查看: 3272|回复: 4
在学习4412开发板,可是呢?busybox编译不成功,大神有吗
ID:211790 发表于 2017-6-16 10:17 | 显示全部楼层 |阅读模式
busybox按照视频配置完成,输入make出错,编译不成功,具体错误如下,请问大神们如何解决
root@ubuntu:/home/minilinux/busybox-1.22.1# make
/home/minilinux/busybox-1.22.1/scripts/gcc-version.sh: line 11: arm-none-linux-gnueabi-gcc: command not found
  SPLIT   include/autoconf.h -> include/config/*
  GEN     include/bbconfigopts.h
  HOSTCC  applets/usage
applets/usage.c: In function ‘main’:
applets/usage.c:52: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
  GEN     include/usage_compressed.h
  HOSTCC  applets/applet_tables
applets/applet_tables.c: In function ‘main’:
applets/applet_tables.c:144: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
  GEN     include/applet_tables.h
  CC      applets/applets.o
/bin/sh: 1: arm-none-linux-gnueabi-gcc: not found
make[1]: *** [applets/applets.o] Error 127
make: *** [applets_dir] Error 2
ID:296970 发表于 2018-8-2 17:55 | 显示全部楼层
请问解决了吗?我也遇到了这个问题
ID:382539 发表于 2018-8-3 14:30 | 显示全部楼层
你的GCC编译器装的有问题吧
你的GCC工具装的有问题吧
ID:233795 发表于 2018-9-6 10:13 | 显示全部楼层
好多人在学习4412开发板
