4900,        4950,        5000,        5050,
                                                        5100,        5200,        5300,        5400,        5500,        5600,        5700,        5800,        5900,        6000,
                                                        6100,        6200,        6300,        6400,        6500,        6600,        6700,        6800,        6900,        7000,
                                                        7100,        7200,        7300,        7400,        7500,        7600,        7700,        7800,        7900,        8000,
                                                        8100,        8200,        8300,        8400,        8500,        8600,        8700,        8800,        8900,        9000,
                                                        9100,        9200,        9300,        9400,        9500,        9600,        9700,        9800,        9900,        10000};
sbit STS=P1^0;
sbit CE = P1^1;
sbit CS=P1^2;
sbit A0=P1^3;
sbit RC=P1^4;
sbit RS=P1^5 ;
sbit RW=P1^6 ;
sbit EN=P1^7 ;
void delay_ms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
uint AD1674_Read(void)
        uint temp;
        uchar temp1,temp2;
        CS=1;        //片选信号
        CE=0;        //初始化,关闭数据采集
        CS=0;
        A0=0;
        RC=0;
        CE=1;//CE=1,CS=0,RC=0,A0=0启动12位温度转换
        _nop_();
        while(STS==1);         //等待数据采集结束
        CE=0;         //芯片使能关闭
        RC=1;
        A0=0;
        CE=1;//CE=1,CS=0,RC=1,12/8=1,A0=0 允许高八位数据并行输出
        _nop_();
        temp1=P0; //读取转换结果的高八位
        CE=0;  //芯片使能关闭
        RC=1;
        A0=1;
        CE=1;//CE=1,CS=0,RC=1,12/8=0,A0=1 允许低四位数据 并行输出
        _nop_();
        temp2=P0;         //读取转换结果的第四位
        temp=((temp1<<4)|(temp2&0X0F));          //高位和低位合成实际温度,temp2为PO口的高四位
        return (temp);           //还回转换结果,右移四位是因为temp2为P0口的高四位
/*** 写数据***/
void w_dat(unsigned char dat)
        RS = 1;
        //EN = 0;
        P2 = dat;
        delay_ms(5);
        RW = 0;
        EN = 1;
        EN = 0;
/*** 写命令***/
void w_cmd(unsigned char cmd)
        RS = 0;
//        EN = 0;
        P2 = cmd;
        delay_ms(5);
        RW = 0;
        EN = 1;
        EN = 0;
/*** 发送字符串到LCD***/
void w_string(unsigned char addr_start, unsigned char *p)
        unsigned char *pp;
        pp = p;
        w_cmd(addr_start);
        while (*pp != '\0')
                w_dat(*pp++);
/*** 初始化1602****/
void Init_LCD1602(void)
        EN = 0;
        w_cmd(0x38);  // 16*2显示,5*7点阵,8位数据接口
        w_cmd(0x0C);  // 显示器开、光标开、光标允许闪烁
        w_cmd(0x06);  // 文字不动,光标自动右移
        w_cmd(0x01);  // 清屏
void process(uint date,uchar add)
        uchar A[7];
        A[0]=date/1000%10+'0';
        A[1]=date/100%10+'0';
        A[2]='.';
        A[3]=date/10%10+'0';
        A[4]=date%10+'0';
        A[5]='C';
        w_string(add,A);
        uchar i,flag=0;
        uint result,temp1,temp2;
        float        res;
        Init_LCD1602();
        w_string(0x80,"Temper:");
        while (1)
                 res=(float)(AD1674_Read());
                 for(i=1;i<150;i++)
                        if(temp1>=temp2)
                                temp1=temp2;
                                flag=i;
                 process(Temper[flag],0x80+7);
ID:79544 发表于 2016-10-29 11:36 | 只看该作者
abs(result-VOL[i]); 这个函数是调用库函数#include <math.h>进行计算值,表示温度所对应的AD值,这是我的理解
ID:61002 发表于 2016-10-29 12:44 | 只看该作者
腾飞的龙 发表于 2016-10-29 11:36
abs(result-VOL); 这个函数是调用库函数#include 进行计算值,表示温度所对应的AD值,这是我的理解
abs是取绝对值的
ID:61002 发表于 2016-10-29 12:49 | 只看该作者
result=(uint)((res/2048.0-1.0)*500.0); 这句话应该是根据你的硬件电路得到的公式,用来把热敏电阻3950线性化
那两个数组里一个表示的是温度,一个是电阻大小 是一一对应的,转换关系是每50度内温度和电阻阻值的关系是线性的
还有问题可以加我qq753388438
ID:143848 发表于 2016-10-29 20:07 | 只看该作者
g753388438 发表于 2016-10-29 12:49
result=(uint)((res/2048.0-1.0)*500.0); 这句话应该是根据你的硬件电路得到的公式,用来把热敏电阻3950线 ...
请问那两个定义的数组怎么来的呢?我是一个1K的普通电阻串上一个1K的热敏电阻然后A/D转换送入单片机最后显示出来,这是基本思路
ID:61002 发表于 2016-10-31 08:26 | 只看该作者
七颗星星 发表于 2016-10-29 20:07
请问那两个定义的数组怎么来的呢?我是一个1K的普通电阻串上一个1K的热敏电阻然后A/D转换送入单片机最后 ...
这个数组是根据分度表来的
