1.时分秒的正常显示
2.可单独调整时钟的分十秒
3.闹钟功能
4,键功能说明
second--正常显示和闹钟状态时调整秒位
minute--正常显示和闹钟状态时调整分位
hour--正常显示和闹钟状态时调整分位
alarm--开启和关闭闹钟功能(变量alarm_is_ok,1为open,0为close)
stop-set-open-close
显示该单片机多功能闹钟的仿真原理图:
部分源码预览:
- #include "Key.h"
- #include "led.h"
- uchar timeSetBuff[8]={'0','0',LED_MODE_COUNT,'0','0',LED_MODE_COUNT,'0','0'};//时钟数据缓冲区
- uchar alarmSetBuff[8]={'0','0',LED_MODE_ALARM,'0','0',LED_MODE_ALARM,'0','0'};//闹钟时间数据缓冲区
- uchar timeDisMod=0x24; //00100100
- uchar secondTemp,minuteTemp,hourTemp;
- uchar secondAlarm,minuteAlarm,hourAlarm;
- uchar timer0Temp;
- uchar alarmKeyCount; //闹钟起停键计数
- bit alarm_is_ok; //闹钟起停状态
- bit time_is_ok; //时间是否到
- bit interface_mod; // 显示界面模式,0为主时间界面,1为设置界面
- * 函数名称:定时器0
- * 功 能:定时器0初始化
- * 入口参数:无
- * 出口参数:无
- void initTimer0(void) //定时10ms
- TMOD |= 0x01; //GATE=0,TR=1运行;C/T=1,counter,0,timer;01十六进制
- TH0 = 0xdc;
- TL0 = 0x00;
- TR0 = 1; //timer0 控制位,为1时启动timer0
- ET0 = 1; //timer0 中断使能
- * 函数名称:时钟比较
- * 功 能:比较时钟和闹钟的时间缓冲区,只比较时和分
- * 入口参数:无
- * 出口参数:无
- void timeCompare(void)
- if((minuteTemp == minuteAlarm) && (hourTemp == hourAlarm))
- time_is_ok = 1;
- alarm_is_ok = 0;
- interface_mod = 1;
- * 函数名称:主函数
- * 功 能:调用并执行各个子函数
- * 入口参数:无
- * 出口参数:无
- void main()
- uchar keyRead;
- init_led();
- init_key();
- initTimer0();
- timer0Temp = 0x00;
- secondTemp = 0x00;
- minuteTemp = 0x00;
- hourTemp = 0x00;
- secondAlarm = 0x00;
- minuteAlarm = 0x00;
- hourAlarm = 0x00;
- alarmKeyCount = 0x02;
- alarm_is_ok = 0; //默认状态停止
- time_is_ok = 0; //默认时间未到
- interface_mod = 0;
- sei();
- while(1)
- if(interface_mod == 1)
- ledSweepDisplay(alarmSetBuff,timeDisMod);
- else
- ledSweepDisplay(timeSetBuff,timeDisMod);
- if(alarm_is_ok == 1)
- timeCompare();
- keyRead = get_key_value();
- if(keyRead == KEY_ALARM)
- if(alarm_is_ok == 1 || time_is_ok == 1)
- alarm_is_ok = 0;
- time_is_ok = 0;
- alarmKeyCount = 0x00;
- else
- if(alarmKeyCount < 0x02)
- alarmKeyCount++;
- else
- if(alarmKeyCount == 0x01)
- if(alarmKeyCount == 0x02)
- alarm_is_ok = 1;
- if(keyRead == KEY_SECOND)
- { if(interface_mod == 1)
- if(secondAlarm < 59)
- secondAlarm++;
- else
- alarmSetBuff[S_L] = secondAlarm % 10 + '0';
- alarmSetBuff[S_H] = secondAlarm / 10 + '0';
- else
- if(secondTemp < 59)
- secondTemp += 1;
- else
- timeSetBuff[S_L] = secondTemp % 10 + '0';
- timeSetBuff[S_H] = secondTemp / 10 + '0';
- if(keyRead == KEY_MINUTE)
- if(minuteAlarm < 59)
- minuteAlarm++;
- else
- minuteAlarm=0x00;
- alarmSetBuff[M_L]=minuteAlarm%10+'0';
- alarmSetBuff[M_H]=minuteAlarm/10+'0';
- else
- if(minuteTemp < 59)
- minuteTemp += 1;
- else
- timeSetBuff[M_L] = minuteTemp % 10 + '0';
- timeSetBuff[M_H] = minuteTemp / 10 + '0';
- if(keyRead == KEY_HOUR)
- if(hourAlarm < 23)
- hourAlarm++;
- else
- hourAlarm = 0x00;
- alarmSetBuff[H_L] = hourAlarm % 10 + '0';
- alarmSetBuff[H_H] = hourAlarm / 10 + '0';
- else
- if(hourTemp < 23)
- hourTemp += 1;
- else
- hourTemp = 0x00;
- timeSetBuff[H_L] = hourTemp%10+'0';
- timeSetBuff[H_H] = hourTemp/10+'0';
- * 函数名称:定时器0中断函数
- * 功 能:定时器0溢出中断入口处,定时10ms
- * 入口参数:无
- * 出口参数:无
- void timer0_overflow(void) interrupt 1
- TH0 = 0xdc;
- TL0 = 0x00;
- if(time_is_ok == 1) //报警
- WARN_TRUMPET = ~WARN_TRUMPET;
- if(timer0Temp < 99) //判断1s是否到
- timer0Temp++;
- else //进中断100次
- if(secondTemp < 59) //判断1min是否到
- secondTemp++;
- else
- if(minuteTemp < 59) //判断1hour是否到
- minuteTemp++;
- else
- if(hourTemp < 23)
- hourTemp++;
- else
- hourTemp = 0x00;
- timeSetBuff[S_L] = secondTemp%10+'0';
- timeSetBuff[S_H] = secondTemp/10+'0';
- timeSetBuff[M_L] = minuteTemp%10+'0';
- timeSetBuff[M_H] = minuteTemp/10+'0';
- sei();
所有资料下载:
电子时钟系统.rar
(41.32 KB, 下载次数: 87)
