这是一个LED16*16程序,我想让LED点阵移屏显示温度,*ss是定义的需要显示字符指针数组,问题出现在这个字符指针数组中的tempint_one,我想把它设定成指向显示一个温度数据的数组指针,这个指针最后指向谁完全由温度数据通过另一个tabnum指针数组控制,但是问题出现在ss在定义及初始化总是报错:main.c(55): error C247: non-address/-constant initializer ,问题现在出在tempint_one,但是现在该怎么初始化它才可以解决这个问题?相关代码及报错如下,程序未完成,不相关代码没上,勿怪!
PS:1、ss在函数外初始化也一样
2 在ss中去掉tempint_one就没有报错
----------------------------------------------------------字模定义文件------------------------------------------------------
#ifndef __FONT_H__
#define __FONT_H__
#include<basic.h>
// ------------------ 汉字字模的数据结构定义 ------------------------ //
uchr code tabspace[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchr code tabdong[]={0x22,0x00,0x22,0x80,0x2A,0xA0,0xAA,0xAF,0xAA,0xAA,0xAF,0xAA,0xAA,0xAA,0xFA,0xFF,
0xAA,0xAA,0xAF,0xAA,0xAA,0xAA,0xEA,0xAF,0xAA,0xA0,0x23,0x80,0x22,0x00,0x00,0x00};
uchr code tabli[]={0x40,0x00,0x44,0x10,0x44,0x08,0x44,0x06,0xC4,0x01,0xFE,0xFF,0x42,0x01,0x63,0x02,
0x42,0x06,0x00,0x00,0xF8,0x0F,0x00,0x40,0x00,0x80,0xFF,0x7F,0x00,0x00,0x00,0x00};
uchr code tabqiang[]={0x02,0x20,0xE2,0x43,0x22,0x82,0x22,0x42,0x7F,0x3E,0x02,0x00,0x80,0x4F,0xBE,0x44,
0x92,0x44,0x92,0x44,0xF2,0x7F,0x92,0x44,0x92,0x44,0xBF,0x64,0x82,0xCF,0x00,0x00};
uchr code tabqiang1[]={0x02,0x20,0xE2,0x43,0x22,0x82,0x22,0x42,0x7F,0x3E,0x02,0x00,0x80,0x4F,0xBE,0x44};
uchr code tab0[]={0xF8,0x07,0xFC,0x0F,0x04,0x09,0xC4,0x08,0x24,0x08,0xFC,0x0F,0xF8,0x07,0x00,0x00}; // -0-
uchr code tab1[]={0x00,0x00,0x10,0x08,0x18,0x08,0xFC,0x0F,0xFC,0x0F,0x00,0x08,0x00,0x08,0x00,0x00};// -1-
uchr code tab2[]={0x08,0x0E,0x0C,0x0F,0x84,0x09,0xC4,0x08,0x64,0x08,0x3C,0x0C,0x18,0x0C,0x00,0x00}; // -2-
uchr code tab3[]={0x08,0x04,0x0C,0x0C,0x44,0x08,0x44,0x08,0x44,0x08,0xFC,0x0F,0xB8,0x07,0x00,0x00}; // -3-
uchr code tab4[]={0xC0,0x00,0xE0,0x00,0xB0,0x00,0x98,0x08,0xFC,0x0F,0xFC,0x0F,0x80,0x08,0x00,0x00}; // -4-
uchr code tab5[]={0x7C,0x04,0x7C,0x0C,0x44,0x08,0x44,0x08,0xC4,0x08,0xC4,0x0F,0x84,0x07,0x00,0x00}; // -5-
uchr code tab6[]={0xF0,0x07,0xF8,0x0F,0x4C,0x08,0x44,0x08,0x44,0x08,0xC0,0x0F,0x80,0x07,0x00,0x00}; // -6-
uchr code tab7[]={0x0C,0x00,0x0C,0x00,0x04,0x0F,0x84,0x0F,0xC4,0x00,0x7C,0x00,0x3C,0x00,0x00,0x00}; // -7-
uchr code tab8[]={0xB8,0x07,0xFC,0x0F,0x44,0x08,0x44,0x08,0x44,0x08,0xFC,0x0F,0xB8,0x07,0x00,0x00}; // -8-
uchr code tab9[]={0x38,0x00,0x7C,0x08,0x44,0x08,0x44,0x08,0x44,0x0C,0xFC,0x07,0xF8,0x03,0x00,0x00}; // -9-
uchr code tab10[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00}; // .
uchr code tab11[]={0x30,0x0C,0x30,0x06,0x00,0x03,0x80,0x01,0xC0,0x00,0x60,0x0C,0x30,0x0C,0x00,0x00}; // -%- .
uchr code tab12[]={0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x06,0x30,0x06,0x00,0x00,0x00,0x00,0x00,0x00}; // :
uchr code tab13_0[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}; //空白
uchr code tab13_1[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
//温
uchr code tab14_0[]={0x10,0x04,0x22,0x04,0x64,0xFE,0x0C,0x01,0x80,0x40,0x00,0x7E,0xFE,0x42,0x92,0x42};
uchr code tab14_1[]={0x92,0x7E,0x92,0x42,0x92,0x7E,0x92,0x42,0xFF,0x42,0x02,0x7E,0x00,0x40,0x00,0x00};
//湿
uchr code tab15_0[]={0x10,0x04,0x22,0x04,0x64,0xFE,0x0C,0x41,0x80,0x44,0xFE,0x48,0x92,0x50,0x92,0x7F};
uchr code tab15_1[]={0x92,0x40,0x92,0x40,0x92,0x7F,0x92,0x50,0xFF,0x48,0x02,0x64,0x00,0x40,0x00,0x00};
//度
uchr code tab16_0[]={0x00,0x40,0x00,0x20,0xFC,0x9F,0x24,0x80,0x24,0x42,0x24,0x42,0xFC,0x26,0xA5,0x2A};
uchr code tab16_1[]={0xA6,0x12,0xA4,0x2A,0xFC,0x26,0x24,0x42,0x34,0x40,0x26,0xC0,0x04,0x40,0x00,0x00};
//现
uchr code tab17_0[]={0x04,0x10,0x84,0x30,0x84,0x10,0xFC,0x1F,0x86,0x88,0x84,0x88,0x00,0x40,0xFE,0x23};
uchr code tab17_1[]={0x02,0x18,0x82,0x07,0x7A,0x78,0x02,0x80,0xFF,0x83,0x02,0x80,0x00,0xE0,0x00,0x00};
//在
uchr code tab18_0[]={0x08,0x08,0x08,0x04,0x08,0x02,0x08,0xFF,0xC8,0x00,0x38,0x40,0x0F,0x41,0x08,0x41};
uchr code tab18_1[]={0x08,0x41,0xE8,0x7F,0x08,0x41,0x88,0x41,0x08,0x41,0x0C,0x60,0x08,0x40,0x00,0x00};
//时
uchr code tab19_0[]={0x00,0x00,0xFC,0x3F,0x84,0x10,0x84,0x10,0x84,0x10,0xFE,0x3F,0x14,0x00,0x10,0x00};
uchr code tab19_1[]={0x90,0x00,0x10,0x23,0x10,0x40,0x10,0x80,0xFF,0x7F,0x10,0x00,0x10,0x00,0x00,0x00};
//刻
uchr code tab20_0[]={0x08,0x40,0x88,0x48,0x88,0x48,0xC8,0x28,0xA9,0x24,0x9E,0x12,0x88,0x19,0x88,0x24};
uchr code tab20_1[]={0x6C,0x62,0x08,0x00,0xE0,0x0F,0x00,0x40,0x00,0x80,0xFF,0x7F,0x00,0x00,0x00,0x00};
#endif
-------------------------------------主文件-----------------------------
#include"basic.h"
#include"154_Drive.h"
#include"595_Drive.h"
#include"Font.h"
uchr l;
uchr i;
uchr j;
loat tep=12.5;
float hum=88.5;
uchr temp[16]={0};
uchr *tabnum[10]={tab0,tab1,tab2,tab3,tab4,tab5,tab6,tab7,tab8,tab9};
uchr (*tempint_one)[16]=&tab0;
//uchr i,j,k,l=0;
uchr *ss[]={tab13_0,tab13_1,tab17_0,tab17_1,tab18_0,tab18_1,tab19_0,tab19_1,
tab20_0,tab20_1,tab12,tab14_0,tab14_1,tab16_0,tab16_1,tab12,tab13_0,tab13_1,
tempint_one};
uchr a,b;
HC154_Init();
HC595_Init();
for(i=0;i<16;i++)
a=*(ss[(l+i)/8]+(((l+i)%8) *2));
b=*(ss[(l+i)/8]+(((l+i)%8)*2)+1);
HC154_G=1;
HC154_Oput_IO(i);
HC595_Writedata(b,a);
HC154_G=0;
j++;
if(j==200)
j=0;
l++;
l=(l>128)?0:l;
报错代码如下:
Rebuild target 'Target 1'
compiling 154_Drive.c...
compiling 595_Drive.c...
compiling main.c...
Target not created.
Build Time Elapsed: 00:00:01
