查看: 7706|回复: 2
哪位高人能将这个C语言译成汇编语言,谢谢了!!
ID:6239 发表于 2008-11-1 21:33 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define uint  unsigned int
#define x     0x80
#define y     0x80
#define comm  0
#define dat   1
//|              VDD|--------------------|VCC     |
//|             LED+|--------------------|VCC     |
//|             LED-|--------------------|GND     |
//|              VSS|--------------------|GND     |
//|                 |    | 89C52    |
//|              DB0|--------------------|P1.0     |
//|              DB1|--------------------|P1.1     |
//|              DB2|--------------------|P1.2     |
//|   OCMJ2X4C   DB3|--------------------|P1.3     |
//|              DB4|--------------------|P1.4     |
//|              DB5|--------------------|P1.5     |
//|              DB6|--------------------|P1.6     |
//|        DB7(busy)|--------------------|P1.7     |
//|               rs|--------------------|P3.0     |
//|               rw|--------------------|P3.1     |
//|                e|--------------------|P3.2     |
//|              psb|--------------------|P3.3     |
//|              rst|--------------------|P3.4     |
sbit rs = P3^0;   //H=data; L=command;
sbit rw = P3^1;   //H=read; L=write;
sbit  e = P3^2;   //input enable;
sbit psb= P3^3;   //H=并口; L=串口;
sbit rst= P3^4;   //Reset Signal 低电平有效
sbit busy=P1^7;   //lcd busy bit
void wr_lcd (uchar dat_comm,uchar content);
void chk_busy (void);
void delay (uint us);
uchar code tab1[]={
"  阀门  "
"  80%  "
/*------------------初始化-----------------*/
void init_lcd (void)
  rst=1;
  psb=1;
  wr_lcd (comm,0x30);  /*30---基本指令动作*/
  wr_lcd (comm,0x01);  /*清屏,地址指针指向00H*/
  wr_lcd (comm,0x06);  /*光标的移动方向*/
  wr_lcd (comm,0x0c);  /*开显示,关游标*/
/*---------------显示汉字或字符----------------*/
void chn_disp (uchar code *chn)
  uchar i,j;
  wr_lcd (comm,0x30);
  wr_lcd (comm,0x80);
  j=0;
  for (i=0;i<8;i++)
  wr_lcd (dat,chn[j*8+i]);
  wr_lcd (comm,0x90);
  j=1;
  for (i=0;i<8;i++)
/*--------------清DDRAM------------------*/
void clrram (void)
  wr_lcd (comm,0x30);
  wr_lcd (comm,0x01);
  chk_busy ();
  if(dat_comm)
    rs=1;   //data
    rw=0;   //write
    rs=0;   //command
    rw=0;   //write
  P1=content;   //output data or comm
  e=1;
  e=0;
  P1=0xff;
  rs=0;
  rw=1;
  e =1;
  while(busy==1);
  e =0;
void delay (uint us)   //delay time
  while(us--);
/*------------------主程序--------------------*/
void main ()
   SP=0x5f;
   init_lcd ();
   clrram();
   chn_disp (tab1);
   while (1);
ID:22056 发表于 2010-3-9 18:59 | 显示全部楼层
