源程序:
- #include<reg52.h>
- #define uchar unsigned char
- #define ulong unsigned long
- //uchar code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40}; //共阴极
- // 0 1 2 3 4 5 6 7 8 9 熄灭 -
- //uchar code loc[]={0xff,0xfe,0xfd,0xfb,0xf7};
- //uchar code ero[]={0x79,0x50,0x5c};
- uchar code num[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0x40}; //共阳极
- uchar code loc[]={~0x00,~0x10,~0x20,~0x40,~0x80,~0x08,~0x04,~0x02,~0x01};
- uchar code ero[]={~0x79,~0x77,~0x3f};
- ulong n=0,n1=0,n2=0; //赋初值
- uchar flag=0; //计算类型选择关键字
- void delay(int t);
- void display(int n);
- void error();
- main()
- while(1)
- uchar temp;
- //第一行检测
- P1=0xfe;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- temp=P1;
- temp=temp&0xfe;
- if(temp!=0xfe)
- temp=P1;
- switch(temp)
- case 0xee:n1=0;n2=0;n=0;flag=0;break; //清零
- case 0xde:n1=10*n1+0;n=n1;break; //0
- case 0xbe: if(flag==1)n=n2+n1; //=
- if(flag==2)n=n2-n1;
- if(flag==3)n=n2*n1;
- if(flag==4)n=n2/n1;
- n1=0;
- break;
- case 0x7e: // +
- n2=n1;n1=0;
- flag=1;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- //扫描第二行
- P1=0xfd;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- temp=P1;
- switch(temp)
- case 0xed:n1=10*n1+1;n=n1;break; //4
- case 0xdd:n1=10*n1+2;n=n1;break; //5
- case 0xbd:n1=10*n1+3;n=n1;break; //6
- case 0x7d: // -
- n2=n1;n1=0;
- flag=2;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- //扫描第三行
- P1=0xfb;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- temp=P1;
- switch(temp)
- case 0xeb:n1=10*n1+4;n=n1;break;
- case 0xdb:n1=10*n1+5;n=n1;break;
- case 0xbb:n1=10*n1+6;n=n1;break;
- case 0x7b: // *
- n2=n1;n1=0;
- flag=3;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- //扫描第四行
- P1=0xf7;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- temp=P1;
- switch(temp)
- case 0xe7:n1=10*n1+7;n=n1;break; //7
- case 0xd7:n1=10*n1+8;n=n1;break; //8
- case 0xb7:n1=10*n1+9;n=n1;break; //9
- case 0x77: // /
- n2=n1;n1=0;
- flag=4;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- display(n);
- //延时函数
- void delay(int t)
- int x,y;
- for(x=0;x<t;x++)
- for(y=0;y<t;y++);
- //数码管显示
- //溢出处理
- uchar g,s,b,q,a,c;
- int abs;
- if((n>999999)||(n<-99999))
- error();
- //正数
- if((n>=0)&&(n<=999999))
- g=n%10;
- s=n/10%10;
- b=n/100%10;
- q=n/1000%10;
- a=n/10000%10;
- c=n/100000%10;
- P0=num[g];
- delay(5);
- P2=loc[4];
- delay(2);
- P2=loc[0];
- delay(3);
- if(n>=10)
- P0=num[s];
- P2=loc[3];
- delay(2);
- P2=loc[0];
- delay(3);
- if(n>=100)
- P0=num[b];
- P2=loc[2];
- delay(2);
- P2=loc[0];
- delay(3);
- if(n>=1000)
- P0=num[q];
- P2=loc[1];
- delay(2);
- P2=loc[0];
- delay(3);
- if(n>=10000)
- P0=num[a];
- P2=loc[5];
- delay(2);
- P2=loc[0];
- delay(3);
- if(n>=100000)
- P0=num[c];
- P2=loc[6];
- delay(2);
- P2=loc[0];
- delay(3);
- //负数
- if((n<0)&&(n>=-999))
- abs=-n;
- g=abs%10;
- s=abs/10%10;
- b=abs/100%10;
- q=abs/1000%10;
- P0=num[g];
- P2=loc[4];
- delay(2);
- P2=loc[0];
- delay(2);
- if((abs/10%10>0)||(abs/100%10>0))
- P0=num[s];
- P2=loc[3];;
- delay(2);
- P2=loc[0];
- delay(2);
- if((abs/100%10>0))
- P0=num[b];
- P2=loc[2];
- delay(2);
- P2=loc[0];
- delay(2);
- if((abs/1000%10>0))
- P0=num[q];
- P2=loc[1];
- delay(2);
- P2=loc[0];
- delay(2);
- else
- P0=num[11];
- P2=loc[1];
- delay(2);
- P2=loc[0];
- delay(2);
- else
- P0=num[11];
- P2=loc[2];
- delay(2);
- P2=loc[0];
- delay(2);
- else
- P0=num[11];
- P2=loc[3];
- delay(2);
- P2=loc[0];
- delay(2);
- //溢出显示
- void error()
- P2=loc[5];
- P0=ero[0];
- delay(2);
- P2=loc[0];
- delay(3);
- P2=loc[1];
- P0=ero[1];
- delay(2);
- P2=loc[0];
- delay(3);
- P2=loc[2];
- P0=ero[1];
- delay(2);
- P2=loc[0];
- delay(3);
- P2=loc[3];
- P0=ero[2];
- delay(2);
- P2=loc[0];
- delay(3);
- P2=loc[4];
- P0=ero[1];
- delay(2);
- P2=loc[0];
- delay(3);
