查看: 5006|回复: 4
stc89C52单片机LCD显示时间设置问题
ID:183600 发表于 2017-3-26 19:07 | 显示全部楼层 |阅读模式
设计LCD显示日期时间,现在先设计到时间。但是写出来的程序在设置时间时每按设置键s6和按增加s7各只作接低电平的键s9功能一样出现光标,可以移动,但是不能作“+”功能,“-”功能S8无作用。
各位高手能否看下我写的程序(如下),哪里写错了!!!
#include<reg52.h>
#define UCHAR        unsigned char
#define UINT unsigned int
sbit lcdE=P3^4;
sbit lcdRs=P3^5;
sbit bitSeg=P2^6;
sbit bitPos=P2^7;
sbit keySet=P3^0;
sbit keyInc=P3^1;
sbit keyDec=P3^2;
sbit rd=P3^7;
UINT num,setNum,incNum,count,hh,mm,ss;
UCHAR code date[]="2017.03.24 SUN";
UCHAR code time[]="23:59:55";
UCHAR code timeAddr[]={0,1,3,4,6,7};
void delay(UINT t)
                UINT x,y;
                for(x=0;x<t;x++)
                        for(y=0;y<110;y++);
void write_com(UCHAR com)
                lcdRs=0; //set the instruction signal(low level)
                lcdE=0;        //set the port of lcdE low level
                P0=com;        //send valid data to the port of P0
                delay(5);        //delay time
                lcdE=1;        //the clock latch signal input,and write the data to LCD1602
void write_dat(UCHAR dat)
                lcdRs=1; //set the data signal(hight level)
                P0=dat;        //send valid data to the port of P0
void write_time(UCHAR addr,UCHAR m)
        UCHAR shi,ge;
        shi=m/10;
        ge=m%10;
        write_com(0x80+0x44+addr);
        write_dat(0x30+shi); //address reference character sheet
        write_dat(0x30+ge);        //address reference character sheet
//写到红色字段程序时,运行不如意。
void key_scan()
        rd=0;
        if(keySet==0)
                        delay(5);
                        if(keySet==0)
                                        while(!keySet);
                                        setNum++;
                                        if(setNum<7)
                                                        TR0=0;
                                                        write_com(0x0f);
                                                        switch(setNum)
        case 1:write_com(0x80+0x45);
        break;
        case 2:write_com(0x80+0x48);
        break;
        case 3:write_com(0x80+0x4b);
        break;
        case 4:write_com(0x0c);
        setNum=0;
        TR0=1;
        break;
        default:   ;break;
                                                        if(keyInc==0)
        delay(5);
        if(keyInc==0)
        while(!keyInc)
        switch(setNum)
        case 1:hh++;
        if(hh==60)
        hh=0;
        write_time(0,hh);
        break;
        case 2:mm++;
        if(mm==60)
        mm=0;
        write_time(3,mm);
        break;
        case 3:ss++;
        if(ss==60)
        ss=0;
        write_time(6,ss);
        break;
        default:   ;break;
                                                        if(keyDec==0)
        delay(5);
        if(keyDec==0)
        while(!keyDec)
        switch(setNum)
        case 1:hh--;
        if(hh<0)
        hh=0;
        write_time(0,hh);
        break;
        case 2:mm--;
        if(mm<0)
        mm=0;
        write_time(3,mm);
        break;
        case 3:ss--;
        if(ss<0)
        ss=0;
        write_time(6,ss);
        break;
        default:   ;break;
//set timer 50ms interrupt once
void timer() interrupt 1
        TH0=0x4c; //{2^16-50000/[12*(1/11.0592)]}/256;
        TL0=0x00;//{2^16-50000/[12*(1/11.0592)]}%256;
        count++;
        if(count==20) //count to 20 seconds
                        count=0;
                        ss++;
                        if(ss==60)
                                        ss=0;
                                        mm++;
                                        if(mm==60)
                                                        mm=0;
                                                        hh++;
                                                        if(hh==24)
        hh=0;
                                                        write_time(0,hh);
                                        write_time(3,mm);
                        write_time(6,ss);
void init()
                bitSeg=0;        //close the nixie tube
                bitPos=0;        //close the nixie tube
                TCON=0x31;        //set T/C interrupt                0011 0001
                IE=0x82;        //set interrupt control                1000 0010
                TMOD=0x01; //set timer mode                0000 0001
                TH0=0x4c;
                TL0=0x00;
                hh=23;
                mm=59;
                ss=55;
                lcdE=0;
                write_com(0x01); //clear display
                write_com(0x38); //set display mode
                write_com(0x0c);        //set display on and cursor appear
                write_com(0x06); //increase address by one,shift cursor to the right
                write_com(0x80+0x01); //set the address of date
                for(num=0;num<14;num++) //initialization date
                                write_dat(date[num]);
                                delay(5);
                write_com(0x80+0x44); //set the address of time
                for(num=0;num<8;num++)        //initialise time
                                write_dat(time[num]);
                                delay(5);
                init();
                while(1)  //if there is no cycle, it will be initialized all the time
                        key_scan();
ID:111634 发表于 2017-3-26 22:30 | 显示全部楼层
具有校正功能的时钟1302(LCD1602显示)
Proteus仿真,确认有效。
实例91 带校正时钟1302(LCD1602显示).rar (52.74 KB, 下载次数: 44)
ID:151348 发表于 2017-3-27 10:03 | 显示全部楼层
要是有仿真文件就好了,只看看程序不好找问题
ID:183600 发表于 2017-3-27 16:36 | 显示全部楼层
void key_scan()程序这样写有问题吗?
ID:111634 发表于 2017-3-27 19:51 | 显示全部楼层
先Proteus仿真,确认有效。
