查看: 569|回复: 0
使用蓝牙模块直接串口连接,显示数字合适,用蓝牙连接后数字变成16进制了 (审核中)
ID:1070602 发表于 2023-5-16 16:09 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
include <reg51.h>
#include <intrins.h>
#define uint unsigned int
uchar temp1,temp2,temp,A;
uchar sb[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
    0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0xBf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
sbit DQ=P3^7;
void delay(uint t)
  uint j,k;
  for(j=t;j>0;j--)
   for(k=115;k>0;k--);
void display_1820(uchar x)
  uint i,ge,shi,xiao;
shi=(x/10);
  ge=(x%10);
  xiao=(x%10/10);
  P0=sb[i];
  for(i=0;i<4;i++)
   if(i==0){P0=0x00;P0=sb[shi];P2=0xfd;delay(1);}
   if(i==0){P0=0x00;P0=sb[ge]|0x80;P2=0xfb;delay(1);}
   if(i==0){P0=0x00;P0=sb[xiao];P2=0xf7;delay(1);}
void delay_18b20(uint i)
  for(;i>0;i--);
void init()
  uchar x=0;
  DQ=1;
  delay_18b20(8);
  DQ=0;
  delay_18b20(80);
  DQ=1;
  delay_18b20(14);
  x=DQ;
  delay_18b20(20);
uchar read()
  uchar i=0;
  uchar dat=0;
  for(i=8;i>0;i--)
    DQ=0;
    dat>>=1;
    DQ=1;
    if(DQ)dat|=0x80;
    delay_18b20(4);
  return dat;
void write(uchar dat)
  uchar i=0;
  for(i=8;i>0;i--)
    DQ=0;
    DQ=dat&0x01;
    delay_18b20(5);
    DQ=1;
    dat>>=1;
uchar read1()
  uchar a=0,b=0,t=0;
  init();
  write(0xcc);
  write(0x44);
  delay_18b20(100);
  init();
  write(0xcc);
  write(0xbe);
  delay_18b20(100);
  a=read();
  b=read();
  temp1=b<<8;
  temp1+=(a&0x63)>>4;
  temp2=a&0x63;
  temp=((b*256+a)>>4);
  return temp;
void UART_Init()
TMOD&=0x63;
TMOD|=0x20;
TR1=1;
TH1=0xF3;
TL1=0xF3;
SCON=0x50;
PCON|=0x80;
ES=1;
EA=1;
void UART_SendByte(unsigned char Byte)
SBUF=Byte;
while(TI==0);
TI=0;
/*1ms=1,±1ms*/void delay_1ms(unsigned int _1ms){_1ms*=110;while(_1ms--){}}
  UART_Init();
                delay_1ms(5);
    //A=read1();
                UART_SendByte(read1());
    //display_1820(read1());
void UART_Routine() interrupt 4
if(RI==1)
  P2=~SBUF;
  UART_SendByte(SBUF);
  RI=0;
