#include <reg52.h>
sbit KEY_IN_1 = P2^4; //矩阵按键的扫描输入引脚1 sbit KEY_IN_2 = P2^5; //矩阵按键的扫描输入引脚2 sbit KEY_IN_3 = P2^6; //矩阵按键的扫描输入引脚3 sbit KEY_IN_4 = P2^7; //矩阵按键的扫描输入引脚4 sbit KEY_OUT_1 = P2^3; //矩阵按键的扫描输出引脚1 sbit KEY_OUT_2 = P2^2; //矩阵按键的扫描输出引脚2 sbit KEY_OUT_3 = P2^1; //矩阵按键的扫描输出引脚3 sbit KEY_OUT_4 = P2^0; //矩阵按键的扫描输出引脚4 sbit ADDR0 = P1^0; sbit ADDR1 = P1^1; sbit ADDR2 = P1^2; sbit ADDR3 = P1^3; sbit ENLED = P1^4;
unsigned char code LedChar[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8, 0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8e }; //数码管真值表
unsigned char KeySta[4][4] = { //全部矩阵按键的当前状态,默认都未按下 {1, 1, 1, 1}, //bit类型不能定义数组,因此定义成unsigned char {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1} };
void main(void) { unsigned char i, j; unsigned char backup[4][4] = { //按键值备份,保存前一次的值 {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1} };
//选择最右边的数码管进行显示 P0 = 0xFF; ADDR0 = 0; ADDR1 = 0; ADDR2 = 0; ADDR3 = 1; ENLED = 0;
//配置T0工作在模式1,定时1ms TMOD = 0x01; TH0 = 0xFC; TL0 = 0x67; TR0 = 1; ET0 = 1; EA = 1;
while(1) { //检索按键状态的变化 for (i=0; i<4; i++) //i作为行循环变量 { for (j=0; j<4; j++) //j作为列循环变量 { if (backup[j] != KeySta[j]) //判断按键动作 { if (backup[j] == 0) //判断按键弹起 { P0 = LedChar[i*4+j]; //执行按键动作 } backup[j] = KeySta[j]; //更新前一次的值 } } } } }
void InterruptTimer0() interrupt 1 { unsigned char i; static unsigned char keyout = 0; //矩阵按键扫描输出计数器 static unsigned char keybuf[4][4] = { //按键扫描缓冲区,保存一段时间内的扫描值 {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF} };
TH0 = 0xFC; //溢出后进入中断重新赋值 TL0 = 0x67; 按照我们的键盘扫描程序应该是中断1ms键值赋值一次并赋值 左移4次则keyout加1转下一列重新扫描16ms扫描完成。而此
程序我发现中断1ms虽然会有键值输入缓存但他会输入一次
keyout就增加一次达不到我们所涉及的效果吗。或许我分析的
不对,就请各位看一下
//将一行的4个按键值移入缓冲区 keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1; keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2; keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3; keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
//消抖后更新按键状态 for (i=0; i<4; i++) //每行4个按键,所以循环4次 { if ((keybuf[keyout] & 0x0F) == 0x00) { //连续4次扫描值为0,即16ms(4*4ms)内都只检测到按下状态时,可认为按键已按下 KeySta[keyout] = 0; } else if ((keybuf[keyout] & 0x0F) == 0x0F) { //连续4次扫描值为1,即16ms(4*4ms)内都只检测到弹起状态时,可认为按键已弹起 KeySta[keyout] = 1; } }
//执行下一次的扫描输出 keyout++; keyout &= 0x03; //用跟0x03做“与”的方式,实现加到4即归零,是不是很巧妙,学会它吧 switch (keyout) { case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break; case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break; case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break; case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break; default: break; } }
