查看: 4256|回复: 1
带计分功能的8路抢答器单片机仿真电路和源代码
ID:210588 发表于 2017-8-8 08:41 | 显示全部楼层 |阅读模式
51单片机做的带有计分功能的8路抢答器proteus仿真电路工程文件和c51源代码
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit k0=P1^0;
  5. sbit k1=P1^1;
  6. sbit k2=P1^2;
  7. sbit k3=P1^3;
  8. sbit k4=P1^4;
  9. sbit k5=P1^5;
  10. sbit k6=P1^6;
  11. sbit k7=P1^7;
  12. sbit beep=P3^7;                                /*蜂鸣器*/
  13. sbit ks=P2^4;                                /*开始计时*/
  14. sbit jiayi=P2^5;                        /*分数加1*/
  15. sbit jianyi=P2^6;                        /*分数减1*/
  16. sbit fw=P2^7;                                /*复位*/
  17. int flg=1;
  18. bit flg1=0;
  19. int t=0,s=0;
  20. uchar qiangdanum=0x0b;
  21. uchar code table[]=
  22. {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x00};
  23. uchar ge=0,shi=0;
  24. uint num,time=10, fs=0;
  25. int nums[]={50,50,50,50,50,50,50,50};
  26. void kyy(void) ;
  27. void displayfs();
  28. void display();                         /*显示函数*/
  29. void kys();        /*设置按键函数*/
  30. void kys2();                                                        /*抢答按键函数*/
  31. void delay(unsigned int z)              /*延迟函数*/
  32. {
  33.     unsigned int x,y;
  34.     for(x=z;x>0;x--)
  35.       for(y=110;y>0;y--);
  36. }
  37. void intial()
  38. {
  39.     TMOD=0X01;                     /*采用方式一,即十六位计数器*/
  40.     TH0=(65536-50000)/256;         /*设置初始值,50ms中断一次*/
  41.     TL0=(65536-50000)%256;
  42.     EA=1;ET0=1;                 /*开启总中断源,定时器中断*/
  43. }
  44. void intia2()
  45. {        TMOD=0X10;                     /*采用方式一,即十六位计数器*/
  46.     TH1=(65536-50000)/256;         /*设置初始值,50ms中断一次*/
  47.     TL1=(65536-50000)%256;
  48.      EA=1;ET1=1;                 /*开启总中断源,定时器中断*/
  49.         }
  50. main()
  51. {        intia2();
  52.     intial();                                    /*初始化*/
  53.         beep=0;
  54.         while(1)
  55.         { kys();
  56.         if(flg1==1)
  57.             displayfs();
  58.                 else
  59.             display();                           /*显示函数*/
  60.
  61.                 if(flg==0)
  62.                 {
  63.                     kys2();
  64.                 }
  65.         }
  66. }
  67. void kys2()                                                        /*抢答按键函数*/
  68. {
  69.     if(k0==0)                               /*开关0按下*/
  70.     {
  71.             delay(5);
  72.         if(k0==0)
  73.         {        flg=1;
  74.                     qiangdanum=1;            /* 1号选手抢答成功,数码管显示1*/
  75.                         beep=1;
  76.                         delay(1000);
  77.                         beep=0;
  78.
  79.                         time=20;
  80.
  81.                 }
  82.      }
  83.     if(k1==0)                                /*开关1按下*/
  84.     {
  85.             delay(5);
  86.         if(k1==0)
  87.         {         flg=1;
  88.                     qiangdanum=2;                /* 2号选手抢答成功,数码管显示2*/
  89.                         beep=1;
  90.                         delay(1000);
  91.                         beep=0;
  92.                         time=20;
  93.
  94.                 }
  95.      }
  96.     if(k2==0)                                 /*开关2按下*/
  97.     {
  98.             delay(5);
  99.         if(k2==0)
  100.         {   flg=1;
  101.                     qiangdanum=3;                 /* 3号选手抢答成功,数码管显示3*/
  102.                         beep=1;
  103.                         delay(1000);
  104.                         beep=0;
  105.                     time=20;
  106.
  107.                 }
  108.      }
  109.     if(k3==0)                                 /*开关3按下*/
  110.     {
  111.             delay(5);
  112.         if(k3==0)
  113.         {   flg=1;
  114.                     qiangdanum=4;           /* 4号选手抢答成功,数码管显示4*/
  115.                     beep=1;
  116.                         delay(1000);
  117.                         beep=0;
  118.                 time=20;
  119.
  120.                 }
  121.      }
  122.     if(k4==0)                                 /*开关4按下*/
  123.     {
  124.             delay(5);
  125.         if(k4==0)
  126.         {          flg=1;
  127.                      qiangdanum=5;           /* 5号选手抢答成功,数码管显示5*/
  128.                          beep=1;
  129.                          delay(1000);
  130.                          beep=0;
  131.                          time=20;
  132.
  133.              }
  134.      }
  135.     if(k5==0)                                 /*开关5按下*/
  136.     {
  137.             delay(5);
  138.         if(k5==0)
  139.         {          flg=1;
  140.                      qiangdanum=6;           /* 6号选手抢答成功,数码管显示6*/
  141.                          beep=1;
  142.                          delay(1000);
  143.                           beep=0;
  144.                         time=20;
  145.
  146.                 }
  147.      }
  148.     if(k6==0)                                 /*开关6按下*/
  149.     {
  150.             delay(5);
  151.         if(k6==0)
  152.         {          flg=1;
  153.                      qiangdanum=7;          /* 7号选手抢答成功,数码管显示7*/
  154.                          beep=1;
  155.                          delay(1000);
  156.                          beep=0;
  157.                          time=20;
  158.
  159.                 }
  160.      }
  161.     if(k7==0)                                     /*开关7按下*/
  162.     {
  163.             delay(5);
  164.         if(k7==0)
  165.         {         flg=1;
  166.                      qiangdanum=8;          /* 8号选手抢答成功,数码管显示8*/
  167.                          beep=1;
  168.                          delay(1000);
  169.                          beep=0;
  170.                         time=20;
  171.
  172.                 }
  173.      }
  174. }
  175. void kys()                                                /*设置按键函数*/
  176. {
  177.    uchar i;
  178. if(qiangdanum==0x0a)                //复位按键按下后开始按键才有效
  179. {
  180.            if(ks==0)
  181.         {
  182.                 delay(5);
  183.             if(ks==0)
  184.                 {
  185.                    TR0=1;
  186.                 flg=0;
  187.                 }
  188.         }
  189. }
  190.             if((qiangdanum!=0x0a)&&(qiangdanum!=0x0b)&&(time!=0))         //在规定时间内或规定时间内答题结束后,分数加减按键才有效
  191.          {
  192.         if(jiayi==0)
  193.         {
  194.                 delay(5);
  195.                 if(jiayi==0)
  196.                   TR0=0;
  197.                   time=nums[qiangdanum-1];
  198.                   for (i=0;i<5;i++)
  199.                    {display();
  200.                   delay(250);
  201.                     delay(250);
  202.                    }
  203.
  204.                   fs=nums[qiangdanum-1];
  205.                   fs++;
  206.                   nums[qiangdanum-1]=fs;
  207.                   time=nums[qiangdanum-1];
  208.        // qiangdanum=0x0b;
  209.                 while(!jiayi);
  210.
  211.         }
  212.         if(jianyi==0)
  213.         {
  214.                 delay(5);
  215.                 if(jianyi==0)
  216.                    TR0=0;
  217.                     time=nums[qiangdanum-1];
  218.                     for (i=0;i<5;i++)
  219.                    {display();
  220.                   delay(250);
  221.                     delay(250);
  222.                    };
  223.                   fs=nums[qiangdanum-1];
  224.                   fs--;
  225.                   nums[qiangdanum-1]=fs;
  226.                   time=nums[qiangdanum-1];
  227.                 // qiangdanum=0x0b;
  228.                 while(!jianyi);
  229.         }
  230.         }
  231.         if(fw==0)                                                //复位按键
  232.         {
  233.                 delay(5);
  234.                 if(fw==0)
  235.                 {  flg=1;
  236.                TR0=0;
  237.                    time=10;
  238.                     flg1=1;
  239.                         s=0;
  240.                         TR1=1;
  241.
  242.                 }
  243.         }
  244. }
  245. void time0() interrupt 1                   /*1秒定时函数,采用方式1重装*/
  246. {
  247.     num++;
  248.     TH0=(65536-50000)/256;
  249.     TL0=(65536-50000)%256;
  250.     if(num==20)
  251.     {
  252.         num=0;
  253.         time--;
  254.         if(time==0)               //时间到,抢答无效
  255.         {
  256.                    TR0=0;
  257.                    flg=1;
  258.         }
  259.      }
  260.
  261. }
  262.
  263. void time1() interrupt 3
  264. {
  265.            t++;
  266.     TH1=(65536-50000)/256;
  267.     TL1=(65536-50000)%256;
  268.     if(t==200)
  269.     {   qiangdanum=0x0b;
  270.         t=0;
  271.         s++;
  272.         if(s==8)               //时间到,抢答无效
  273.                 {  s=0;
  274.                   TR1=0;
  275. ……………………
  276. …………限于本文篇幅 余下代码请从51黑下载附件…………
带计分功能的8路抢答器仿真电路和源代码分享.zip (218.9 KB, 下载次数: 99)
ID:89286 发表于 2017-8-26 16:11 | 显示全部楼层
thanks for sharing
