查看: 2959|回复: 0
单片机定时器+软件延时,求解!
ID:184107 发表于 2017-6-18 17:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<AT89X51.H>
void scan_k1();
unsigned char set,flag1,flag2,flag3,flag4,flag5,flag6;
unsigned long aa;
sbit k1=P3^2;
sbit LED1=P2^5;
sbit LED2=P2^6;
sbit LED3=P2^7;
sbit G1=P2^0;
void TimerConfiguration()
    TMOD = 0x01; //选择工作方式1
    TH0 = 0x3C;         //设置初始值
    TL0 = 0xB0;
    EA = 1;                         //打开总中断
    ET0 = 1;                 //打开定时器0中断
    //TR0 = 1;                 //启动定时器0
void Timer0() interrupt 1
          TH0 = 0x3C;         //设置初始值
      TL0 = 0xB0;
          aa++;
                aa=0;
                scan_k1();
                TimerConfiguration();
                while(set==1)
                {                 TimerConfiguration();
                                 scan_k1();
                                                if(set==1)
                                                        if(aa==36000)//aa设置12000(10分钟)可以定时,36000就不可以??求解!
        if(flag1==1)
        G1=1;
        TR0 =0;
        flag1=1;
        LED1=0;
        LED2=1;
        LED3=1;
        G1=0;
        TR0 =1;
                while(set==2)
                                 scan_k1();
                                                if(set==2)
                                                        if(aa==144000)
        if(flag2==1)
        G1=1;
        TR0 =0;
        flag2=1;
        LED1=1;
        LED2=0;
        LED3=1;
        G1=0;
        TR0 =1;
                while(set==3)
                                 scan_k1();
                                                if(set==3)
                                                        if(aa==72000*3)
        if(flag3==1)
        G1=1;
        TR0 =0;
        flag3=1;
        LED1=1;
        LED2=1;
        LED3=0;
        G1=0;
        TR0 =1;
                while(set==4)
                                 scan_k1();
                                                if(set==4)
                                                        if(aa==72000*4)
        if(flag4==1)
        G1=1;
        TR0 =0;
        flag4=1;
        LED1=0;
        LED2=1;
        LED3=0;
        G1=0;
        TR0 =1;
                while(set==5)
                                 scan_k1();
                                                if(set==5)
                                                        if(aa==72000*5)
        if(flag5==1)
        G1=1;
        TR0 =0;
        flag5=1;
        LED1=1;
        LED2=0;
        LED3=0;
        G1=0;
        TR0 =1;
                while(set==6)
                                 scan_k1();
                                                if(set==6)
                                                        if(aa==72000*6)
        if(flag6==1)
        G1=1;
        TR0 =0;
        flag6=1;
        LED1=0;
        LED2=0;
        LED3=0;
        G1=0;
        TR0 =1;
                while(set==0)
                                scan_k1();
                                LED1=1;
                                LED2=1;
                                LED3=1;
                                G1=1;
                                TR0 =0;
                                //initial();
/*void Delay10ms(unsigned long c)   //误差 0us
            unsigned char a,b;
            for(;c>0;c--)
                for(b=38;b>0;b--)
                    for(a=130;a>0;a--);
void scan_k1()
                unsigned int i;
                if(k1==0)set++;
                if(set==7) set=0;
                F0:if(k1==0) goto F0;
                for(i=0;i<20000;i++);
                //aa=0;
