#include<reg51.h>
#include<intrins.h>
sbit DS=P1^6;
uint temp;
unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
unsigned char code table1[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
void delay(uint count)
uint i;
while(count)
i=200;
while(i>0)
i--;
count--;
void delayms(uchar x)
uint i,j;
for(i=x;i>0;i--)
for(j=120;j>0;j--);
void delay10us(uchar t)
do
_nop_();_nop_();_nop_();_nop_();
while(--t);
void Init_Com(void)
TMOD = 0x20;
PCON = 0x00;
SCON = 0x50;
TH1 = 0xFd;
TL1 = 0xFd;
TR1 = 1;
bit drst(void)
bit ask;
EA=0;
DS=0;
delay10us(65);
DS=1;
delay10us(6);
ask=DS;
while(!DS);
return ask;
EA=1;
bit readbit(void)
bit dat;
EA=0;
DS=0;_nop_();
DS=1;_nop_();_nop_();
dat=DS;
delay10us(6);
return (dat);
EA=1;
uchar read(void)
uchar i,j,dat;
dat=0;
EA=0;
for(i=1;i<=8;i++)
j=readbit();
dat=(j<<7)|(dat>>1); //读出的数据最低位在最前面,这样刚好一个字节在DAT里
return(dat);
EA=1;
void write(uchar dat)
uchar j;
bit testb;
EA=0;
for(j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if(testb)
DS=0;
_nop_();_nop_();
DS=1;
delay10us(6);
DS=0; //write 0
delay10us(6);
DS=1;
_nop_();_nop_();
}EA=1;
void DSrun(void)
bit ask;
EA=0;
drst();
delay(1);
if(ask==0)
write(0xcc);
write(0x44);
EA=1;
uint tmp()
float tt;
uchar a,b;
EA=0;
DSrun();
a=read();
b=read();
temp=b;
temp<<=8;
temp=temp|a;
tt=temp*0.0625;
temp=tt*10+0.5;
return temp;
EA=1;
void display(uint temp)
uchar A1,A2,A3,A4,A2s,A3s,ser;
ser=temp/10;
ser=SBUF;
A1=temp/1000; //这里是为了显示正负,目前没有实现。
A2s=temp%1000;
A2=A2s/100;
A3s=A2s%100;
A3=A3s/10;
A4=A3s%10;
P0=table[A1];
P2=0x01;
delayms(1);
P0=table[A2];
P2=0x02;
delayms(1);
P0=table1[A3];
P2=0x04;
delayms(1);
P0=table[A4];
P2=0x08;
delayms(1);
uchar a;
do
DSrun();
//delay(200);
for(a=100;a>0;a--)
{ display(tmp());
} while(1);
这个程序仿真结果是这样的:
求大神指点一下是哪里出错了。
