#include<reg51.h>
#define SCANPORT P1
sbit spk=P3^0;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f,
0x77,0x7c,0x39,0x5e,0x79,
0x71};
uchar uca_LineScan[4]={0xEF,0xDF,0xBF,0x7F};
uchar ucKeyScan()
uchar Temp=0;
uchar ucRow=0,ucLine=0;
for(ucLine=0;ucLine<4;ucLine++)
SCANPORT=uca_LineScan[ucLine];
Temp=SCANPORT & 0x0F;
if(Temp!=0x0F)
switch(Temp)
case 0x0E: ucRow=10;break;
case 0x0D: ucRow=20;break;
case 0x0B: ucRow=30;break;
case 0x07: ucRow=40;break;
default: ucRow=50;break;
break;
SCANPORT=0x0F;
return ucRow+ucLine+1;
void vKeyProcess(unsigned char ucKeyCode)
switch(ucKeyCode)
case 11:P0=table[0];spk=1;break; //'7'
case 12:P0=table[1];spk=1;break; //'8'
case 13:P0=table[2];spk=1;break;
case 14:P0=table[3];spk=1;break;
case 21:P0=table[4];spk=1;break; //'4'
case 22:P0=table[5];spk=1;break; //'5'
case 23:P0=table[6];spk=1;break;
case 24:P0=table[7];spk=1;break;
case 31:P0=table[8];spk=1;break; //'1'
case 32:P0=table[9];spk=1;break; //'2'
case 33:P0=table[10];spk=1;break;
case 34:P0=table[11];spk=1;break;
case 41:P0=table[12];spk=1;break; //'3'
case 42:P0=table[13];spk=1;break;
case 43:P0=table[14];spk=1;break; //'0'
case 44:P0=table[15];spk=1;break; //'+'
default:break;
spk=0;
P0=0;
vKeyProcess(ucKeyScan());
spk=0;
