NRF24L01无线温度监控的上位机界面:
NRF24L01无线测温源程序:
- #include <reg52.h>
- #include <intrins.h>
- typedef unsigned char uchar;
- typedef unsigned char uint;
- //****************************************NRF24L01端口定义***************************************
- sbit MISO =P1^3;
- sbit MOSI =P1^4;
- sbit SCK =P1^2;
- sbit CE =P1^1;
- sbit CSN =P3^2;
- sbit IRQ =P3^3;
- //************************************按键***************************************************
- sbit KEY1=P3^6;
- sbit KEY2=P3^7;
- //************************************数码管位选*********************************************
- sbit led3=P2^0;
- sbit led2=P2^1;
- sbit led1=P2^2;
- sbit led0=P2^3;
- //************************************蜂明器***************************************************
- sbit BELL=P3^4;
- //*****************************************DS1820端口设置****************************************
- sbit DQ=P3^5 ;
- //***********************************数码管0-9编码***********************************************
- uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码
- uchar seg1[10]={0x40,0x4F,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
- uchar data temp_data[2]={0x00,0x00}; //温度采集数据缓冲区
- uchar dispaly[7]; //显示缓冲区
- uint bdata sta; //NRF24L01状态标志
- sbit RX_DR =sta^6;
- sbit TX_DS =sta^5;
- sbit MAX_RT =sta^4;
- //*************************************NRF24L01**************************************************
- #define TX_ADR_WIDTH 5 // 本机地址宽度设置
- #define RX_ADR_WIDTH 5 // 接收方地址宽度设置
- #define TX_PLOAD_WIDTH 20 // 4 字节数据长度
- #define RX_PLOAD_WIDTH 20 // 4 字节数据长度
- uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址
- uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址
- //*****************************NRF24L01寄存器指令,详细请对照,Page18******************************
- #define READ_REG 0x00 // 读寄存器指令
- #define WRITE_REG 0x20 // 写寄存器指令
- #define RD_RX_PLOAD 0x61 // 读取接收数据指令
- #define WR_TX_PLOAD 0xA0 // 写待发数据指令
- #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令
- #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令
- #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令
- #define NOP 0xFF // 保留
- //****************************SPI(nRF24L01)寄存器地址,详细请对照,Page18-24**********************
- #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式
- #define EN_AA 0x01 // 自动应答功能设置
- #define EN_RXADDR 0x02 // 可用信道设置
- #define SETUP_AW 0x03 // 收发地址宽度设置
- #define SETUP_RETR 0x04 // 自动重发功能设置
- #define RF_CH 0x05 // 工作频率设置
- #define RF_SETUP 0x06 // 发射速率、功耗功能设置
- #define STATUS 0x07 // 状态寄存器
- #define OBSERVE_TX 0x08 // 发送监测功能
- #define CD 0x09 // 地址检测
- #define RX_ADDR_P0 0x0A // 频道0接收数据地址
- #define RX_ADDR_P1 0x0B // 频道1接收数据地址
- #define RX_ADDR_P2 0x0C // 频道2接收数据地址
- #define RX_ADDR_P3 0x0D // 频道3接收数据地址
- #define RX_ADDR_P4 0x0E // 频道4接收数据地址
- #define RX_ADDR_P5 0x0F // 频道5接收数据地址
- #define TX_ADDR 0x10 // 发送地址寄存器
- #define RX_PW_P0 0x11 // 接收频道0接收数据长度
- #define RX_PW_P1 0x12 // 接收频道0接收数据长度
- #define RX_PW_P2 0x13 // 接收频道0接收数据长度
- #define RX_PW_P3 0x14 // 接收频道0接收数据长度
- #define RX_PW_P4 0x15 // 接收频道0接收数据长度
- #define RX_PW_P5 0x16 // 接收频道0接收数据长度
- #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置
- //************************************NRF24L01函数申明**********************************************
- void Delay(unsigned int s);
- void inerDelay_us(unsigned char n);
- void init_NRF24L01(void);
- uint SPI_RW(uint uchar);
- uchar SPI_Read(uchar reg);
- void SetRX_Mode(void);
- uint SPI_RW_Reg(uchar reg, uchar value);
- uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars);
- uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars);
- unsigned char nRF24L01_RxPacket(unsigned char* rx_buf);
- void nRF24L01_TxPacket(unsigned char * tx_buf);
- //************************************DS18B20函数申明**********************************************
- void delay1(uint i);
- void ds_reset(void);
- void write_byte(uchar value);
- uchar read_byte(void);
- void read_temp();
- void work_temp();
- //*****************************************长延时*****************************************
- unsigned int i;
- for(i=0; i<s; i++);
- /*延时函数
- for(;n>0;n--)
- _nop_();
- /*NRF24L01初始化
- inerDelay_us(100);
- CE=0; // chip enable
- CSN=1; // Spi disable
- SCK=0; // Spi clock line init high
- SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21
- SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致
- SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为4字节
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1Mkbps,发射功率为最大值0dB
- /*函数:uint SPI_RW(uint uchar)
- /*功能:NRF24L01的SPI写时序,详细看时序图,Page19
- uint bit_ctr;
- for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit
- MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI
- uchar = (uchar << 1); // shift next bit into MSB..
- SCK = 1; // Set SCK high..
- uchar |= MISO; // capture current MISO bit
- SCK = 0; // ..then set SCK low again
- return(uchar); // return read uchar
- /*函数:uchar SPI_Read(uchar reg)
- /*功能:NRF24L01的SPI时序,详细看时序图,Page19
- uchar reg_val;
- CSN = 0; // CSN low, initialize SPI communication...
- SPI_RW(reg); // Select register to read from..
- reg_val = SPI_RW(0); // ..then read registervalue
- CSN = 1; // CSN high, terminate SPI communication
- return(reg_val); // return register value
- /*功能:NRF24L01读写寄存器函数,
- uint status;
- CSN = 0; // CSN low, init SPI transaction
- status = SPI_RW(reg); // select register
- SPI_RW(value); // ..and write value to it..
- CSN = 1; // CSN high again
- return(status); // return nRF24L01 status uchar
- /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
- /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数
- uint status,uchar_ctr;
- CSN = 0; // Set CSN low, init SPI tranaction
- status = SPI_RW(reg); // Select register to write to and read status uchar
- for(uchar_ctr=0;uchar_ctr<uchars;uchar_ctr++)
- pBuf[uchar_ctr] = SPI_RW(0); //
- CSN = 1;
- /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
- /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数
- CSN = 0; //SPI使能
- for(uchar_ctr=0; uchar_ctr<uchars; uchar_ctr++) //
- SPI_RW(*pBuf++);
- CSN = 1; //关闭SPI
- /*函数:void SetRX_Mode(void)
- /*功能:数据接收配置
- CE=0;
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收
- CE = 1;
- inerDelay_us(130);
- /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
- /*功能:数据读取后放如rx_buf接收缓冲区中
- unsigned char revale=0;
- sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况
- if(RX_DR) // 判断是否接收到数据
- CE = 0; //SPI使能
- SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
- revale =1; //读取数据完成标志
- SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
- return revale;
- /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf)
- /*功能:发送 tx_buf中数据
- CE=0; //StandBy I模式
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
- SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送
- CE=1; //置高CE,激发数据发送
- inerDelay_us(10);
- /*以下是DS18B20温度传感相关函数
- for(;i>0;i--);
- //****************************************************DS1820复位函数***************************************
- char temp=1;
- while(temp)
- while(temp)
- DQ=1;_nop_();_nop_();
- DQ=0;
- delay1(80);
- DQ=1;
- delay1(9);
- temp=DQ;
- delay1(64);
- temp=~DQ;
- DQ=1;
- //***********************************************DS1820写函数*********************************************
- uchar i;
- for(i=8;i>0;i--)
- DQ=0;_nop_();_nop_();_nop_();_nop_();_nop_();
- DQ=value&0x01;
- delay1(9);
- value>>=1;
- DQ=1;
- delay1(1);
- //****************************************************DS1820读函数*****************************************
- uchar i;
- uchar value1=0;
- for(i=8;i>0;i--)
- value1>>=1;
- DQ=0;
- _nop_();_nop_();_nop_();_nop_();
- DQ=1;
- if(DQ)
- value1|=0x80;
- delay1(9);
- DQ=1;
- return(value1);
- //****************************************************读取温度**********************************************
- void read_temp()
- ds_reset();
- write_byte(0xcc);
- write_byte(0xbe);
- temp_data[0]=read_byte();
- temp_data[1]=read_byte();
- ds_reset();
- write_byte(0xcc);
- write_byte(0x44);
- //****************************************************温度处理*********************************************
- void work_temp()
- uchar n=0;
- if(temp_data[1]>127)
- temp_data[1]=(256-temp_data[1]); //负值
- temp_data[0]=(256-temp_data[0]);
- n=1;
- dispaly[6]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4);
- dispaly[5]=dispaly[6]/100; //百位
- dispaly[4]=dispaly[6]%100; //
- dispaly[2]=dispaly[4]/10; //十位
- dispaly[1]=dispaly[4]%10; //个位
- switch (temp_data[0]&0x0f) //小数位
- case 0x0f:dispaly[0]=9;break;
- case 0x0e:dispaly[0]=9;break;
- case 0x0d:dispaly[0]=8;break;
- case 0x0c:dispaly[0]=8;break;
- case 0x0b:dispaly[0]=7;break;
- case 0x0a:dispaly[0]=6;break;
- case 0x09:dispaly[0]=6;break;
- case 0x08:dispaly[0]=5;break;
- case 0x07:dispaly[0]=4;break;
- case 0x06:dispaly[0]=4;break;
- case 0x05:dispaly[0]=3;break;
- case 0x04:dispaly[0]=3;break;
- case 0x03:dispaly[0]=2;break;
- case 0x02:dispaly[0]=1;break;
- case 0x01:dispaly[0]=1;break;
- case 0x00:dispaly[0]=1;break;
- default:break;
- if(n) //负值时显示aa,正直显示dd
- dispaly[3]=0x11; //
- else dispaly[3]=0x22;
- //****************************************************温度显示****************************************************
- void disdignit()
- P0=0xC6;
- led0=0;
- delay1(40);
- led0=1;
- P0=seg[dispaly[0]];
- led1=0;
- delay1(40);
- led1=1;
- P0=seg1 [dispaly[1]];
- led2=0;
- delay1(40);
- led2=1;
- P0=seg[ dispaly[2]];
- led3=0;
- delay1(40);
- led3=1;
- //************************************主函数************************************************************
- void main(void)
- uchar i=0;
- // uchar TxBuf[4]={0}; //4字节发送数据缓冲区
- init_NRF24L01() ; //NRF24L01初始化配置
- ds_reset();
- write_byte(0xcc);
- write_byte(0x44);
- Delay(6000);
- while(1)
- if(i==3)
- i=0;
- read_temp();
- work_temp();
- delay1(500);
- i++;
- disdignit();
- nRF24L01_TxPacket(dispaly); // Transmit Tx buffer data
- SPI_RW_Reg(WRITE_REG+STATUS,0XFF);
全部资料下载地址:
http://www.51hei.com/bbs/dpj-91589-1.html
