查看: 7270|回复: 3
一个32位摇摇棒程序+原理图
32位摇摇棒程序原理图:
32位摇摇棒程序:
  1. #include <STC11F60XE.h>
  2. /*********外部接口定义**********/
  4. #define uint unsigned int    //宏定义
  5. #define out P1        //数据输出端口
  6. sbit led1=P3^0;        //第1组LED
  7. sbit led2=P3^1;        //第2组LED
  8. sbit led3=P3^3;        //第3组LED
  9. sbit led4=P3^4;        //第4组LED
  10. sbit key1=P3^5;         //按键输入
  11. sbit p3_2=P3^2;
  12. uchar KY,num;      //KY作用在后面说明
  13. uchar BUFF;                                   //缓存
  14. /*********全局变量定义**********/
  15. unsigned long int TimeCount=0;
  16. unsigned int         DelayN=80,                //延时临时计数
  17.                                 DelayTime=80;        //每次延时的周期个数
  18. unsigned char key,keyy;
  19. /**********************************************/
  20. void delay(unsigned char n);
  21. void DelayMs(void);
  22. /*******************************************/
  23. unsigned char code text0[]={
  24. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  25. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0xB7,0xBB,0xB7,0xBB,0xB3,0xBB,0xB4,0xBB,0xB5,0xBB,0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0x07,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"自",1*/
  26. 0xBF,0xBF,0xBE,0xDF,0x39,0xE0,0xFF,0xDF,0xEF,0xBF,0xEF,0xBF,0x6D,0xB0,0x6D,0xB7,0x6D,0xB7,0x01,0xB7,0x6E,0xB7,0x6E,0xB7,0x6E,0xB0,0xEF,0xBF,0xEF,0xBF,0xFF,0xFF,/*"适",2*/
  27. 0xFF,0xBF,0xFF,0xC7,0x03,0xF8,0xBB,0xDF,0x7B,0xDF,0xFB,0xD0,0xEB,0xDB,0xDA,0xDF,0x39,0xDC,0x7B,0xCF,0xFB,0xD3,0xFB,0xDC,0x1B,0xDF,0xBB,0xDF,0xFF,0xDF,0xFF,0xFF,/*"应",3*/
  28. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  29. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  30. 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"摇",6*/
  31. 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"摇",7*/
  32. 0xEF,0xFC,0x2F,0xFF,0x00,0x00,0xAF,0xFF,0x6F,0xFD,0xBB,0xF5,0xAB,0xF6,0x2B,0xF5,0x8B,0xF5,0xA0,0x00,0x2B,0xF5,0xAB,0xF4,0xAB,0xF6,0xBB,0xF5,0xBF,0xFD,0xFF,0xFF,/*"棒",8*/
  33. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",9*/
  34. };
  35. unsigned char code text1[]={
  36. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  37. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
  38. 0xF7,0xFD,0xF7,0xFE,0x76,0xFF,0x31,0x00,0x57,0xFF,0xE7,0x7C,0xFF,0xBF,0x01,0xCF,0x7D,0xF0,0x7D,0xFF,0x7D,0xFF,0x7D,0x80,0x01,0x7F,0xFF,0x7F,0xFF,0x0F,0xFF,0xFF,/*"祝",2*/
  39. 0x7F,0xFF,0xBF,0xFF,0x0F,0x80,0xD3,0xFF,0xBC,0xEF,0xDF,0xF3,0x67,0xFC,0xF0,0xDE,0xF5,0xBF,0x17,0xC0,0xF7,0xFF,0x77,0xFF,0xD7,0xFC,0xE3,0xE3,0xF7,0xF7,0xFF,0xFF,/*"你",3*/
  40. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  41. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  42. 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",6*/
  43. 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",7*/
  44. 0xBF,0xFF,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF3,0x01,0xFC,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0x01,0x80,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xFF,0xFF,/*"开",8*/
  45. 0xFF,0xFB,0x7F,0xFC,0xFF,0xFF,0xFF,0xFF,0x0F,0xC0,0xFF,0xBF,0xFE,0xBF,0xFD,0xBF,0xE3,0xBF,0xF7,0xBF,0xFF,0xBF,0xBF,0x87,0x7F,0xFF,0xFF,0xF8,0xFF,0xFD,0xFF,0xFF,/*"心",9*/
  46. };
  47. unsigned char code text2[]={
  48. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0x01,0x00,0x00,0x80,0x01,0x00,0x00,0x80,0xF9,0xFF,0xFF,0x9F,
  49. 0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0x01,0xFE,0xFF,
  50. 0x7F,0x00,0xF8,0xFF,0x3F,0x00,0xF0,0xFF,0x1F,0x00,0xE0,0xFF,0x0F,0x00,0xC0,0xFF,0x07,0x00,0x80,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFE,
  51. 0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xF8,0x07,0x00,0x00,0xF0,0x0F,0x00,0x00,0xE0,0x1F,0x00,0x00,0xE0,0x3F,0x00,0x00,0xC0,0x3F,0x00,0x00,0x80,0x1F,0x00,0x00,0xC0,
  52. 0x0F,0x00,0x00,0xE0,0x07,0x00,0x00,0xF0,0x03,0x00,0x00,0xF8,0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xFE,0x03,0x00,0x00,0xFF,0x07,0x00,0x80,0xFF,0x0F,0x00,0xC0,0xFF,
  53. 0x1F,0x00,0xE0,0xFF,0x3F,0x00,0xE0,0xFF,0xFF,0x00,0xF8,0xFF,0xFF,0x01,0xFC,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  54. 0x07,0x00,0x00,0xE0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0xFF,0xFF,0xFF,0xC7,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,
  55. 0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xC7,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xFF,/*"未命名文件",0*/
  56. };
  57. /***********n(us)延时子程序***************/
  58. void DelayUs(uint N)
  59. {
  60. uint x;
  61. for(x=0; x<=N;x++);
  62. }
  63. /******************************************/
  64. void main()
  65. {
  66.         AUXR=0x80;
  67.         CLK_DIV=1;
  68.         EX0=1;        //开放外部中断0
  69.         IT0=1;        //中断0为边沿触发方式
  70.         IP=0x02;        //设置中断优先级
  71.         TMOD=0x02;        //定时器0方式2,8位重装载
  72.         TH0=0x80;        //设定定时器初值
  73.         TL0=0x80;
  74.         KY=0;
  75.         EA=1;        //开放中断
  76.         ET0=1;        //开放定时器0中断
  77.         TR0=1;        //启动定时器0,开始计时*/
  78.         key=0;        //初始化显示第一组文字
  79.         keyy=0;
  80.         P1M0=0x55;        //0101 0101        /P1.0  P1 .2 P1.4 P1.6推挽输出
  81.     P1M1=0xAA;
  82.         while(1){//等待中断
  83.
  84.         if(key1==0){        //有键按下
  85.          DelayUs(50);
  86.          if(key1==0){
  87.                 key++;                                //更换下一幅图片
  88.                 if(key>2) key=0;        //图片循环显示 根据显示的组数来定义 这里有9组 所以就要keyy>9
  89.                 while(key1==0);                //等待按键释放
  90.                 }
  91.                 }
  92.         if(num>10) //每中断10次切换
  93.                 {
  94.                 keyy++;
  95.                 num=0;
  96.                 }
  97.         if(keyy>2)keyy=0;        //图片循环显示 根据显示的组数来定义 这里有9组 所以就要keyy>9
  98.         }
  99. }
  100.
  101. /*********文字显示子程序**********/
  102. void display_word(unsigned char code *text)
  103. {
  104.    unsigned        char i,j=2;                        //j为图片起始位置 3 为第3个开始是图片 如果要显示高时32的大字 也属于图片格式
  105.     DelayUs(6400);
  106.
  107.         for(i=0;i<64;i++)
  108.         {
  109.
  110.         P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  111.             P3M1=0x1B;
  112.                 if((key>=j)||(keyy>=j))
  113.                 BUFF=(*(text+i*4+3));
  114.                 else
  115.                 BUFF=(*(text+128+i*2+1));
  116.                 led4=0;
  117.                 P1=~BUFF>>1;
  118.                 P3M0=0x10;                        //0001 0000        //P3.4推挽输出 P3 .0 P3.3 P3.1输入高阻
  119.             P3M1=0x0B;          //0000 1011
  120.                  delay(1);
  121.                 P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  122.             P3M1=0x1B;                         //0001 1011
  123.                 led4=1;
  124.              P1=BUFF;             //01010101  1357
  125.                 P3M0=0x10;                        //0001 0000        //P3.4推挽输出 P3 .0 P3.3 P3.1输入高阻
  126.             P3M1=0x0B;          //0000 1011
  127.                  delay(1);
  128.                 P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  129.             P3M1=0x1B;                         //0001 1011
  130.                 if((key>=j)||(keyy>=j))
  131.                 BUFF=(*(text+i*4+2));
  132.                 else
  133.                 BUFF=(*(text+128+i*2));
  134.                 led3=0;
  135.                 P1=~BUFF>>1;
  136.                 P3M0=0x08;                        //0000 1000        //P3.3推挽输出 P3 .0 P3.1 P3.4输入高阻
  137.             P3M1=0x13;          //0001 0011
  138.                 delay(1);
  139.                 P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  140.             P3M1=0x1B;                         //0001 1011
  141.                 led3=1;
  142.              P1=BUFF;             //01010101  1357
  143.                 P3M0=0x08;                        //0000 1000        //P3.3推挽输出 P3 .0 P3.1 P3.4输入高阻
  144.             P3M1=0x13;          //0001 0011
  145.                  delay(1);
  146.                 P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  147.             P3M1=0x1B;
  148.                 if((key>=j)||(keyy>=j))
  149.                 BUFF=(*(text+i*4+1));
  150.                 else
  151.                 BUFF=(*(text+i*2+1));
  152.                 led2=0;
  153.             P1=~BUFF>>1;
  154.                 P3M0=0x02;                        //0000 0010        //P3.1推挽输出 P3 .0 P3.3 P3.4输入高阻
  155.             P3M1=0x19;                        //0001 1001
  156.                 delay(1);
  157.                 P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  158.             P3M1=0x1B;                         //0001 1011
  159.                 led2=1;
  160.              P1=BUFF;            //01010101  1357
  161.                 P3M0=0x02;                        //0000 0010        //P3.1推挽输出 P3 .0 P3.3 P3.4输入高阻
  162.             P3M1=0x19;                        //0001 1001
  163.                  delay(1);
  164.                 P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  165.             P3M1=0x1B;                         //0001
  166.                 if((key>=j)||(keyy>=j))
  167.                 BUFF=(*(text+i*4));
  168.                 else
  169.                 BUFF=(*(text+i*2));
  170.                 led1=0;
  171.                 P1=~BUFF>>1;
  172.                 P3M0=0x01;                        //0000 0001        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  173.             P3M1=0x1A;                         //0001 1010
  174.                 delay(1);
  175.             P3M0=0x00;                        //0000 0000        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  176.             P3M1=0x1B;                         //0001 1011
  177.                 led1=1;
  178.              P1=BUFF;            //01010101  1357
  179.                 P3M0=0x01;                        //0000 0001        //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
  180.             P3M1=0x1A;                         //0001 1010
  181.                  delay(1);
  182. } }
  183. /*********显示内容选择子程序**********/
  184. void display(unsigned char t)
  185. {        keyy=0;
  186.         switch (t){                //通过按键选择显示内容
  187.                 case 0:        {display_word(text0);}break;
  188.                 case 1:        {display_word(text1);}break;
  189.                 case 2:        {display_word(text2);}break;
  190. //                case 3:        {display_word(text3);}break;
  191. //                case 4:        {display_word(text4);}break;
  192. //                case 5:        {display_word(text5);}break;
  193. //                case 6:        {display_word(text6);}break;
  194. //                case 7:        {display_word(text7);}break;
  195.         //        case 8:        {display_word(text8);}break;
  196.         //        case 9:        {display_word(text9);}break;
  197.         //        case 10:{display_word(text10);}break;
  198.                 //default:{display_word(text1);}
  199.
  200.
  201.                 }}
  202. /*****************************************/
  203. void display1(unsigned char y)
  204. {
  205.         switch (y){                //通过按键选择显示内容
  206.                 case 0:        {display_word(text0);}break;
  207.                 case 1:        {display_word(text1);}break;
  208.                 case 2:        {display_word(text2);}break;
  209. //                case 3:        {display_word(text3);}break;
  210. //                case 4:        {display_word(text4);}break;
  211. //                case 5:        {display_word(text5);}break;
  212. //                case 6:        {display_word(text6);}break;
  213. //                case 7:        {display_word(text7);}break;
  214.         //        case 8:        {display_word(text8);}break;
  215.         //        case 9:        {display_word(text9);}break;
  216.         //        case 10:{display_word(text10);}break;
  217.                 }
  218.                 }
  219. /***************************************/
  220. /*********延时子程序**********/
  221. void delay(unsigned char n)
  222. {
  223.         for(;n>0;n--){
  224.                 DelayN=DelayTime;
  225.                 while (DelayN);
  226.         }
  227. }
  228. /*********中断子程序**********/
  229. void int0() interrupt 0        //使用外部中断0
  230. {
  231. KY=~KY;
  232. if(KY==0)
  233. {
  234.         DelayTime=TimeCount/1580;
  235.         TimeCount=0;        //延时周期计数清零
  236.         if(key==0)
  237.         {
  238.          num++;
  239.          display1(keyy);        //根据按键选择循环显示文字
  240.         }
  241.         else
  242.         {
  243.         display(key);        //根据按键选择循环显示文字
  244.         }
  245. }
  246. }
  247. void timer0() interrupt 1                //定时器0中断子程序
  248. {
  249.         TimeCount++;
  250.         if (DelayN!=0)
  251.         DelayN--;
  252. }
收藏收藏1 分享淘帖 顶 踩
ID:188983 发表于 2017-4-12 21:26 | 只看该作者
您好,您有时间做单片机兼职吗?如果有兴趣加我QQ,我这里长期需要编程兼职
ID:55655 发表于 2018-6-9 17:23 | 只看该作者
烧进去手都摇酸了就显示几下,图都看不清是什么,就别提撩女神了
ID:978459 发表于 2022-4-12 10:24 来自手机 | 只看该作者
请问led显示模块的原理是啥,如何通过八个io口驱动32个led灯的
