分享个测障小车制作,带有完整的设计报告,proteus仿真及源代码
具有红外测障,角度测量功能
避障部分采用红外线发射和接受原理。铁片检测采用电感式接近开关LJ18A3-8-Z/BX检测,产生的高低电平信号经过处理后,完成相应的记录数目,驱动蜂鸣器发声。黑带寻迹依*安装在车底部左右两个光敏二极管对管来对地面反射光感应。寻光设计在小车前端安装3路(左、中、右)光敏电阻对光源信号采集,模拟信号经过ADC0809转化为数字信号送到MCU处理。记程通过在车轮上安装小磁块,再用霍尔管感应产生计数脉冲。记时由软件实现,显示采用普通七段LED。此系统比较灵活,采用软件方法来解决复杂的硬件电路部分,使系统硬件简洁化,各类功能易于实现。
单片机部分源码:
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- //uchar code LED[4]={0xdc,0xe3,0x9c,0xce};
- uchar jianhao _at_ 0x40;
- uchar code LCD[]={0x20,0x5e,0x76,0x54,0x42};
- sbit SH_CP=P2^2; //595
- sbit ST_CP=P2^3;
- sbit DS=P2^4;
- sbit ACC7=ACC^7;
- sbit RS=P2^5; //Lcd
- sbit RW=P2^6;
- sbit E =P2^7;
- sbit p31=P3^1;
- sbit p32=P3^2;
- //中断接收
- void inter0(void) interrupt 0
- #pragma asm
- PUSH ACC
- PUSH PSW
- CLR EX0
- JNB P3.1, READ1
- READOUT0:SETB EX0
- SETB EA
- POP PSW
- POP ACC
- RETI
- READ1: CLR A
- MOV DPH, A
- MOV DPL, A
- HARD1: JB P3.1,HARD11
- INC DPTR
- NOP
- NOP
- AJMP HARD1
- HARD11: MOV A,DPH
- JZ READOUT0
- CLR A
- READ11: INC A
- READ12: JNB P3.1,READ12
- MOV R1,#06H
- READ13: JNB P3.1,READ11
- MOV R5,#255
- DJNZ R5,$
- DJNZ R1,READ13
- // DEC A
- MOV 40H,A
- LJMP READOUT0
- #pragma endasm
- void Delay_1ms(uint j)
- { uchar i=0;
- for(;j>0;j--)
- for(i=0;i<125;i++);
- void delay(uchar t, uchar i)
- { for(;t>0;t--)
- { for(;i>0;i--); }
- void sent(unsigned char dat)
- { uchar i;
- ACC=dat;
- for(i=8;i>0;i--)
- { ST_CP=0;
- DS=ACC7;
- SH_CP=0;
- ACC=ACC<<1;
- SH_CP=1;
- delay(1,3);
- ST_CP=1;
- void lcdwd(uchar da)
- { RS=1;
- RW=0;
- E=1;
- sent(da);
- delay(1,100);
- E=0;
- void lcdwc(uchar c)
- { RS=0;
- RW=0;
- E=1;
- sent(c);
- delay(1,100);
- E=0;
- void lcdinit()
- { delay(15,125);
- lcdwc(0x38);
- delay(5,125);
- lcdwc(0x38);
- delay(5,125);
- lcdwc(0x38);
- delay(5,125);
- lcdwc(0x08);
- lcdwc(0x01);
- lcdwc(0x06);
- lcdwc(0x0c);
- void WriteString(uchar *s,uchar a,uchar b)//字符串由N个单字字符组成
- { for(;*s!=0;s++)
- { lcdwc(0x80+(a++)+0x40*b);//地址
- lcdwd(*s); //数据
- void display()
- {uchar s1[4],*ps;
- s1[0]='y';
- s1[1]='k';
- s1[2]=' ';
- s1[3]=LCD[jianhao];
- ps=&s1;
- WriteString(ps,0,0);}
- //主程序
- void main()
- IE=0;EX0=1;EA=1; lcdinit();//jianhao=0;
- for(;;)
- display();
完整的设计报告和其他资料下载:
测障测角小车.rar
(126.75 KB, 下载次数: 21)
