一个自行车码表的设计,个人还不是特别的透彻,希望大家一起学习,带proteus仿真工程文件,和51单片机源代码。
码表计时实物图:
产品方案与论证:
程序流程:
状态切换:
码表的仿真原理图:
自行车码表源程序:
- #include<reg52.h>
- typedef unsigned char u8;
- typedef unsigned int u16;
- /********端口定义*********/
- #define DATA P0
- sbit seg_sel = P1^4;
- sbit bit_sel = P1^5;
- sbit start = P3^2;
- sbit store = P3^3;
- sbit diskey = P3^4;
- sbit reset = P3^5;
- sbit led = P1^0;
- /********变量定义*********/
- u16 tem_ms;
- u8 n_ten_ms,n_sec,n_min;
- u8 run_flag;//当run_flag为1,代表开始计数
- u8 temp_buf[5][3];
- u8 arr_pt;
- u8 code seg_tab[]={
- 0xc0,0xf9,0xa4,0xb0,
- 0x99,0x92,0x82,0xf8,
- 0x80,0x90,0x88,0x83,
- 0xc6,0xa1,0x86,0x8e
- u8 code bit_tab[]={
- 0x10,0x20,0x40,0x80,
- 0x01,0x02,0x04,0x08
- void delay(unsigned int y)
- unsigned int x,z;
- for(x=y; x>0; x--)
- for(z=110; z>0; z--);
- void display_led(u8 which_bit, u8 which_number)
- bit_sel = 1;//Q[7..0]=D[7..0]
- DATA = bit_tab[which_bit];
- bit_sel = 0;//BIT[7..0]=0x80
- seg_sel = 1;//Q[7..0]=D[7..0]
- DATA = seg_tab[which_number];
- seg_sel = 0;
- void display(u8 which_bit, u8 which_number)
- u8 x,y;
- x = which_number/10;//分离十位
- y = which_number%10;//分离个位
- if (which_bit == 1)
- display_led(1, x);
- delay(2);
- display_led(0, y);
- delay(2);
- if (which_bit == 2)
- display_led(4, x);
- delay(2);
- display_led(3, y);
- delay(2);
- if (which_bit == 3)
- display_led(7, x);
- delay(2);
- display_led(6, y);
- delay(2);
- void reflash (void)
- display(1, n_ten_ms);
- display(2, n_sec);
- display(3, n_min);
- void main (void)
- TMOD = 0x01;//设置定时/计数器T0
- TH0 = (65535-10000) / 256;
- TL0 = (65535-10000) % 256;
- EA = 1;//开放总中断
- ET0 = 1;//开放定时器0的溢出中断
- //TR0 = 1;
- while (1)
- if (start == 0)
- delay(5);
- if (start == 0)
- run_flag = ~run_flag;
- } while(!start);
- if (run_flag)
- TR0 = 1; //开始计数
- else if (!run_flag)
- TR0 = 0;
- if (diskey == 0)
- delay (5);
- if (diskey == 0)
- arr_pt --;
- n_ten_ms = temp_buf[arr_pt][0];
- n_sec = temp_buf[arr_pt][1];
- n_min = temp_buf[arr_pt][2];
- } while (!diskey);
- if (reset == 0)
- delay(5);
- if (reset == 0)
- n_ten_ms = 0;
- ………余下代码请下载附件…………
资料下载:
码表设计.zip
(2.54 MB, 下载次数: 46)
