查看: 3276|回复: 0
8*8*8点阵动画程序
ID:145533 发表于 2016-11-1 16:24 | 显示全部楼层 |阅读模式
// 動畫Delay迴圈
void delay_ms(uint16_t x)
  uint8_t y, z;
  for ( ; x > 0 ; x--){
    for ( y = 0 ; y < 90 ; y++){
      for ( z = 0 ; z < 6 ; z++){
        asm volatile ("nop");
//Z axiz的下雨動畫
void shift (char axis, int direction)
        int i, x ,y;
        int ii, iii;
        int state;
        for (i = 0; i < 8; i++)
                if (direction == -1)
                        ii = i;
                } else
                        ii = (7-i);
                for (x = 0; x < 8; x++)
                        for (y = 0; y < 8; y++)
                                        iii = ii+1;
                                } else
                                        iii = ii-1;
                                if (axis == AXIS_Z)
                                        state = getvoxel(x,y,iii);
                                        altervoxel(x,y,ii,state);
                                if (axis == AXIS_Y)
                                        state = getvoxel(x,iii,y);
                                        altervoxel(x,ii,y,state);
                                if (axis == AXIS_X)
                                        state = getvoxel(iii,y,x);
                                        altervoxel(ii,y,x,state);
                i = 7;
        } else
                i = 0;
                        if (axis == AXIS_Z)
                                clrvoxel(x,y,i);
                        if (axis == AXIS_Y)
                                clrvoxel(x,i,y);
                        if (axis == AXIS_X)
                                clrvoxel(i,y,x);
[/pre]
