查看: 1527|回复: 0
直流电机调速及预警
ID:236125 发表于 2017-11-24 16:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#define  CYCLE 10         //pwn周期
sbit  PWN0=P1^4;
sbit  PWN1=P1^5;
sbit  key1=P3^0;        //jia
sbit  key2=P3^1;        //jian
sbit  key3=P3^2;        //tingzhi
sbit  key4=P3^3;  //zhengfanzhuan
char  PWN_ON=0;
char  count=0;         //定时器计数
int  num,flag;//正反转标志位
sbit beep=P2^3;
void delayms(int x)
    int i,j;
        for(i=x;i>0;i--)
          for(j=110;j>0;j--);
void keyscan()
     if(key1==0)
            delayms(5);
                if(key1==0)
                    while(!key1);
                 if(num<=3)
                          num++;
                          if(num==2)
                              beep=0;
                                  P0=0x00;
                                  delayms(10);
                                  beep=1;
                                  P0=0xff;
                          if(num==3)
                              beep=0;
                                  P0=0x00;
    if(key2==0)
           delayms(5);
           if(key2==0)
              if(num>0)
                   num--;
                   while(!key2);
         if(key3==0)
            delayms(5);
            if(key3==0)
              while(!key3);
              num=!num;
          if(key4==0)
             delayms(5);
                 if(key4==0)
                     while(!key4);
                     flag++;
                         if(flag==2)
                         flag=0;
          switch(num)
             case 0: PWN_ON=0;break;
                 case 1: PWN_ON=4;break;
                 case 2: PWN_ON=7;break;
                 case 3: PWN_ON=10;break;
             default:
                 break;
void init()        //初始化
        PWN0=1;
        PWN1=1;
    TMOD=0X01;
        TH1=(65535-45872)/256;
        TL1=(65535-45872)%256;
        EA=1;
        ET1=1;
        TR1=1;
    init();
            keyscan();
void  T1_time()interrupt 3
           count++;
          if(count>CYCLE)
          count=0;
          if(count<PWN_ON)//进行正反转
               if(flag==1)
                          PWN0=0;
              PWN1=1;
                           PWN0=1;
               PWN1=0;
             PWN0=1;
         PWN1=1;
