查看: 1519|回复: 0
呼吸灯单片机源码
ID:152303 发表于 2016-12-5 15:16 | 显示全部楼层 |阅读模式
#include <AT89X52.h>
#define MAX 0x50   //定时上限定义
#define MIN 0x00   //定时下限定义
#define TIMELINE 11         //时间分频常数
#define TRUE  1
#define FALSE 0             //标志位常数
unsigned int TimeCounter;
bit ArrowFlg = 0;         //方向标志位
unsigned char upCounter,downCounter;    //增加计数器和减少计数器
sbit LED=P2^0;
//T0的中断服务子函数
void T0Deal() interrupt 1 using 0
        TH0=0xf1;
        TL0=0xf1;
        TR0=1;
        TimeCounter++;  //定时计数器增加
        if(TimeCounter == TIMELINE)
                if((upCounter == MAX)&&(downCounter == MIN))  //计数方向标志位切换
      ArrowFlg = FALSE;
                if((upCounter == MIN)&&(downCounter == MAX))
      ArrowFlg= TRUE;
                if(ArrowFlg == 1)   //如果是增加计数
      upCounter++;
      downCounter--;
                else               //如果是减少计数
      upCounter--;
      downCounter++;
                TimeCounter=0;
//延时函数
void Delay(unsigned int i)
        unsigned int j;
        while(i--)
                for(j=0;j<32;j++);     //延时
        upCounter = MIN;
        downCounter = MAX;     //计数器初始化
        TMOD = 0x01;          //设置定时器工作方式
        TH0 = 0xF0;
        TL0 = 0xF0 ;          //T0初始化值
        EA = 1;
        ET0 = 1;              //开中断
        TR0 = 1;              //启动T0
                LED=0;            //输出变化的PWM波形
                Delay(downCounter);
                LED=1;
                Delay(upCounter);
