下面给出一个设计实例,在实例中通过定时器中断和DAC0832结合的方式来产生1~100KHZ的正弦波,幅度为0-Vcc/2。
首先按照下面的公式建立一个正弦波样本表,样表中将一个正弦波周期分成128个点,每个点按7位量化(127对应最高幅度Vcc/2):
f(x) = 64 + 63 * sin(2πx/180) x∈[0…127]
程序中使用16位定时器0产生取样中断,及定时器0的中断时间即为正弦波的采样周期。(T=1/(f*64))。本例中将正弦波分成64个采样点输出,及每隔两个点要从采样样本中取出一个数DAC0832的输入。
单片机源程序:
- #define SIN_GLOBAL 1
- #include "sin.h"
- //正弦波128个采样点寄存数组
- code uchar Sin[128] = {
- 64,67,70,73,76,79,82,85,88,91,94,96,99,102,104,106,
- 109,111,113,115,117,118,120,121,123,124,125,126,126,
- 127,127,127,127,127,127,127,126,126,125,124,123,121,
- 120,118,117,115,113,111,109,106,104,102,99,96,94,91,
- 88,85,82,79,76,73,70,67,64,60,57,54,51,48,45,42,39,
- 36,33,31,28,25,23,21,18,16,14,12,10,9,7,6,4,3,2,1,
- 1,0,0,0,0,0,0,0,1,1,2,3,4,6,7,9,10,12,14,16,18,21,23,
- 25,28,31,33,36,39,42,45,48,51,54,57,60
- *函数名称:Timer0_init(double timer0Delay)
- *函数功能:定时器0初始化
- *函数入口:timer0Delay,定时器定时时间,单位为毫秒
- *函数出口:无
- void Timer0_init(double timer0Delay)
- double time;
- double timeTemp;
- timer0TH0=0x00;
- timer0TL0=0x00;
- timeTemp=0x00;
- time=(double)(((double)12)/((F_CPU)/1000000));
- if(((double)255)*time>timer0Delay)
- timer0TH0=0x00;
- timer0TL0=(uchar)(256ul-timer0Delay/time);
- else
- while(timeTemp>timer0Delay)
- timeTemp+=time;
- timer0TH0++;
- timer0TH0--;
- timeTemp=timeTemp-((double)timer0TH0)*time;
- timer0TL0=(uchar)(256ul-timeTemp/time);
- TMOD|=0x01; //GATE=0,TR=1运行;C/T=1,counter,0,timer;01十六进制
- TH0=timer0TH0;
- TL0=timer0TL0;
- TR0=1; //timer0 控制位,为1时启动timer0
- ET0=1; //timer0 中断使能
- *函数名称:dac0832_init(void)
- *函数功能:D/A转换芯片dac0832初始化
- *函数入口:无
- *函数出口:无
- void dac0832_init(void)
- sinCodeCount=0;
- DAC0832=Sin[0];
- *函数名称:writeDAC0832(uchar dacDate)
- *函数功能:向D/A转换芯片dac0832数据口写数据
- *函数入口:dacDate
- *函数出口:无
- void writeDAC0832(uchar dacDate)
- DAC0832=dacDate;
下载:
正弦波发生器.rar
(20.14 KB, 下载次数: 182)
