查看: 4060|回复: 2
单片机ds18b20温度检测电路仿真设计 带源码
ID:193204 发表于 2017-4-24 21:29 | 显示全部楼层 |阅读模式
分享一个ds18b20传感器检测环境温度,数码管显示并且超过一定温度蜂鸣器蜂鸣报警,下面是部分电路仿真图。
51单片机源程序:
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. sbit DS=P2^2;           //define interface
  5. uint temp;             // variable of temperature
  6. uchar flag1;            // sign of the result positive or negative
  7. sbit wela1=P2^4;                //段选信号的锁存器控制
  8. sbit wela2=P2^5;
  9. sbit wela3=P2^6;                //段选信号的锁存器控制
  10. sbit wela4=P2^7;                //位选信号的锁存器控制
  11. sbit beep=P2^3;
  12. unsigned char code table[]={0xC0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
  13.                         0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
  14. unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
  15.                         0x87,0xff,0xef};
  16. void delay(uint count)      //delay
  17. {
  18.   uint i;
  19.   while(count)
  20.   {
  21.     i=200;
  22.     while(i>0)
  23.     i--;
  24.     count--;
  25.   }
  26. }
  27. void dsreset(void)       //send reset and initialization command
  28. {
  29.   uint i;
  30.   DS=0;
  31.   i=103;
  32.   while(i>0)i--;
  33.   DS=1;
  34.   i=4;
  35.   while(i>0)i--;
  36. }
  37. bit tmpreadbit(void)       //read a bit
  38. {
  39.    uint i;
  40.    bit dat;
  41.    DS=0;i++;          //i++ for delay
  42.    DS=1;i++;i++;
  43.    dat=DS;
  44.    i=8;while(i>0)i--;
  45.    return (dat);
  46. }
  47. uchar tmpread(void)   //read a byte date
  48. {
  49.   uchar i,j,dat;
  50.   dat=0;
  51.   for(i=1;i<=8;i++)
  52.   {
  53.     j=tmpreadbit();
  54.     dat=(j<<7)|(dat>>1);   //读出的数据最低位在最前面,这样刚好一个字节在DAT里
  55.   }
  56.   return(dat);
  57. }
  58. void tmpwritebyte(uchar dat)   //write a byte to ds18b20
  59. {
  60.   uint i;
  61.   uchar j;
  62.   bit testb;
  63.   for(j=1;j<=8;j++)
  64.   {
  65.     testb=dat&0x01;
  66.     dat=dat>>1;
  67.     if(testb)     //write 1
  68.     {
  69.       DS=0;
  70.       i++;i++;
  71.       DS=1;
  72.       i=8;while(i>0)i--;
  73.     }
  74.     else
  75.     {
  76.       DS=0;       //write 0
  77.       i=8;while(i>0)i--;
  78.       DS=1;
  79.       i++;i++;
  80.     }
  81.   }
  82. }
  83. void tmpchange(void)  //DS18B20 begin change
  84. {
  85.   dsreset();
  86.   delay(1);
  87.   tmpwritebyte(0xcc);  // address all drivers on bus
  88.   tmpwritebyte(0x44);  //  initiates a single temperature conversion
  89. }
  90. uint tmp()               //get the temperature
  91. {
  92.   float tt;
  93.   uchar a,b;
  94.   dsreset();
  95.   delay(1);
  96.   tmpwritebyte(0xcc);
  97.   tmpwritebyte(0xbe);
  98.   a=tmpread();
  99.   b=tmpread();
  100.   temp=b;
  101.   temp<<=8;             //two byte  compose a int variable
  102.   temp=temp|a;
  103.   tt=temp*0.0625;
  104.   temp=tt*10+0.5;
  105.   return temp;
  106. }
  107. void display(uint temp)                        //显示程序
  108. {
  109.
  110.    uchar A1,A2,A2t,A3;
  111.    A1=temp/100;
  112.    A2t=temp%100;
  113. …………限于本文篇幅 余下代码请从51黑下载附件…………
下载:
数码管显示温度并报警 .rar (63.77 KB, 下载次数: 68)
参与人数 1黑币 +5 收起 理由
荒谬的真理 + 5 很给力!
ID:210052 发表于 2017-6-11 11:53 | 显示全部楼层
好东西。。。
ID:216275 发表于 2017-7-1 17:24 | 显示全部楼层
非常好,我觉得可以靠这个改编一下物自己的程序了
