查看: 3831|回复: 1
16*16点阵显示汉字单片机源码
ID:209751 发表于 2017-6-10 10:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"reg51.h"
#define out0 P0
#define out1 P1
#define out2 P2
uchar code table[] = {0x00,0x08,0x7F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x08,0x7F,0xFC,
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x04,0xFF,0xFE,0x00,0x00,
                                         0x08,0x10,0x08,0x10,0x09,0x18,0xFF,0x94,0x08,0x10,0x09,0x14,0x7F,0xFE,0x55,0x10,
0x55,0x10,0x7F,0x10,0x49,0x28,0x7F,0x28,0x49,0x28,0x49,0x44,0x43,0x44,0x41,0x82,
                                         0x3F,0xF8,0x04,0x00,0x08,0x10,0x1F,0xF8,0x28,0x10,0x48,0x10,0x8F,0xF0,0x04,0x04,
0xFE,0xFE,0x10,0x20,0x20,0x44,0x7E,0xFE,0xA3,0x44,0x22,0x44,0x3E,0x7C,0x20,0x40,
uchar code str[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,};
uchar code table1[]={
0x08,0x20,0x08,0x24,0xFF,0xFE,0x08,0x20,0x20,0x40,0x7C,0x28,0x45,0xFC,0x44,0x88,
0x7C,0x50,0x43,0xFE,0x7C,0x20,0x44,0x28,0x45,0xFC,0x7C,0x20,0x40,0x20,0x00,0x20};
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=120;j>0;j--);
void delay(uint j)
  uchar i=250;
  for(;j>0;j--)
          while(--i);
        i=100;
   uint i,j,n;
  for(j=0;j<3;j++)
                   for(n=0;n<40;n++)
                        for(i=0;i<16;i++)
                        out1=str[i%16]; //选择行
                        out0=table[i*2+j*32];
                        out2=table[i*2+1+j*32];
                         delay(4);
                         out0=0x00;
                     out2=0x00;
ID:209751 发表于 2017-6-10 10:23 | 只看该作者
代码如下啊啊
proteus-LED16-16.zip
21.19 KB, 下载次数: 13, 下载积分: 黑币 -5
