利用条码扫描,含源码,经过调试,可以使用
- #include <STC12C2052AD.H>
- #include "string.h"
- #include "stdlib.h"
- //#include <no_hand.h>
- #define POLYNOMIAL_IDF 0x08408 //crc16 多项式
- #define MAXUSERTIMERS 4
- #define MAXTIMERSTICK 1000 //用户定时器最大时间长度(ms)
- #define UERTIMESTATUS_STOP 0 //用户定时器状态-停止
- #define UERTIMESTATUS_RUN 1 //用户定时器状态-运行
- #define UERTIMESTATUS_RINING 2 //用户定时器状态-到时
- #define UERTIMESTATUS_ERROR 3 //用户定时器状态-到时
- #define Tid_SendTimer 1
- #define Tcn_SendTimer 2//20// 2
- #define Tid_pcrTimer 2
- #define Tcn_pcrTimer 20
- #define Tid_tiaomarTimer 3
- #define Tcn_tiaomarTimer 20
- #define Tid_TiaomaYingQing 0
- #define Tcn_TiaomaYingQing 500
- typedef struct _TiaoMaDataInfo
- unsigned char SerialNum; //接收条码的顺序号
- unsigned char Sta;
- unsigned char CheckData;//校验码
- unsigned char TiaoMaBuf[10];
- }TiaoMaDataInfo;
- typedef struct _TiaoMaBuf
- unsigned char Sta;//1:表示有 0:表示不存在
- unsigned char TiaoMaBuf[6];
- }TiaoMaBuf;
- typedef struct _ComuStaInfo
- unsigned char Cmd;
- unsigned char Len;
- unsigned char Num;
- unsigned char Buf[8];
- unsigned char Suc;
- unsigned int CRC;
- }ComuStaInfo;
- //定时器结构定义
- typedef struct _SUserTimer{
- volatile int Deadline;
- volatile int ReLoadTickNum;
- } SUserTimer;
- TiaoMaDataInfo gTiaoMaData;
- TiaoMaBuf TiaoMaBufData;
- ComuStaInfo idata ComuStaData;
- SUserTimer UserTimer[MAXUSERTIMERS];
- sbit pc_txd =P3^2; //模拟串口接收
- sbit pc_rxd =P3^3; //模拟串口发送
- bit byte_waiting_flag; //接收字节时的等待时间,在未收到校验之前
- bit Sendtopcflag; //模拟串口发送数据标志
- bit Sendtopcendflag; //模拟串口发送数据字节结束标志
- bit Revfrompcendflag; //模拟串口接收数据字节结束标志
- bit Revfrompcflag; //模拟串口接收数据标志
- bit YQflag =0;
- bit DelayScanFlag =0;
- unsigned char Revfrompcdata,Sendtopcdata;
- unsigned char T0timeouttimesR,T0timeouttimesT;
- unsigned char idata wait_receive_num;
- unsigned char idata SendToPc[12];
- unsigned int TimeTick =0;
- unsigned char Send_Flag =0;
- unsigned char idata Send_Len =0;
- //unsigned char DelayScanFlag =0;
- unsigned long idata DelayScanTime =0;
- void UART0_SendByte(unsigned char dat);
- //* Function Name : GetTickCount()
- //* Object : Return the number of systimer tick
- //* Input Parameters :
- //* Output Parameters :
- unsigned long GetTickCount(void)
- return TimeTick;
- //* Function Name : ResetTickCount()
- //* Object : systimer tick = 0
- void ResetTickCount(void)
- int TimerID;
- TimeTick = 0;
- for(TimerID=0;TimerID<MAXUSERTIMERS;TimerID++)
- UserTimer[TimerID].Deadline = 0;
- //* Function Name : CheckResetTickCount()
- void CheckResetTickCount(void)
- int TimerID;
- if(1)
- if(UserTimer[TimerID].Deadline != 0)
- UserTimer[TimerID].Deadline -= 0x10000;
- //stop the timer0 int
- TimeTick -= 0x10000;
- //start the timer0 int
- //* Function Name : BeginTimer()
- //* Object : Begin a user timer with tick
- unsigned int StartTimer(unsigned int TimerID, unsigned int TimerTickCount)//1 ticket =5ms
- if( TimerID > MAXUSERTIMERS) return 0;
- if(TimerTickCount == 0)
- TimerTickCount = UserTimer[TimerID].ReLoadTickNum;
- if(TimerTickCount > MAXTIMERSTICK)
- TimerTickCount = MAXTIMERSTICK;
- UserTimer[TimerID].ReLoadTickNum = TimerTickCount;
- UserTimer[TimerID].Deadline = TimeTick+TimerTickCount;
- return TimerID;
- //* Function Name : HaltTimer()
- //* Object : Stop a user timer with tick
- unsigned int HaltTimer(unsigned int TimerID)
- if( TimerID > MAXUSERTIMERS) return UERTIMESTATUS_ERROR;
- return TimerID;
- //* Function Name : GetTimerStatus()
- unsigned int GetTimerStatus( unsigned int TimerID,const int AutoStop) //反绕问题
- unsigned int retcode;
- if(TimerID > MAXUSERTIMERS)
- retcode = UERTIMESTATUS_ERROR;
- else if(UserTimer[TimerID].Deadline == 0)
- retcode = UERTIMESTATUS_STOP;
- else if(UserTimer[TimerID].Deadline > TimeTick)
- if((UserTimer[TimerID].Deadline - TimeTick) > TimeTick+UserTimer[TimerID].ReLoadTickNum)
- StartTimer(TimerID,0);
- else
- retcode = UERTIMESTATUS_RUN;
- else
- if(AutoStop)
- else
- UserTimer[TimerID].Deadline = TimeTick+UserTimer[TimerID].ReLoadTickNum;
- retcode = UERTIMESTATUS_RINING;
- return retcode;
- //#include <reg52.h>/**************THIS IS A 模拟串口接收中 定时器0初始化**************/
- void board_init(void)
- // unsigned char test;
- SCON =0x050;
- TMOD =0x22;
- TH1 =0xfa; //9600baud,11.0592m
- TL1 =0xfa;
- PCON =0x80;
- TCON =0x01;
- WDT_CONTR =0x3e;
- CMOD =80; //在空闲模式下停止PCA计时器工作
- CCON =0;
- CCAPM0 =0x49; //CCAPM1用作软件定时器。当CCF1和ECCF1都置位时中断,CCF1和ECCF1必须由软件清零
- CL =0;
- CH =0;
- CCAP0L =0x00;
- CCAP0H =0x12;
- // CCAP0L =0xb8;//200us
- // CCAP0H =0x00;
- EPCA_LVD =1;
- CR =1;
- // AUXR &=0x3f;
- //TH0 =0x7f;// 给定时器0赋初值255-11059200/12/4800+1=40
- //TL0 =0x7f;
- EA =1;
- ES =1;
- // ES =1;
- TR1 =1;
- EX0 =1;
- //EX1 =1;
- ET0 =1;
- IP =0;
- PT0 =1; //TEST ,T0 IS PRIVATY
- IT0 =1; //the edge interrupt
- pc_txd =1;
- pc_rxd =1;
- //TX_EN =1;
- void DataInit(void)
- memset(&gTiaoMaData,0,sizeof(TiaoMaDataInfo));
- memset(&TiaoMaBufData,0,sizeof(TiaoMaBuf));
- memset(&ComuStaData,0,sizeof(ComuStaInfo));
- Revfrompcendflag =0;
- Sendtopcflag =0;
- void externint0 (void) interrupt 0
- TR0 =0;
- TH0 =0x0A0;
- TL0 =0x0A0;
- T0timeouttimesR =8;
- Revfrompcflag =1;
- ET0=1;
- TR0 =1;
- EX0 =0;
- //wait_receive_num =0;
- byte_waiting_flag =0;
- timer0 interrupt subprogram
- void t0int(void) interrupt 1
- if( Sendtopcflag==1)
- if( Sendtopcdata & 0x01)
- pc_rxd =1; //T1=P1.6
- else
- pc_rxd =0;
- Sendtopcdata =Sendtopcdata >> 1; //右移
- Sendtopcdata =Sendtopcdata |0x80;
- T0timeouttimesT--;
- if( T0timeouttimesT==0)
- Sendtopcflag =0;
- pc_rxd =1; //停止位
- Sendtopcendflag =1;
- // TR0 =0;
- EX0 =1;
- if ( Revfrompcflag==1)
- { //test =~test; //test
- Revfrompcdata = Revfrompcdata >> 1;
- if (pc_txd ==1) //PC_txd=P3^2
- Revfrompcdata =Revfrompcdata | 0x80;
- T0timeouttimesR--;
- if(T0timeouttimesR==0)
- Revfrompcflag =0;
- Revfrompcendflag =1;
- IE0 =0;
- EX0 =1;
- byte_waiting_flag =1;
- TR0 =0;
- TH0 =0;
- TL0 =0;
- TR0 =1;
- PCA interrupt subprogram
- void pcaint(void) interrupt 6
- //int i;
- //static int i;
- CCF0 =0;
- // i =(CCAP0H*256)+CCAP0L;
- //i +=0xb8;
- //CCAP0H =(unsigned char )(i>>8);
- //CCAP0L =(unsigned char )i;
- // CL =0;
- // CH =0;
- CCAP0L +=0x00;
- CCAP0H +=0x12;
- // UART0_SendByte(CCAP0H);
- //UART0_SendByte(CCAP0L);
- //CCAP0L +=0xb8;
- // CCAP0H +=0x00;
- TimeTick++;
- /*********************sending a byte of simulate serial port**********/
- void sendbyte(unsigned char simdata)
- // txd_sel =1;
- Sendtopcdata =simdata;
- EX0=0; //模拟串口接收
- TR0=0; //定时器0停止计数
- TH0=0x0A0; //给定时器0赋初值255-11.0592/12/9600+1=A0
- TL0=0x0A0;
- TR0=1;
- ET0=1; //定时器0开始计数
- pc_rxd=0; //串口传输数据的开始BIT=0
- T0timeouttimesT=0x0a; // //1 start bit ;8 bit data ,1 stop bit
- Sendtopcflag=1; //在定时其中断中,根据该标志
- Sendtopcendflag=0;
- while(!Sendtopcendflag); //waiting the simulate serial port sending end
- // //允许模拟串口接收
- void emulator_send_string(unsigned char *array,unsigned char array_length)
- unsigned int i;
- for (i=0;i<array_length;i++)
- sendbyte(array[i]);
- ** 函数名称 :UART0_SendByte()
- ** 函数功能 :向串口0发送1字节数据
- ** 入口参数 :dat 要发送的数据
- ** 出口参数 :无
- //TB8 =Even_Checkout(dat);
- SBUF =dat;
- //if(IcWayDefineFlag ==1)
- // TB8 =~TB8;
- while(!TI);
- TI =0;
- ** 函数名称 :UART0_SendString()
- ** 函数功能 :向串口0发送一个字符串
- ** 入口参数 :aa 一个字符串的首地址,length,字符串的长度
- ** 出口参数 :无
- void UART0_SendString(char *aa,unsigned int length)
- unsigned int i;
- for (i=0;i<length;i++)
- UART0_SendByte(aa[i]);
- void TiaoMaRev(void)
- unsigned char temp;
- temp =0;
- if (Revfrompcendflag == 1)
- temp =Revfrompcdata;
- //UART0_SendByte(temp);
- switch(gTiaoMaData.Sta)
- case 0://开始位
- if(temp ==0x36)
- gTiaoMaData.Sta++;
- //BeginTimer(uint8 TimerId,uint32 ValueCount)
- //StartTimer(TID_TIAOMAREV1,TIN_TIAOMAREV1);
- StartTimer(Tid_tiaomarTimer,Tcn_tiaomarTimer);//定义条码接收时间,超时状态归零
- else
- gTiaoMaData.SerialNum =0;
- break;
- case 1://条码接收
- gTiaoMaData.TiaoMaBuf[gTiaoMaData.SerialNum]=(temp-0x30);
- gTiaoMaData.SerialNum++;
- if(gTiaoMaData.SerialNum==6)
- break;
- case 2://条码校验位
- gTiaoMaData.CheckData =(temp-0x30);
- case 3://
- case 4:
- HaltTimer(Tcn_tiaomarTimer);
- //////////条码校验算法
- unsigned char TiaoMaCheck(void)
- unsigned char i=0;
- unsigned char CheckDat1;
- unsigned char CheckDat2;
- CheckDat1 =gTiaoMaData.TiaoMaBuf[5]+gTiaoMaData.TiaoMaBuf[3]+gTiaoMaData.TiaoMaBuf[1]+6;
- CheckDat1 =CheckDat1*3;
- CheckDat2 =gTiaoMaData.TiaoMaBuf[4]+gTiaoMaData.TiaoMaBuf[2]+gTiaoMaData.TiaoMaBuf[0];
- CheckDat2 =CheckDat2+CheckDat1;
- while(i*10 <CheckDat2)
- i++;
- CheckDat1 =i*10-CheckDat2;
- if(gTiaoMaData.CheckData ==CheckDat1)
- return 0; //校验成功
- else
- return 1; //校验失败
- void tiaomadis(void)
- if(gTiaoMaData.Sta ==5)//表示收到了条码校验位
- gTiaoMaData.Sta =0;
- //UART0_SendByte(0x99);
- //UART0_SendString(TiaoMaBufData.TiaoMaBuf,6);
- HaltTimer(Tid_tiaomarTimer);//条码接收完毕
- if(TiaoMaCheck() ==0)
- //if(YQflag ==1)
- //if(GetTimerStatus(Tid_TiaomaYingQing,1)!=UERTIMESTATUS_RUN)
- if(DelayScanFlag ==0)
- //UART0_SendByte(0x66);
- TiaoMaBufData.Sta =1;
- YQflag =0;
- DelayScanFlag =1;
- //拷贝条码数据
- memcpy(TiaoMaBufData.TiaoMaBuf,gTiaoMaData.TiaoMaBuf,10);
- //StartTimer(Tid_TiaomaYingQing,Tcn_TiaomaYingQing);
- ** 函数名称 :GetCRC16
- ** 函数功能 :得到CRC16值
- ** 入口参数 : bufData:要进行CRC校验的串,sizeData:串的长度
- ** 出口参数 :无
- unsigned int GetCRC16(unsigned char *bufData, unsigned int sizeData)
- unsigned int CRC_buf, i;
- unsigned char j;
- CRC_buf = 0;
- for(i=0; i < sizeData; i++)
- CRC_buf ^= bufData[i];
- for(j=0; j < 8; j++)
- if(CRC_buf & 0x0001) {CRC_buf >>= 1; CRC_buf ^= POLYNOMIAL_IDF;}
- else CRC_buf >>= 1;
- return CRC_buf;
- //条码协议
- //为半双工,条码板被动,主板主动查询
- //协议格式为: SYNC(1 byte) ADR(1 byte) LNG(1 byte) CMD(1 byte) DATA(0 to 250 bytes) CRC2( bytes)
- ////条码回应时ADR: 0X10,空闲data:0X83H
- //有条码dat:0X84H +6 HEX
- void serial (void) interrupt 4
- unsigned char serial_buf;
- // unsigned char i;
- if(RI ==1)
- RI =0;
- serial_buf =SBUF;
- // UART0_SendByte(serial_buf);
- //sendbyte(serial_buf);
- switch(ComuStaData.Sta)
- case 0:
- if(serial_buf ==0x02)
- ComuStaData.Buf[ComuStaData.Sta]=serial_buf;
- ComuStaData.Sta++;
- ComuStaData.Num =0;
- StartTimer(Tid_pcrTimer,Tcn_pcrTimer);
- else
- ComuStaData.Sta =0;
- break;
- case 1://adr
- break;
- case 2://lng
- //if(serial_buf ==6)
- ComuStaData.Len =serial_buf;
- //UART0_SendByte(0xcc);
- //else
- // ComuStaData.Sta =0;
- if(ComuStaData.Len>7)
- break;
- case 3://cmd
- ComuStaData.Cmd =serial_buf;
- break;
- case 3:
- ComuStaData.Buf[ComuStaData.Num+3]=serial_buf;
- ComuStaData.Num++;
- if(ComuStaData.Num ==(ComuStaData.Len-3))
- ComuStaData.Suc =1;
- //UART0_SendByte(0xaa);
- ComuStaData.CRC=((ComuStaData.Buf[ComuStaData.Len-1]<<8)+ComuStaData.Buf[ComuStaData.Len-2]);
- HaltTimer(Tid_pcrTimer);
- break;
- void pcdis(void)
- int crc;
- unsigned char i;
- if(ComuStaData.Suc ==1)
- ComuStaData.Suc =0;
- if(ComuStaData.CRC ==GetCRC16(ComuStaData.Buf,(ComuStaData.Len-2)))
- //if(ComuStaData.Buf[1] ==0x10)//ADR为条码
- if(ComuStaData.Buf[3]==0x33)//polling
- if(TiaoMaBufData.Sta ==0)//空闲位,表示没有扫描值
- SendToPc[0] =0x02;//head
- SendToPc[1] =0x10;//adr
- SendToPc[2] =0x6;//len
- SendToPc[3] =0x83;//dat
- crc =GetCRC16(SendToPc,4);
- SendToPc[4] =(unsigned char)crc;
- SendToPc[5] =(unsigned char)(crc>>8);
- Send_Flag =1;
- Send_Len =6;
- //UART0_SendString(SendToPc,6);
- StartTimer(Tid_SendTimer,Tcn_SendTimer);
- else if(TiaoMaBufData.Sta ==1)//为1,表示有扫描值
- SendToPc[2] =0x0c;//len
- SendToPc[3] =0x84;//dat
- for(i =0;i<6;i++)
- SendToPc[i+4]=TiaoMaBufData.TiaoMaBuf[i];
- crc =GetCRC16(SendToPc,10);
- SendToPc[10] =(unsigned char)crc;
- SendToPc[11] =(unsigned char)(crc>>8);
- Send_Flag =1;
- Send_Len =12;
- //UART0_SendString(SendToPc,12);
- …………限于本文篇幅 余下代码请从51黑下载附件…………
全部资料下载地址:
code_saomiaoban.zip
(111.36 KB, 下载次数: 34)
