查看: 2252|回复: 0
lcd1602.c文件
ID:184807 发表于 2017-7-31 22:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include <intrins.h>
#define INT8U  unsigned char
#define INT16U unsigned int
sbit RS = P1^0;        //寄存器选择线
sbit RW = P1^1;        //读/写控制线
sbit EN = P2^5;        //使能控制
// 延时
void delay_ms(INT16U ms)
    INT8U i; while(ms--) for(i = 0; i < 120; i++);
// 忙等待
void Busy_Wait()
    INT8U LCD_Status;                        //液晶状态字节变量
    do
         P0 = 0xFF;
        EN = 0;RS = 0;RW = 1;
        EN = 1;LCD_Status = P0;
        EN = 0;
    } while (LCD_Status & 0x80);            //液晶忙继续循环
// 写LCD命令
void Write_LCD_Command(INT8U cmd)
    Busy_Wait();
    EN = 0;RS = 0;RW = 0;
    P0 = cmd;
    EN = 1;_nop_();EN = 0;
// 发送数据
void Write_LCD_Data(INT8U dat)
    Busy_Wait();
    EN = 0;RS = 1;RW = 0;
    P0 = dat;
// LCD初始化
void Initialize_LCD()
    Write_LCD_Command(0x38); delay_ms(1);    //置功能,8位,双行,5*7
    Write_LCD_Command(0x01); delay_ms(1);    //清屏
    Write_LCD_Command(0x06); delay_ms(1);    //字符进入模式:屏幕不动,字符后移
    Write_LCD_Command(0x0C); delay_ms(1);    //显示开,关光标
// 在指定位置显示字符串
void LCD_ShowString(INT8U r, INT8U c,INT8U *str)
    INT8U i = 0;
    code INT8U DDRAM[] = {0x80,0xC0};        //1602LCD两行的起始DDRAM地址
    Write_LCD_Command(DDRAM[r] | c);        //设置显示起始位置
    for ( i = 0; str[i] && i < 16 ;i++)        //输出字符串
      Write_LCD_Data(str[i]);
    for (; i < 16; i++)                         //不足一行时用空格填充
      Write_LCD_Data(' ');
