#include<reg51.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar num,dunum;
uchar code table_du[]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
display(uint);
delay(uchar);
EA=1;
ET0=1;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TR0=1;
if(num==20)
num=0;
if(dunum==100);
dunum=0;
dunum++;
display(dunum);
void time0() interrupt 1
{TH0=(65536-50000)/256;
num++;
display(uint dunum)
P0=table_du[dunum/10];
dula=1;
dula=0;
P0=0xfe;
wela=1;
wela=0;
delay(145);
P0=table_du[dunum%10];
dula=1;
dula=0;
P0=0xfd;
wela=1;
wela=0;
delay(145);
return(0);
delay(uchar x)
uchar a,b;
for(a=x;a>0;a--)
for(b=200;b>0;b--);
return(0);
