查看: 3926|回复: 2
关于NRF24L01的问题
ID:146960 发表于 2017-7-2 11:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在两块开发板上,用NRF24L01通信实现按下一块开发板上的按键,另一块开发版上的小灯亮
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "lcd.h"
#include "usart.h"
#include "24l01.h"
int main(void)
        u8 key,mode;
        u16 t=0;
        u8 tmp_buf[33];
        delay_init();                     //延时函数初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
        uart_init(115200);                 //串口初始化为115200
        LED_Init();                                          //初始化与LED连接的硬件接口
        KEY_Init();                                        //初始化按键
        LCD_Init();                                           //初始化LCD
        NRF24L01_Init();                    //初始化NRF24L01
        POINT_COLOR=RED;                        //设置字体为红色
        LCD_ShowString(30,50,200,16,16,"ELITE STM32");
        LCD_ShowString(30,70,200,16,16,"NRF24L01 TEST");
        LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(30,110,200,16,16,"2015/1/17");
        while(NRF24L01_Check())
                LCD_ShowString(30,130,200,16,16,"NRF24L01 Error");
                delay_ms(200);
                LCD_Fill(30,130,239,130+16,WHITE);
                delay_ms(200);
                LED0=1;
        LCD_ShowString(30,130,200,16,16,"NRF24L01 OK"); //检测24L01是否存在
                key=KEY_Scan(0);
                if(key==KEY0_PRES)
                        mode=0;
                        break;
                }else if(key==KEY1_PRES)
                        mode=1;
                        break;
                t++;
                if(t==100)LCD_ShowString(10,150,230,16,16,"KEY0:RX_Mode  KEY1:TX_Mode"); //闪烁显示提示信息
                if(t==200)
                        LCD_Fill(10,150,230,150+16,WHITE);
                        t=0;
                delay_ms(5);
        LCD_Fill(10,150,240,166,WHITE);//清空上面的显示
        POINT_COLOR=BLUE;//设置字体为蓝色
        if(mode==0)//RX模式
                LCD_ShowString(30,150,200,16,16,"NRF24L01 RX_Mode");
                LCD_ShowString(30,170,200,16,16,"Received DATA:");
                NRF24L01_RX_Mode();
                        if(NRF24L01_RxPacket(tmp_buf)==0)//一旦接收到信息,则显示出来.
                                tmp_buf[32]=0;//加入字符串结束符
                                LCD_ShowString(0,190,lcddev.width-1,32,16,tmp_buf);
                        }else delay_us(100);
                        t++;
                        if(t==10000)//大约1s钟改变一次状态
                                t=0;
                                LED0=!LED0;
        }else//TX模式
                LCD_ShowString(30,150,200,16,16,"NRF24L01 TX_Mode");
                NRF24L01_TX_Mode();
                mode=' ';//从空格键开始
                        if(NRF24L01_TxPacket(tmp_buf)==TX_OK)
                                LCD_ShowString(30,170,239,32,16,"Sended DATA:");
                                key=mode;
                                for(t=0;t<32;t++)
                                        key++;
                                        if(key>('~'))key=' ';
                                        tmp_buf[t]=key;
                                mode++;
                                if(mode>'~')mode=' ';
                                tmp_buf[32]=0;//加入结束符
                        }else
                                LCD_Fill(0,170,lcddev.width,170+16*3,WHITE);//清空显示
                                LCD_ShowString(30,170,lcddev.width-1,32,16,"Send Failed ");
                        LED0=!LED0;
                        delay_ms(1500);
这是列程,我该改哪些部分?
ID:82765 发表于 2017-7-2 12:50 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:146960 发表于 2017-7-2 15:00 | 只看该作者
cjjcjj1 发表于 2017-7-2 12:50
你好!你程序发的不完整,缺少主要的头文件
#include "24l01.h"
#include "lcd.h"
#include "delay.h"
#include "spi.h"
#include "usart.h"
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};
//初始化24L01的IO口
void NRF24L01_Init(void)
        GPIO_InitTypeDef GPIO_InitStructure;
  SPI_InitTypeDef  SPI_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOG, ENABLE);         //使能PB,G端口时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;                                 //PB12上拉 防止W25X的干扰
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);        //初始化指定IO
        GPIO_SetBits(GPIOB,GPIO_Pin_12);//上拉
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8;        //PG8 7 推挽
        GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化指定IO
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PG6 输入
        GPIO_ResetBits(GPIOG,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8);//PG6,7,8上拉
  SPI2_Init();                    //初始化SPI
        SPI_Cmd(SPI2, DISABLE); // SPI外设不使能
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //SPI设置为双线双向全双工
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //SPI主机
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //发送接收8位帧结构
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                //时钟悬空低
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;        //数据捕获于第1个时钟沿
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由软件控制
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;                //定义波特率预分频的值:波特率预分频值为16
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //数据传输从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
        SPI_Init(SPI2, &SPI_InitStructure);  //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
        SPI_Cmd(SPI2, ENABLE); //使能SPI外设
        NRF24L01_CE=0;                         //使能24L01
        NRF24L01_CSN=1;                        //SPI片选取消
//检测24L01是否存在
//返回值:0,成功;1,失败
u8 NRF24L01_Check(void)
        u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
        u8 i;
        SPI2_SetSpeed(SPI_BaudRatePrescaler_4); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz)
        NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址.
        NRF24L01_Read_Buf(TX_ADDR,buf,5); //读出写入的地址
        for(i=0;i<5;i++)if(buf!=0XA5)break;
        if(i!=5)return 1;//检测24L01错误
        return 0;                 //检测到24L01
//SPI写寄存器
//reg:指定寄存器地址
//value:写入的值
u8 NRF24L01_Write_Reg(u8 reg,u8 value)
        u8 status;
           NRF24L01_CSN=0;                 //使能SPI传输
          status =SPI2_ReadWriteByte(reg);//发送寄存器号
          SPI2_ReadWriteByte(value);      //写入寄存器的值
          NRF24L01_CSN=1;                 //禁止SPI传输
          return(status);                               //返回状态值
//读取SPI寄存器值
//reg:要读的寄存器
u8 NRF24L01_Read_Reg(u8 reg)
        u8 reg_val;
        NRF24L01_CSN = 0;          //使能SPI传输
          SPI2_ReadWriteByte(reg);   //发送寄存器号
          reg_val=SPI2_ReadWriteByte(0XFF);//读取寄存器内容
          NRF24L01_CSN = 1;          //禁止SPI传输
          return(reg_val);           //返回状态值
//在指定位置读出指定长度的数据
//reg:寄存器(位置)
//*pBuf:数据指针
//len:数据长度
//返回值,此次读到的状态寄存器值
u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len)
        u8 status,u8_ctr;
          status=SPI2_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值
        for(u8_ctr=0;u8_ctr<len;u8_ctr++)pBuf[u8_ctr]=SPI2_ReadWriteByte(0XFF);//读出数据
          NRF24L01_CSN=1;       //关闭SPI传输
          return status;        //返回读到的状态值
//在指定位置写指定长度的数据
//reg:寄存器(位置)
//*pBuf:数据指针
//len:数据长度
//返回值,此次读到的状态寄存器值
u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len)
        u8 status,u8_ctr;
          status = SPI2_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值
          for(u8_ctr=0; u8_ctr<len; u8_ctr++)SPI2_ReadWriteByte(*pBuf++); //写入数据
          NRF24L01_CSN = 1;       //关闭SPI传输
//启动NRF24L01发送一次数据
//txbuf:待发送数据首地址
//返回值:发送完成状况
u8 NRF24L01_TxPacket(u8 *txbuf)
        u8 sta;
        SPI2_SetSpeed(SPI_BaudRatePrescaler_8);//spi速度为9Mhz(24L01的最大SPI时钟为10Mhz)
        NRF24L01_CE=0;
          NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF  32个字节
        NRF24L01_CE=1;//启动发送
        while(NRF24L01_IRQ!=0);//等待发送完成
        sta=NRF24L01_Read_Reg(STATUS);  //读取状态寄存器的值
        NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志
        if(sta&MAX_TX)//达到最大重发次数
                NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
                return MAX_TX;
        if(sta&TX_OK)//发送完成
                return TX_OK;
        return 0xff;//其他原因发送失败
//启动NRF24L01发送一次数据
//txbuf:待发送数据首地址
//返回值:0,接收完成;其他,错误代码
u8 NRF24L01_RxPacket(u8 *rxbuf)
        u8 sta;
        SPI2_SetSpeed(SPI_BaudRatePrescaler_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz)
        if(sta&RX_OK)//接收到数据
                NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据
                NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
                return 0;
        return 1;//没收到任何数据
//该函数初始化NRF24L01到RX模式
//设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR
//当CE变高后,即进入RX模式,并可以接收数据了
void NRF24L01_RX_Mode(void)
        NRF24L01_CE=0;
          NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址
          NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01);    //使能通道0的自动应答
          NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40);             //设置RF通信频率
          NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//设置TX发射参数,0db增益,2Mbps,低噪声增益开启
          NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f);//配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式
          NRF24L01_CE = 1; //CE为高,进入接收模式
//该函数初始化NRF24L01到TX模式
//设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR
//PWR_UP,CRC使能
//CE为高大于10us,则启动发送.
void NRF24L01_TX_Mode(void)
        NRF24L01_CE=0;
          NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//写TX节点地址
          NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK
          NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
          NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40);       //设置RF通道为40
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);  //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
          NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e);    //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断
        NRF24L01_CE=1;//CE为高,10us后启动发送
,我主要是想实现目的,能移植成功够就行
