- /*************** writer:shopping.w ******************/
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- uchar code LEDData[]=
- 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
- sbit OE = P1^0;
- sbit EOC = P1^1;
- sbit ST = P1^2;
- sbit CLK = P1^3;
- void DelayMS(uint ms)
- uchar i;
- while(ms--)
- for(i=0;i<120;i++);
- void Display_Result(uchar d)
- P2 = 0xf7;
- P0 = LEDData[d%10];
- DelayMS(5);
- P2 = 0xfb;
- P0 = LEDData[d%100/10];
- DelayMS(5);
- P2 = 0xfd;
- P0 = LEDData[d/100];
- DelayMS(5);
- void main()
- TMOD = 0x02; //设定定时器0为工作方式2
- TH0 = 0x14; //给定时器装载初值
- TL0 = 0x00;
- IE = 0x82; //中断控制寄存器,开总中断,开定时器0中断源
- TR0 = 1; //打开计时器0
- P1 = 0x3f; //初始控制信号
- while(1)
- ST = 0;
- ST = 1;
- ST = 0;
- while(EOC == 0);
- OE = 1;
- Display_Result(P3);
- OE = 0;
- void Timer0_INT() interrupt 1
- CLK = !CLK;
下载:
ADC0809模数转换与显示.zip
(64.01 KB, 下载次数: 44)
