喜欢的 可以看一下
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define led P0
- uchar tab[11]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
- uchar count, count0;
- void delay(uint x);
- void play();
- void main()
- TMOD = 0X01;//定时器0的工作方式为1;
- TH0 = (65536 - 40000) / 256;
- TL0 = (65536 - 40000) % 256;
- EA = 1;//开中断
- ET0 = 1;//开定时器0中断
- TR0 = 1;//启动定时器0
- led = 0x0c;
- while(1)
- play();
- void timer0() interrupt 1//定时器0中断服务程序
- count++;//中断次数累加
- if(count == 50)
- count = 0;//30次的50毫秒为1秒
- count0++;
- if((count0>=5)&&(count0<=8))
- P2=~tab[8-count0];
- else
- P2=0xff;
- if((count0>=13)&&(count0<=16))
- P3=~tab[16-count0];
- else
- P3=0xff;
- if(count0 == 16)
- count0 = 0;
- void play()
- if(count0 == 5) //5s后南北黄,东西红
- led = 0x0a;
- delay(100);
- led = 0x08;
- delay(100);
- led = 0x0a;
- delay(100);
- led = 0x08;
- delay(100);
- led = 0x0a;
- else if(count0 == 8) //8s后南北红,东西绿
- led = 0x21;
- else if(count0 == 13) //13s南北红,东西黄
- led = 0x11;
- delay(100);
- led = 0x01;
- delay(100);
- led = 0x11;
- delay(100);
- led = 0x01;
- delay(100);
- led = 0x11;
- else if(count0 == 0) //16s后南北绿,东西红
- led = 0x0c;
- uint a, b;
- for(a = x; a > 0; a--)
- for(b = 1000; b > 0; b--);
