// PIC16F877A Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#include <stdio.h>
#include <stdlib.h>
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = OFF // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
* File: 蜂鸣器.c
* Author: Administrator
* Created on 2017年7月5日, 下午6:44
#define ucahr unsigned char
TRISD=0;
PORTD=0;
下面是编译的结果,看不懂这是什么意思。用的软件是“MPLAB X IDE V3.61”编译器是XC8
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
nbproject/Makefile-default.mk:105: *** missing separator. Stop.
make[1]: Entering directory 'F:/PIC��Ƭ��ѧϰ/������.X'
make: *** [.build-impl] Error 2
make[1]: Leaving directory 'F:/PIC��Ƭ��ѧϰ/������.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
编译已失败 (退出值2, 总时间: 140ms)
