查看: 5647|回复: 0
带触摸的单片机芯片A96T218引脚图和pdf规格书下载
分享一个ABOV UM_A96T218_V1.2_EN.pdf规格书,TK可以和LED共用的触摸芯片
A96T218引脚图(包含有各种封装格式的):
Main features
8-bit Microcontroller with high performance M8051 CPU
Basic MCU Function
   – 32K bytes Flash Code Memory
   – Code Area Protection
   – 256 bytes SRAM Data Memory
   – 1,792 bytes XRAM
Built-in Analog Function
   – Power-On Reset and Low Voltage Indicator Reset
   – Internal 16 MHz RC Oscillator
24CH Self Capactitive Touch Switch
   – 16-bit Sensing Resolution
   – Fast Initial Self-Calibration
   – Key Detection Mode : Single/Multi-Mode
   – The Improvement of SNR by Bias-Calibration in Analog Sensing Block
完整的pdf格式文档51黑下载地址:
UM_A96T218_V1.2_EN.pdf (5.13 MB, 下载次数: 22)
