#include<reg52.h> //库文件
#define uchar unsigned char//宏定义无符号字符型
#define uint unsigned int //宏定义无符号整型
uchar Count;
sbit Key=P3^4;//P3.4控制T0口中断
sbit _Speak =P2^0 ; //讯响器控制脚 //定义一个位变量_Speak
unsigned char code SONG[] ={
//路边的野华不要采
0xFF,0x20,0x30,0x1C,0x10,0x18,0x20,
0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,
0x30,0x80,0xFF,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,
0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,0x30,0x80,0x20,0x30,0x1C,0x10,0x20,
0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,0x15,0x1F,
0x05,0x20,0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,
0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,
0x20,0x26,0x20,0x20,0x20,0x30,0x30,0x20,0x30,0x1C,0x10,0x18,0x40,0x1C,0x20,0x20,
0x20,0x26,0x40,0x13,0x60,0x18,0x20,0x15,0x40,0x13,0x40,0x18,0x80,0x00,
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00,};
void Time0_Init()//初始化函数
TMOD = 0x01;//定时器中断地工作状态为1
IE = 0x82; //p127 中断允许寄存器,82=10000010,IE.7位为1表示CPU开放中断,IE.1表示允许定时器T0溢出中断
TH0 = 0xD8; //为T0计数器付初值,高位TH0=0XD8,低位TL0=0XF0,65536-55536=10000,表明T0计数器计数10000个计数周期后溢出
TL0 = 0xF0; //12MZ晶振,10ms
void Time0_Int() interrupt 1 //定时计数器T0中断p128
TH0 = 0xD8; //重装初值
TL0 = 0xF0;
Count++; //长度加1,执行一次,中断计数器加一
void Delay_xMs(unsigned int x) //1MS 延时子程序
unsigned int i,j;
for( i =0;i < x;i++ )
for( j =0;j<3;j++ );
void Play_Song(unsigned char i) //:歌曲播放子程序i 为播放哪一段曲目
unsigned char Temp1,Temp2;
unsigned int Addr=0;
Count = 0; //中断计数器清0
Addr=i*165;
Temp1 = SONG[Addr++];
if ( Temp1 == 0xFF ) //休止符
TR0 = 0; Delay_xMs(100);
else if ( Temp1 == 0x00 ) //歌曲结束符
return;
Temp2 = SONG[Addr++];
TR0 = 1;
_Speak = ~_Speak; //按位取反指令
Delay_xMs(Temp1);
if ( Temp2 == Count )
Count = 0;
break;
void main() //主程序
Time0_Init(); //定时器0 中断初始化
if(Key==0){
Play_Song(0);
if(Key==0){
Play_Song(1);}}else{
TR0=0;
} //播放
这是目前的代码,我想知道怎么通过点击P3.4的按钮实现切换到下一首歌曲的功能 |
