STC15F2K60S2UART程序:
1.UartMCUtoPC.zip
(27.14 KB, 下载次数: 21)
- /* --- STC MCU Limited ------------------------------------------------*/
- /* --- STC15F4K60S4 系列 定时器1用作串口1的波特率发生器举例------------*/
- /* --- Mobile: (86)13922805190 ----------------------------------------*/
- /* --- Fax: 86-0513-55012956,55012947,55012969 ------------------------*/
- /* --- Tel: 86-0513-55012928,55012929,55012966-------------------------*/
- /* 如果要在程序中使用此代码,请在程序中注明使用了STC的资料及程序 */
- /* 如果要在文章中应用此代码,请在文章中注明使用了STC的资料及程序 */
- //本示例在Keil开发环境下请选择Intel的8058芯片型号进行编译
- //若无特别说明,工作频率一般为11.0592MHz
- #include "reg51.h"
- #include "intrins.h"
- typedef unsigned char BYTE;
- typedef unsigned int WORD;
- #define FOSC 11059200L //系统频率
- #define BAUD 115200 //串口波特率
- #define NONE_PARITY 0 //无校验
- #define ODD_PARITY 1 //奇校验
- #define EVEN_PARITY 2 //偶校验
- #define MARK_PARITY 3 //标记校验
- #define SPACE_PARITY 4 //空白校验
- #define PARITYBIT NONE_PARITY //定义校验位
- sfr P0M1 = 0x93;
- sfr P0M0 = 0x94;
- sfr P1M1 = 0x91;
- sfr P1M0 = 0x92;
- sfr P2M1 = 0x95;
- sfr P2M0 = 0x96;
- sfr P3M1 = 0xb1;
- sfr P3M0 = 0xb2;
- sfr P4M1 = 0xb3;
- sfr P4M0 = 0xb4;
- sfr P5M1 = 0xC9;
- sfr P5M0 = 0xCA;
- sfr P6M1 = 0xCB;
- sfr P6M0 = 0xCC;
- sfr P7M1 = 0xE1;
- sfr P7M0 = 0xE2;
- sfr AUXR = 0x8e; //辅助寄存器
- sfr P_SW1 = 0xA2; //外设功能切换寄存器1
- #define S1_S0 0x40 //P_SW1.6
- #define S1_S1 0x80 //P_SW1.7
- sbit P22 = P2^2;
- bit busy;
- void SendData(BYTE dat);
- void SendString(char *s);
- void main()
- P0M0 = 0x00;
- P0M1 = 0x00;
- P1M0 = 0x00;
- P1M1 = 0x00;
- P2M0 = 0x00;
- P2M1 = 0x00;
- P3M0 = 0x00;
- P3M1 = 0x00;
- P4M0 = 0x00;
- P4M1 = 0x00;
- P5M0 = 0x00;
- P5M1 = 0x00;
- P6M0 = 0x00;
- P6M1 = 0x00;
- P7M0 = 0x00;
- P7M1 = 0x00;
- ACC = P_SW1;
- ACC &= ~(S1_S0 | S1_S1); //S1_S0=0 S1_S1=0
- P_SW1 = ACC; //(P3.0/RxD, P3.1/TxD)
- // ACC = P_SW1;
- // ACC &= ~(S1_S0 | S1_S1); //S1_S0=1 S1_S1=0
- // ACC |= S1_S0; //(P3.6/RxD_2, P3.7/TxD_2)
- // P_SW1 = ACC;
- // ACC = P_SW1;
- // ACC &= ~(S1_S0 | S1_S1); //S1_S0=0 S1_S1=1
- // ACC |= S1_S1; //(P1.6/RxD_3, P1.7/TxD_3)
- // P_SW1 = ACC;
- #if (PARITYBIT == NONE_PARITY)
- SCON = 0x50; //8位可变波特率
- #elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
- SCON = 0xda; //9位可变波特率,校验位初始为1
- #elif (PARITYBIT == SPACE_PARITY)
- SCON = 0xd2; //9位可变波特率,校验位初始为0
- #endif
- AUXR = 0x40; //定时器1为1T模式
- TMOD = 0x20; //定时器1为模式2(8位自动重载)
- TL1 = (256 - (FOSC/32/BAUD)); //设置波特率重装值
- TH1 = (256 - (FOSC/32/BAUD));
- TR1 = 1; //定时器1开始工作
- ES = 1; //使能串口中断
- EA = 1;
- SendString("Hello 51\n");
- while(1);
- UART 中断服务程序
- void Uart() interrupt 4 using 1
- if (RI)
- RI = 0; //清除RI位
- P0 = SBUF; //P0显示串口数据
- P22 = RB8; //P2.2显示校验位
- if (TI)
- TI = 0; //清除TI位
- busy = 0; //清忙标志
- 发送串口数据
- while (busy); //等待前面的数据发送完成
- ACC = dat; //获取校验位P (PSW.0)
- if (P) //根据P来设置校验位
- #if (PARITYBIT == ODD_PARITY)
- TB8 = 0; //设置校验位为0
- #elif (PARITYBIT == EVEN_PARITY)
- TB8 = 1; //设置校验位为1
- #endif
- else
- #endif
- busy = 1;
- SBUF = ACC; //写数据到UART数据寄存器
- 发送字符串
- while (*s) //检测字符串结束标志
- SendData(*s++); //发送当前字符
