#include<reg52.h>
uchar code table[]=
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
uchar info[32];
uint temp,num=0,flag=0;
uchar keyscany();
void init();
void delay(uchar i)
uchar j,k;
for(j=i;j>0;j--)
for(k=125;k>0;k--);
init();
info[num]=keyscany();
if(flag>0)
while(flag==0);
SBUF=info[num];
num++;
if(num==32) break;
num=0;
void init()
TMOD=0X20;
TH1=0XFD;
TL1=0XFD;
TR1=1;
SM0=0;
SM1=1;
REN=1;
ES=1;
EA=1;
uchar keyscany()
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch (temp)
case(0xee):num=0;break;
case(0xde):num=1;break;
case(0xbe):num=2;break;
case(0x7e):num=3;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfd;//???
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch (temp)
case(0xed):num=4;break;
case(0xdd):num=5;break;
case(0xbd):num=6;break;
case(0x7d):num=7;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch (temp)
case(0xeb):num=8;break;
case(0xdb):num=9;break;
case(0xbb):num=10;break;
case(0x7b):num=11;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch (temp)
case(0xe7):num=12;break;
case(0xd7):num=13;break;
case(0xb7):num=14;break;
case(0x77):num=15;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
flag++;
return num;
void inter() interrupt 4
while(!TI);
TI=0;
