// 功能: 显示加速度计和陀螺仪的10位原始数据
// 显示:LCD1602
#include <STC12C5A60S2.H>
#include <math.h> //Keil library
#include <stdio.h> //Keil library
#include <INTRINS.H>
typedef unsigned char uchar;
typedef unsigned short ushort;
typedef unsigned int uint;
// 定义51单片机端口
#define DataPort P0 //LCD1602数据端口
sbit SCL=P2^1; //IIC时钟引脚定义
sbit SDA=P2^0; //IIC数据引脚定义
sbit LCM_RS=P2^6; //LCD1602命令端口
sbit LCM_RW=P2^5; //LCD1602命令端口
sbit LCM_EN=P2^7; //LCD1602命令端口
// 定义MPU6050内部地址
#define SMPLRT_DIV 0x19 //陀螺仪采样率,典型值:0x07(125Hz)
#define CONFIG 0x1A //低通滤波频率,典型值:0x06(5Hz)
#define GYRO_CONFIG 0x1B //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
#define ACCEL_CONFIG 0x1C //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define TEMP_OUT_H 0x41
#define TEMP_OUT_L 0x42
#define GYRO_XOUT_H 0x43
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
#define PWR_MGMT_1 0x6B //电源管理,典型值:0x00(正常启用)
#define WHO_AM_I 0x75 //IIC地址寄存器(默认数值0x68,只读)
#define SlaveAddress 0xD0 //IIC写入时的地址字节数据,+1为读取
//定义类型及变量
uchar dis[4]; //显示数字(-511至512)的字符数组
int dis_data; //变量
//int Temperature,Temp_h,Temp_l; //温度及高低位数据
//函数声明
void delay(unsigned int k); //延时
//LCD相关函数
void InitLcd(); //初始化lcd1602
void lcd_printf(uchar *s,int temp_data);
void WriteDataLCM(uchar dataW); //LCD数据
void WriteCommandLCM(uchar CMD,uchar Attribc); //LCD指令
void DisplayOneChar(uchar X,uchar Y,uchar DData); //显示一个字符
void DisplayListChar(uchar X,uchar Y,uchar *DData,L); //显示字符串
//MPU6050操作函数
void InitMPU6050(); //初始化MPU6050
void Delay5us();
void I2C_Start();
void I2C_Stop();
void I2C_SendACK(bit ack);
bit I2C_RecvACK();
void I2C_SendByte(uchar dat);
uchar I2C_RecvByte();
void I2C_ReadPage();
void I2C_WritePage();
void display_ACCEL_x();
void display_ACCEL_y();
void display_ACCEL_z();
uchar Single_ReadI2C(uchar REG_Address); //读取I2C数据
void Single_WriteI2C(uchar REG_Address,uchar REG_data); //向I2C写入数据
//整数转字符串
if(temp_data<0)
temp_data=-temp_data;
*s='-';
else *s=' ';
*++s =temp_data/100+0x30;
temp_data=temp_data%100; //取余运算
*++s =temp_data/10+0x30;
temp_data=temp_data%10; //取余运算
*++s =temp_data+0x30;
//延时
unsigned int i,j;
for(i=0;i<k;i++)
for(j=0;j<121;j++);
//LCD1602初始化
void InitLcd()
WriteCommandLCM(0x38,1);
WriteCommandLCM(0x08,1);
WriteCommandLCM(0x01,1);
WriteCommandLCM(0x06,1);
WriteCommandLCM(0x0c,1);
DisplayOneChar(0,0,'A');
DisplayOneChar(0,1,'G');
//LCD1602写允许
void WaitForEnable(void)
DataPort=0xff;
LCM_RS=0;LCM_RW=1;_nop_();
LCM_EN=1;_nop_();_nop_();
while(DataPort&0x80);
LCM_EN=0;
//LCD1602写入命令
if(Attribc)WaitForEnable();
LCM_RS=0;LCM_RW=0;_nop_();
DataPort=CMD;_nop_();
LCM_EN=1;_nop_();_nop_();LCM_EN=0;
//LCD1602写入数据
WaitForEnable();
LCM_RS=1;LCM_RW=0;_nop_();
DataPort=dataW;_nop_();
//LCD1602写入一个字符
Y&=1;
X&=15;
if(Y)X|=0x40;
X|=0x80;
WriteCommandLCM(X,0);
WriteDataLCM(DData);
//LCD1602显示字符串
uchar ListLength=0;
Y&=0x1;
X&=0xF;
while(L--)
DisplayOneChar(X,Y,DData[ListLength]);
ListLength++;
X++;
//延时5微秒(STC90C52RC@12M)
//不同的工作环境,需要调整此函数
//当改用1T的MCU时,请调整此延时函数
void Delay5us()
_nop_();_nop_();_nop_();_nop_();
//I2C起始信号
void I2C_Start()
SDA = 1; //拉高数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 0; //产生下降沿
Delay5us(); //延时
SCL = 0; //拉低时钟线
//I2C停止信号
void I2C_Stop()
SDA = 0; //拉低数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 1; //产生上升沿
Delay5us(); //延时
//I2C发送应答信号
//入口参数:ack (0:ACK 1:NAK)
SDA = ack; //写应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
//I2C接收应答信号
bit I2C_RecvACK()
SCL = 1; //拉高时钟线
Delay5us(); //延时
CY = SDA; //读应答信号
SCL = 0; //拉低时钟线
Delay5us(); //延时
return CY;
//向I2C总线发送一个字节数据
uchar i;
for (i=0; i<8; i++) //8位计数器
dat <<= 1; //移出数据的最高位
SDA = CY; //送数据口
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
I2C_RecvACK();
//从I2C总线接收一个字节数据
uchar i;
uchar dat = 0;
SDA = 1; //使能内部上拉,准备读取数据,
dat <<= 1;
SCL = 1; //拉高时钟线
Delay5us(); //延时
dat |= SDA; //读数据
SCL = 0; //拉低时钟线
Delay5us(); //延时
return dat;
//向I2C设备写入一个字节数据
I2C_Start(); //起始信号
I2C_SendByte(SlaveAddress); //发送设备地址+写信号
I2C_SendByte(REG_Address); //内部寄存器地址,
I2C_SendByte(REG_data); //内部寄存器数据,
I2C_Stop(); //发送停止信号
//从I2C设备读取一个字节数据
uchar REG_data;
I2C_Start(); //起始信号
I2C_SendByte(REG_Address); //发送存储单元地址,从0开始
I2C_Start(); //起始信号
I2C_SendByte(SlaveAddress+1); //发送设备地址+读信号
REG_data=I2C_RecvByte(); //读出寄存器数据
I2C_SendACK(1); //接收应答信号
I2C_Stop(); //停止信号
return REG_data;
//初始化MPU6050
void InitMPU6050()
Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠状态
Single_WriteI2C(SMPLRT_DIV, 0x07);
Single_WriteI2C(CONFIG, 0x06);
Single_WriteI2C(GYRO_CONFIG, 0x18);
Single_WriteI2C(ACCEL_CONFIG, 0x01);
//合成数据
int GetData(uchar REG_Address)
char H,L;
H=Single_ReadI2C(REG_Address);
L=Single_ReadI2C(REG_Address+1);
return (H<<8)+L; //合成数据
//在1602上显示10位数据
void Display10BitData(int value,uchar x,uchar y)
value/=64; //转换为10位数据
lcd_printf(dis, value); //转换数据显示
DisplayListChar(x,y,dis,4); //启始列,行,显示数组,显示长度
//主程序
delay(500); //上电延时
InitLcd(); //液晶初始化
delay(150);
Display10BitData(GetData(ACCEL_XOUT_H),2,0); //显示X轴加速度
Display10BitData(GetData(ACCEL_YOUT_H),7,0); //显示Y轴加速度
Display10BitData(GetData(ACCEL_ZOUT_H),12,0); //显示Z轴加速度
Display10BitData(GetData(GYRO_XOUT_H),2,1); //显示X轴角速度
Display10BitData(GetData(GYRO_YOUT_H),7,1); //显示Y轴角速度
Display10BitData(GetData(GYRO_ZOUT_H),12,1); //显示Z轴角速度
delay(500);
