查看: 3508|回复: 0
ADNS_3080鼠标传感器驱动代码
ID:212906 发表于 2017-6-20 14:32 | 显示全部楼层 |阅读模式
#include "ANDS3080.h"
#include "spi.h"
#include "usart.h"
#include "srom.h"
#include "delay.h"
#define H  200 //oáÃ×
u8 success,revision;
#define ANDS_NOP_H()    GPIO_SetBits(GPIOA, GPIO_Pin_12)
#define ANDS_NOP_L()    GPIO_ResetBits(GPIOA, GPIO_Pin_12)
#define ANDS_RESET_H()  GPIO_SetBits(GPIOA, GPIO_Pin_8)
#define ANDS_RESET_L()  GPIO_ResetBits(GPIOA, GPIO_Pin_8)
#define ANDS_NCS_H()    GPIO_SetBits(GPIOB, GPIO_Pin_12)
#define ANDS_NCS_L()    GPIO_ResetBits(GPIOB, GPIO_Pin_12)
Nop ---A12
reset--A8
NCS----B12
MOSI---PA7
MISO---PA6
SCLK---PA5
oˉêyÔ-Dí£ovoid ADNS_3080_GPIO_Configuration(void)
1|Äü£oμ÷óøÃoˉêyÔò½øDDANDS3080ËùóÃIO¿ú½øDD3õê¼»ˉ Nop ËˉÃßÏà1Ø¡¢Ncs Ƭѡ¡¢Reset ¸′λ
êäèë£o
êä3ö£o
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8| GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP; //íÆíìêä3ö
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
          ANDS_NCS_H();
oˉêyÔ-Dí£ovoid ADNS3080_reset(void)
1|Äü£oμ÷óøÃoˉêyÔò½øDDANDS3080½øDD¸′λ2ù×÷
êäèë£o
êä3ö£o
void ADNS3080_reset(void)  //ADNS3080 ¸′루¸ß£©
    ANDS_RESET_L();
    delay_ms(5);
    ANDS_RESET_H();
    delay_ms(5);
    ANDS_RESET_L();//Âö3åDÅoÅ
oˉêyÔ-Dí£ovoid Write_srom(void)
1|Äü£oANDS3080í»·¢D′Ä£ê½
êäèë£o
êä3ö£o
    int i;
    ANDS_NCS_L(); //à-μíƬѡ£¬¿aê¼′«êä
    writr_register(0x20,0x44);
    delay_us(51);
    writr_register(0x23,0x07);
    delay_us(51);
    writr_register(0x24,0x88);
    delay_us(51);
    ANDS_NCS_H();  //à-¸ßƬѡ£¬í£Ö1′«êä
    delay_us(340);//μè′y′óóú1Ö¡ê±¼ä
    writr_register(SROM_Enable,0x18);
    delay_us(41);//  >40us
    for(i=0;i<=1985;i++)
         writr_register(0x60,SROM[i]);
         delay_us(11);// >10us
    //OFF_CS();
    delay_us(105);//>104us
oˉêyÔ-Dí£ovoid ADNS3080_Init(void)
1|Äü£oμ÷óøÃoˉêyÔò½øDDANDS3080×üμÄ3õê¼»ˉ
êäèë£o
êä3ö£o
    ADNS_3080_GPIO_Configuration();
    ADNS3080_reset(); //¸′λ
    ANDS_NOP_H();  //à-¸ßNOP,ÃaËˉÃß
    delay_ms(10);
    Write_srom();
    ADNS_Configuration();
    revision=read_register(0x01);
   // printf("revision = %x\n",revision);
    success=read_register(0x1f); //2é¿′êÇ·ñÏÂÔØ3é1|
   // printf("success = %x\n",success);
oˉêyÔ-Dí£ovoid ADNS_Configuration(void)
1|Äü£oμ÷óøÃoˉêyÔò½øDDANDS3080ÅäÖÃ
êäèë£o
êä3ö£o
    ANDS_NCS_L();
    writr_register(Configuration_bits,0x10);//éèÖ÷ֱæÂê 1600 //èôBit 4Îa0£¬ÔòÎa400μãÿó¢′ç
    delay_ms(3);
    writr_register(Extended_Config,0x01);
    delay_ms(3);
    if(read_busy()!=1)
        //éèÎa3000֡ÿÃë
        ANDS_NCS_H();  //í»·¢_D′Ä£ê½
        delay_ms(2);
        ANDS_NCS_L();
        Spi1_SendReceive(Frame_Period_Max_Bound_Lower+0x80);//éèÖÃÖ¡Âê //ÏèD′μíλÔùD′¸ßλ
        Spi1_SendReceive(0xe0); // 0x40  C0 5000Ö¡Âê
        Spi1_SendReceive(Frame_Period_Max_Bound_Upper+0x80);
        Spi1_SendReceive(0x1a); //0x1f 12
    clear_motion();
    ANDS_NCS_H();
oˉêyÔ-Dí£ou8 read_register(u8 adress)
1|Äü£oμ÷óøÃoˉêyÔò½øDDANDS3080Ö¸¶¨μØÖ·¶áè¡
êäèë£o
êä3ö£o
    u8 temp;
    ANDS_NCS_L();//Ƭѡê1Äü£¬×üÏßÑ¡ÖDANDS3080
    temp=Spi1_SendReceive(adress+0x00);//¶á
    delay_us(75);
    temp=Spi1_SendReceive(0xff);//ìá1©ê±ÖóDÅoÅ_¶á
    ANDS_NCS_H();//Ƭѡí£Ö1ê1Äü£¬ANDS3080àëÏß
    return temp;
êäèë£o
êä3ö£o
void writr_register(u8 adress,u8 vlue)
    ANDS_NCS_L();
    Spi1_SendReceive(adress+0x80);
    Spi1_SendReceive(vlue);
    ANDS_NCS_H();
    delay_us(51);
êäèë£o
êä3ö£o
u8 read_busy(void)//D′Ö¡ÂêμÄÅDÃ|  ==1Ã|
    u8 temp;
    ANDS_NCS_L();
    temp=Spi1_SendReceive(Extended_Config+0x00);
    delay_us(75);
    temp&=0x80;
    ANDS_NCS_H();
    return temp;
êäèë£o
êä3ö£o
void clear_motion(void)
    ANDS_NCS_L();
    Spi1_SendReceive(Motion_Clear+0x80);
    Spi1_SendReceive(0xff);//Çå3yX Yêy¾Y
    ANDS_NCS_H();
oˉêyÔ-Dí£ovoid Get_Move(int move[2])
êäèë£omoveêy×飬move[0]ÎaXÖáμÄËù¶è£¬move[1]ÎaYÖáμÄËù¶è
êä3ö£o
    unsigned char flag=0;
    move[0] = 0;
    move[1] = 0;
                Spi1_SendReceive(0x50);
                delay_us(75);
                flag=Spi1_SendReceive(0xFF); //òç3ö±ê־λ
                move[0]=Spi1_SendReceive(0xFF);  //¶áè¡XÖáμÄËù¶è
                move[1]=Spi1_SendReceive(0xFF);  //¶áè¡YÖáμÄËù¶è
                if(move[0]&0x80)
                                //21Âë×a»»
                                move[0]-=256;
                if(move[1]&0x80)
                                //21Âë×a»»
                                move[1]-=256;
                ANDS_NCS_H();
                delay_us(4);
                ANDS_NCS_H();
                if((flag&0x10)!=1)//êÇ·ñòç3ö
                                if(flag&0x80) //ûóDòç3öÔò′òó¡
                                                //printf("x=%d,y=%d\n",SumX,SumY);
                                else          //òç3öÔò½«x¡¢yÖáËù¶èÇåáã
                                                move[0]=0;
                                                move[1]=0;
                                flag = 0;
                        //        delay_ms(10);
