- 我的这个程序是一个智能窗帘的程序,功能是定时开关窗帘和根据光照强度来开关窗帘,找了好久不知道错在哪里求给位帮忙看看
- #include<reg52.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit wela=P2^7;
- sbit lcdrs=P2^0;
- sbit lcdwr=P2^1;
- sbit lcden=P2^2;
- sbit k1=P3^4;
- sbit k2=P3^5;
- sbit k3=P3^6;
- sbit k4=P3^7;
- sbit ajjd=P3^3;
- sbit clk=P1^1;
- sbit io=P1^0;
- sbit rst=P1^2;
- sbit CLK0832= P1^1;
- sbit CS0832= P1^3;
- sbit Di0832= P1^4;
- sbit Do0832= P1^5;
- void naozhongscan();
- uchar num0,num1,num2,num3,num4;
- void init();
- void delay(uchar);
- void keyscan();
- uchar lcd_date_add[7]={0x40+9,0x40+6,0x40+3,0xa,7,0xd,4};
- uchar date_write_add[7]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c};//miao fen shi ri yue zhou nian
- uchar date_read_add[7]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};
- uchar date[7]={30,32,16,27,2,7,11};
- uchar date1[7];
- uchar naozhong[7]={35,32,16,27,2,7,11};
- uchar flag,flag1,flag2;
- uchar code table0[]=" - - ";
- uchar code table1[]=" : : ";
- uint light;
- uchar state=0;
- uchar read0832();
- void lcd_com(uchar);
- void lcd_date(uchar);
- void lcd_time(uchar,uchar);
- void write_ds1302(uchar add,uchar date);
- uchar read_ds1302(uchar add);
- void read_rtc();
- void set_ds1302(uchar add,uchar time);
- void display();
- void init_ds1302();
- void movestep();
- void reserve();
- void move();
- void main()
- wela=1;
- P1=0xff;
- wela=0;
- init();
- init_ds1302();
- while(1)
- if(flag1==1)
- naozhongscan();
- light=read0832();
- if(light>=0&&light<40)movestep(0);
- if(light>=40&&light<125)movestep(1);
- if(light>=125&&light<210)movestep(2);
- if(light>=210&&light<255)movestep(3);
- read_rtc();
- if(flag==0)
- display();
- keyscan();
- light=read0832();
- void init()
- flag=0;
- flag1=0;
- flag2=0;
- lcden=0;
- lcdwr=0;
- num2=0;
- num3=0;
- num4=0;
- lcd_com(0x38);//??????,16*2??,5*7??,8?????
- lcd_com(0x01);//??,???????
- lcd_com(0x0c);//?????????,???,????,????
- lcd_com(0x06);//???????????
- lcd_com(0x80);//????????????
- for(num0=0;num0<16;num0++)
- lcd_date(table0[num0]);
- lcd_com(0x80+0x40);
- for(num0=0;num0<11;num0++)
- lcd_date(table1[num0]);
- void lcd_com(uchar com)
- lcdrs=0;
- P0=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void lcd_date(uchar date)
- lcdrs=1;
- P0=date;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void lcd_time(uchar add,uchar Date)
- uchar shi,ge;
- shi=Date/10;
- ge=Date%10;
- lcd_com(0x80+add);
- lcd_date(0x30+shi);
- lcd_date(0x30+ge);
- void keyscan()
- ajjd=0;
- if(num3!=2)
- if(k1==0)
- delay(5);
- if(k1==0)
- while(!k1);
- num2++;
- if(num2==1)
- flag=1;
- lcd_com(0x80+lcd_date_add[0]);
- lcd_com(0x0f);//?????????,???,????,????
- if(num2==2)
- lcd_com(0x80+lcd_date_add[1]);
- if(num2==3)
- lcd_com(0x80+lcd_date_add[2]);
- if(num2==4)
- lcd_com(0x80+lcd_date_add[3]);
- if(num2==5)
- lcd_com(0x80+lcd_date_add[4]);
- if(num2==6)
- lcd_com(0x80+lcd_date_add[5]);
- if(num2==7)
- lcd_com(0x80+lcd_date_add[6]);
- if(num2==8)
- num2=0;
- flag=0;
- if(num2!=0)
- if(k2==0)
- delay(5);
- if(k2==0)
- while(!k2);
- if(num2==1)
- date[0]++;
- if(date[0]==60)
- date[0]=0;
- _nop_();
- lcd_time(lcd_date_add[0],date[0]);
- set_ds1302(date_write_add[0],date[0]);
- if(num2==2)
- date[1]++;
- if(date[1]==60)
- date[1]=0;
- _nop_();
- lcd_time(lcd_date_add[1],date[1]);
- set_ds1302(date_write_add[1],date[1]);
- if(num2==3)
- date[2]++;
- if(date[2]==24)
- date[2]=0;
- _nop_();
- lcd_time(lcd_date_add[2],date[2]);
- set_ds1302(date_write_add[2],date[2]);
- if(num2==4)
- date[3]++;
- if(date[3]==32)
- date[3]=1;
- _nop_();
- lcd_time(lcd_date_add[3],date[3]);
- set_ds1302(date_write_add[3],date[3]);
- if(num2==5)
- date[4]++;
- if(date[4]==13)
- date[4]=1;
- _nop_();
- lcd_time(lcd_date_add[4],date[4]);
- set_ds1302(date_write_add[4],date[4]);
- if(num2==6)
- date[5]++;
- if(date[5]==8)
- date[5]=1;
- _nop_();
- lcd_time(lcd_date_add[5],date[5]);
- set_ds1302(date_write_add[5],date[5]);
- if(num2==7)
- date[6]++;
- if(date[6]==99)
- date[6]=1;
- _nop_();
- lcd_time(lcd_date_add[6],date[6]);
- set_ds1302(date_write_add[6],date[6]);
- if(k3==0)
- delay(5);
- if(k3==0)
- while(!k3);
- if(num2==1)
- date[0]--;
- if(date[0]==-1)
- date[0]=59;
- _nop_();
- lcd_time(lcd_date_add[2],date[0]);
- if(num2==2)
- date[1]--;
- if(date[1]==-1)
- date[1]=59;
- _nop_();
- if(num2==3)
- date[2]--;
- if(date[2]==-1)
- date[2]=23;
- _nop_();
- if(num2==4)
- date[3]--;
- if(date[3]==0)
- date[3]=31;
- _nop_();
- if(num2==5)
- date[4]--;
- if(date[4]==0)
- date[4]=12;
- _nop_();
- if(num2==6)
- date[5]--;
- if(date[5]==0)
- date[5]=7;
- _nop_();
- if(num2==7)
- date[6]--;
- if(date[6]==0)
- date[6]=99;
- _nop_();
- if(k4==0)
- delay(5);
- if(k4==0)
- while(!k4);
- num3++;
- if(num3==1)
- flag1=1;
- lcd_com(0x80+1);
- lcd_date(0x41);
- if(num3==2)
- ajjd=0;
- flag1=0;
- if(num4==0)
- for(num0=0;num0<7;num0++)
- lcd_time(lcd_date_add[num0],naozhong[num0]);
- lcd_com(0x80+1);
- lcd_date(0x42);
- //lcd_com(0x0f);
- flag=1;
- if(k1==0)
- delay(5);
- if(k1==0)
- while(!k1);
- num4++;
- if(num4==1)
- if(num4==2)
- if(num4==3)
- if(num4==4)
- if(num4==5)
- if(num4==6)
- if(num4==7)
- if(num4==8)
- num4=0;
- flag=1;
- if(num4!=0)
- if(k2==0)
- delay(5);
- if(k2==0)
- while(!k2);
- if(num4==1)
- naozhong[0]++;
- if(naozhong[0]==60)
- naozhong[0]=0;
- _nop_();
- lcd_time(lcd_date_add[0],naozhong[0]);
- if(num4==2)
- naozhong[1]++;
- if(naozhong[1]==60)
- naozhong[1]=0;
- _nop_();
- lcd_time(lcd_date_add[1],naozhong[1]);
- if(num4==3)
- naozhong[2]++;
- if(naozhong[2]==24)
- naozhong[2]=0;
- _nop_();
- lcd_time(lcd_date_add[2],naozhong[2]);
- if(num4==4)
- naozhong[3]++;
- if(naozhong[3]==32)
- naozhong[3]=1;
- _nop_();
- lcd_time(lcd_date_add[3],naozhong[3]);
- if(num4==5)
- naozhong[4]++;
- if(naozhong[4]==13)
- naozhong[4]=1;
- _nop_();
- lcd_time(lcd_date_add[4],naozhong[4]);
- if(num4==6)
- naozhong[5]++;
- if(naozhong[5]==8)
- naozhong[5]=1;
- _nop_();
- lcd_time(lcd_date_add[5],naozhong[5]);
- if(num4==7)
- naozhong[6]++;
- if(naozhong[6]==99)
- naozhong[6]=1;
- _nop_();
- lcd_time(lcd_date_add[6],naozhong[6]);
- if(k3==0)
- delay(5);
- if(k3==0)
- while(!k3);
- if(num4==1)
- naozhong[0]--;
- if(naozhong[0]==-1)
- naozhong[0]=59;
- _nop_();
- lcd_time(lcd_date_add[2],naozhong[0]);
- if(num4==2)
- naozhong[1]--;
- if(naozhong[1]==-1)
- naozhong[1]=59;
- _nop_();
- if(num4==3)
- naozhong[2]--;
- if(naozhong[2]==-1)
- naozhong[2]=23;
- _nop_();
- if(num4==4)
- naozhong[3]--;
- if(naozhong[3]==0)
- naozhong[3]=31;
- _nop_();
- if(num4==5)
- naozhong[4]--;
- if(naozhong[4]==0)
- naozhong[4]=12;
- _nop_();
- if(num4==6)
- naozhong[5]--;
- if(naozhong[5]==0)
- naozhong[5]=7;
- _nop_();
- if(num4==7)
- naozhong[6]--;
- if(naozhong[6]==0)
- naozhong[6]=99;
- _nop_();
- if(num3==3)
- flag=0;
- flag1=0;
- lcd_com(0x80+1);
- lcd_date(20);//?lcd??????
- num3=0;
- num4=0;
- uchar i,temp;
- rst=0;
- clk=0;
- _nop_();
- rst=1;
- for(i=0;i<8;i++)
- clk=0;
- temp=add;
- io=temp&0x01;
- add>>=1;
- clk=1;
- _nop_();
- for(i=0;i<8;i++)
- clk=0;
- temp=date;
- io=temp&0x01;
- date>>=1;
- clk=1;
- _nop_();
- rst=0;
- uchar i,temp,data1,j;
- rst=0;
- clk=0;
- _nop_();;
- rst=1;
- for(i=0;i<8;i++)
- clk=0;
- temp=add;
- io=temp&0x01;
- add>>=1;
- clk=1;
- _nop_();
- for(i=0;i<8;i++)
- data1>>=1;
- clk=0;
- if(io)
- data1=data1|0x80;
- clk=1;
- rst=0;
- _nop_();
- j=data1%16;
- data1=data1/16;
- data1=data1*10+j;
- return(data1);
- uchar j;
- write_ds1302(0x8e,0x00);
- j=time/10;
- time=time%10;
- time=time+j*16;
- write_ds1302(add,time);
- write_ds1302(0x8e,0x80);
- void read_rtc()
- uchar i;
- for(i=0;i<7;i++)
- date[ i]=read_ds1302(date_read_add[ i]);
- void display()
- uchar i;
- for(i=0;i<7;i++)
- lcd_time(lcd_date_add[ i],date[ i]);
- uchar i=0;
- uchar j=0;
- while((j==0)&&(i<7))
- j=naozhong^date[ i];
- i++;
- if(i==7)
- movestep(3);
- uchar read0832()
- uchar i,dat1=0,dat2=0;
- CS0832=0;
- CLK0832=0;
- Di0832=1;
- CLK0832=1;//òÔéÏ1y3ì2úéúáËò»¸ö¿aê¼DÅoÅ
- CLK0832=0;
- Di0832=1;//D¾Æ¬ÕaÄü½øDDμ¥í¨μà×a»»Ä£ê½
- CLK0832=1;
- CLK0832=0;
- Di0832=1;
- CLK0832=1;//¶Ôí¨μà1½øDD×a»»
- CLK0832=0;
- Di0832=1;
- for(i=0;i<8;i++)
- dat1 = dat1 | Di0832;
- CLK0832 = 1;
- CLK0832 = 0;
- dat1 = dat1 << 1 ;
- CS0832 = 1;
- return dat1;// (dat1 == dat2) ? dat1:0;
- void move(uchar step)
- uchar i;
- P2=0x0f;
- for(i=0;i<step;i++)
- P2=0x03;
- delay(200);
- P2=0x06;
- delay(200);
- P2=0x0c;
- delay(200);
- P2=0x09;
- delay(200);
- void reserve(uchar step)
- uchar i;
- P2=0x0f;
- P2=0x09;
- delay(200);
- P2=0x0c;
- delay(200);
- P2=0x06;
- delay(200);
- P2=0x03;
- delay(200);
- void movestep(uchar level)
- switch(level)
- case 0:switch(state)
- case 0:break;
- case 1:reserve(1);break;
- case 2:reserve(2);break;
- case 3:reserve(3);break;
- }state=0;break;
- case 1:switch(state)
- case 0:move(1);break;
- case 1:break;
- case 2:reserve(1);break;
- case 3:reserve(2);break;
- }state=1;break;
- case 2:switch(state)
- case 0:move(2);break;
- case 1:move(1);break;
- case 2:break;
- case 3:reserve(1);break;
- }state=2;break;
- case 3:switch(state)
- case 0:move(3);break;
- case 1:move(2);break;
- case 2:move(1);break;
- case 3:break;
- }state=3;break;
