查看: 1287|回复: 0
12864正选拨程序
ID:234985 发表于 2017-9-22 21:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg52.h"
#include "intrins.h"
#include "math.h"
#define unchar unsigned char
#define unint unsigned int
#define dataPort P0
#define Vmax 16
#define freq 60
sbit rs = P3^5;
sbit rw = P3^6;
sbit en = P3^4;
float x,y;
unchar code xian1[]={"峰值16V" };
unchar code xian2[]={"频率60Hz" };
void delayms(unsigned int n)
unsigned char i;
for(;n>0;n--)
for(i=0;i<100;i++);
void checkBusy(void)
rs=0;
rw=1;
en=1;
dataPort=0xff;
while(dataPort & 0x80);
en=0;
void writeCommand(unsigned char cmd)
checkBusy();
rs=0;
rw=0;
en=1;
dataPort=cmd;
_nop_();
en=0;
void writeData(unsigned char adata)
checkBusy();
rs=1;
rw=0;
en=1;
dataPort=adata;
_nop_();
en=0;
unsigned char readData(void)
unsigned char RData;
dataPort=0xff;
checkBusy();
rs=1;
rw=1;
en=0;
en=1;
RData=dataPort;
en=0;
return RData;
void ClrGDRAM(void)
        unsigned char x,y;
        for(y=0;y<64;y++)
            for(x=0;x<16;x++)
                        writeCommand(0x34);
            writeCommand(y+0x80);     //行地址
            writeCommand(x+0x80);     //列地址
            writeCommand(0x30);
            writeData(0x00);
            writeData(0x00);
        //writeCommand(0x30);
void LcmInit(void)
writeCommand(0x30);
delayms(50);
writeCommand(0x01);
delayms(50);
writeCommand(0x06);
delayms(50);
writeCommand(0x0c);
ClrGDRAM();
//psb=1;
函数名:  drawPoint
函数说明:画点
传入参数:打点位置(x0,y0);color=1,点亮;color=0,擦除
传出参数:无
返回值:  无
void drawPoint(unsigned char x,unsigned char y,unsigned char color)
unsigned char row,collum,cbite;
unsigned char tempH,tempL;
writeCommand(0x34);
writeCommand(0x36);
collum=x>>4;
cbite=x&0x0f;
if(y<32)
        row=y;
        {row=y-32;
        collum+=8;
writeCommand(0x80+row);
writeCommand(0x80+collum);
readData();
tempH=readData();
tempL=readData();
if (color)
         if(cbite<8)
         tempH|=(1<<(7-cbite));
         //tempL=(1<<(7-cbite));
         //tempH=(1<<(15-cbite));
         tempL|=(1<<(15-cbite));
           if(cbite<8)
         tempH&=~(1<<(7-cbite));
         tempL&=~(1<<(15-cbite));
writeData(tempH);
writeData(tempL);
writeCommand(0x30);
函数名:  drawRowLine
函数说明:画水平线
传入参数:(x0,y0),水平线的起点;(x1,y0)水平线的终点
传出参数:无
返回值:  无
void drawRowLine(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char color)
    unsigned char  temp;
    if(x0>x1)                                 // 对x0、x1大小进行排列,以便画图
        temp = x1;
        x1 = x0;
        x0 = temp;
    do
        drawPoint(x0, y0, color);        // 逐点显示,描出垂直线
        x0++;
    while(x1>=x0);
函数名:  drawCollumLine
函数说明:画竖直线
传入参数:(x0,y0),竖直线的起点;(x0,y1)竖直线的终点;
传出参数:无
返回值:  无
void drawCollumLine(unsigned char x0,unsigned char y0,unsigned char y1,unsigned char color)
unsigned char temp;
if(y0>y1)
  temp=y0;
  y0=y1;
  y1=temp;
while (y0<=y1)
drawPoint(x0,y0,color);
y0++;
//在坐标(x,y)处显示字符串
void LcmPrint(unsigned char x,unsigned char y,unsigned char *adata)
unsigned char address;
unsigned char i=0;
switch (y)
  case 0:address=0x80+x;break;
  case 1:address=0x90+x;break;
  case 2:address=0x88+x;break;
  case 3:address=0x98+x;break;
  default:break;
writeCommand(address);
while(*(adata+i))
        writeData(*(adata+i));
        i++;
          x=y=0;
        LcmInit();
        drawRowLine(0,31,127,1);
        drawCollumLine(0,0,63,1);
          for(x=0;x<128;x=x+0.05)
           y=Vmax*sin(2*3.14*freq*x);
           drawPoint(x,(y+31),1);
          LcmPrint(0,3,xian1);
          LcmPrint(4,3,xian2);
