查看: 8137|回复: 2
STM32多通道adc采集代码
ID:202393 发表于 2017-5-19 03:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
STM32 ADC多通道转换
描述:用ADC连续采集11路模拟信号,并由DMA传输到内存。ADC配置为扫描并且连续转换模式,ADC的时钟配置为12MHZ。在每次转换结束后,由DMA循环将转换的数据传输到内存中。ADC可以连续采集N次求平均值。最后通过串口传输出最后转换的结果。
程序如下:
  1. #i nclude "stm32f10x.h" //这个头文件包括STM32F10x所有外围寄存器、位、内存映射的定义
  2. #i nclude "eval.h" //头文件(包括串口、按键、LED的函数声明)
  3. #i nclude "SysTickDelay.h"
  4. #i nclude "UART_INTERFACE.h"
  5. #i nclude <stdio.h>
  6. #define N 50 //每通道采50次
  7. #define M 12 //为12个通道
  8. vu16 AD_Value[N][M]; //用来存放ADC转换结果,也是DMA的目标地址
  9. vu16 After_filter[M]; //用来存放求平均值之后的结果
  10. int i;
  11. void GPIO_Configuration(void)
  12. {
  13. GPIO_InitTypeDef GPIO_InitStructure;
  14. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  15. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //因为USART1管脚是以复用的形式接到GPIO口上的,所以使用复用推挽式输出
  16. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  17. GPIO_Init(GPIOA, &GPIO_InitStructure);
  18. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  19. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  20. GPIO_Init(GPIOA, &GPIO_InitStructure);
  21. //PA0/1/2 作为模拟通道输入引脚
  22. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
  23. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
  24. GPIO_Init(GPIOA, &GPIO_InitStructure);
  25. //PB0/1 作为模拟通道输入引脚
  26. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  27. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
  28. GPIO_Init(GPIOB, &GPIO_InitStructure);
  29. //PC0/1/2/3/4/5 作为模拟通道输入引脚
  30. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
  31. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
  32. GPIO_Init(GPIOC, &GPIO_InitStructure);
  33. }
  34. }
  35. void RCC_Configuration(void)
  36. {
  37. ErrorStatus HSEStartUpStatus;
  38. RCC_DeInit(); //RCC 系统复位
  39. RCC_HSEConfig(RCC_HSE_ON); //开启HSE
  40. HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待HSE准备好
  41. if(HSEStartUpStatus == SUCCESS)
  42. {
  43. FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
  44. FLASH_SetLatency(FLASH_Latency_2); //Set 2 Latency cycles
  45. RCC_HCLKConfig(RCC_SYSCLK_Div1); //AHB clock = SYSCLK
  46. RCC_PCLK2Config(RCC_HCLK_Div1); //APB2 clock = HCLK
  47. RCC_PCLK1Config(RCC_HCLK_Div2); //APB1 clock = HCLK/2
  48. RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6); //PLLCLK = 12MHz * 6 = 72 MHz
  49. RCC_PLLCmd(ENABLE); //Enable PLL
  50. while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLL is ready
  51. RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock source
  52. while(RCC_GetSYSCLKSource() != 0x08); //Wait till PLL is used as system clock source
  53. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB
  54. | RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1 | RCC_APB2Periph_AFIO |RCC_APB2Periph_USART1, ENABLE ); //使能ADC1通道时钟,各个管脚时钟
  55. RCC_ADCCLKConfig(RCC_PCLK2_Div6); //72M/6=12,ADC最大时间不能超过14M
  56. RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA传输
  57. }
  58. }
  59. void ADC1_Configuration(void)
  60. {
  61. ADC_InitTypeDef ADC_InitStructure;
  62. ADC_DeInit(ADC1); //将外设 ADC1 的全部寄存器重设为缺省值
  63. ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在独立模式
  64. ADC_InitStructure.ADC_ScanConvMode =ENABLE; //模数转换工作在扫描模式
  65. ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //模数转换工作在连续转换模式
  66. ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //外部触发转换关闭
  67. ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐
  68. ADC_InitStructure.ADC_NbrOfChannel = M; //顺序进行规则转换的ADC通道的数目
  69. ADC_Init(ADC1, &ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
  70. //设置指定ADC的规则组通道,设置它们的转化顺序和采样时间
  71. //ADC1,ADC通道x,规则采样顺序值为y,采样时间为239.5周期
  72. ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
  73. ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
  74. ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
  75. ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
  76. ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 5, ADC_SampleTime_239Cycles5 );
  77. ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 6, ADC_SampleTime_239Cycles5 );
  78. ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 7, ADC_SampleTime_239Cycles5 );
  79. ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 8, ADC_SampleTime_239Cycles5 );
  80. ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 9, ADC_SampleTime_239Cycles5 );
  81. ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 10, ADC_SampleTime_239Cycles5 );
  82. ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
  83. ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
  84. // 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
  85. ADC_DMACmd(ADC1, ENABLE);
  86. ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1
  87. ADC_ResetCalibration(ADC1); //复位指定的ADC1的校准寄存器
  88. while(ADC_GetResetCalibrationStatus(ADC1)); //获取ADC1复位校准寄存器的状态,设置状态则等待
  89. ADC_StartCalibration(ADC1); //开始指定ADC1的校准状态
  90. while(ADC_GetCalibrationStatus(ADC1)); //获取指定ADC1的校准程序,设置状态则等待
  91. }
  92. void DMA_Configuration(void)
  93. {
  94. DMA_InitTypeDef DMA_InitStructure;
  95. DMA_DeInit(DMA1_Channel1); //将DMA的通道1寄存器重设为缺省值
  96. DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR; //DMA外设ADC基地址
  97. DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; //DMA内存基地址
  98. DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //内存作为数据传输的目的地
  99. DMA_InitStructure.DMA_BufferSize = N*M; //DMA通道的DMA缓存的大小
  100. DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
  101. DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
  102. DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //数据宽度为16位
  103. DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //数据宽度为16位
  104. DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循环缓存模式
  105. DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x拥有高优先级
  106. DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输
  107. DMA_Init(DMA1_Channel1, &DMA_InitStructure); //根据DMA_InitStruct中指定的参数初始化DMA的通道
  108. }
  109. //配置所有外设
  110. void Init_All_Periph(void)
  111. {
  112. RCC_Configuration();
  113. GPIO_Configuration();
  114. ADC1_Configuration();
  115. DMA_Configuration();
  116. //USART1_Configuration();
  117. USART_Configuration(9600);
  118. }
  119. u16 GetVolt(u16 advalue)
  120. {
  121. return (u16)(advalue * 330 / 4096); //求的结果扩大了100倍,方便下面求出小数
  122. }
  123. void filter(void)
  124. {
  125. int sum = 0;
  126. u8 count;
  127. for(i=0;i<12;i++)
  128. {
  129. for ( count=0;count<N;count++)
  130. {
  131. sum += AD_Value[count][i];
  132. }
  133. After_filter[i]=sum/N;
  134. sum=0;
  135. }
  136. }
  137. int main(void)
  138. {
  139. u16 value[M];
  140. init_All_Periph();
  141. SysTick_Initaize();
  142. ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  143. DMA_Cmd(DMA1_Channel1, ENABLE); //启动DMA通道
  144. while(1)
  145. {
  146. while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待传输完成否则第一位数据容易丢失
  147. filter();
  148. for(i=0;i<12;i++)
  149. {
  150. value[i]= GetVolt(After_filter[i]);
  151. printf("value[%d]:\t%d.%dv\n",i,value[i]/100,value[i]0) ;
  152. delay_ms(100);
  153. }
  154. }
  155. }
收藏收藏1 分享淘帖 顶 踩
ID:192685 发表于 2018-10-17 18:47 | 只看该作者
复制后出现这条错误该怎么解决,请问"eval.h"这个头文件里放的是什么内容
ID:480842 发表于 2019-9-9 08:27 | 只看该作者
