12864电子钟制作资料,共享给大家
- 经过本人对函数的优化修改,编译后代码比原来少了近300 字节。
- /* 获取当前日期的农历及星期*/
- /*公历年对应的农历数据,每年三字节, 格式: */
- /*第一字节BIT7-4 位表示闰月月份,值为0 为无闰月, */
- /*BIT3-0 对应农历第1-4 月的大小*/
- /*第二字节BIT7-0 对应农历第5-12 月大小, */
- /*第三字节BIT7 表示农历第13 个月大小月份对应的位*/
- /*为1 表示本农历月大(30 天),为0 表示小(29 天) */
- /*第三字节BIT6-5 表示春节的公历月份,BIT4-0 表示春节的公历日期*/
- /*类型:Byte:unsigned char Word:unsigned int */
- /*本代码中Tim[0]/Tim[1]/Tim[2]分别为当前年月日数据*/
- /*其中Tim[0]Bit7 表示世纪,1 为20 世纪19xx,0 为21 世纪20xx*/
- /*Tim[10]为周数据/Tim[7]/Tim[8]/Tim[9]为农历数据,根据需要自行更换*/
- #include <intrins.h>
- Byte code year_code[597]={
- 0x04,0xAe,0x53,0x0A,0x57,0x48,0x55,0x26,0xBd, // 1901-1903
- 0x0d,0x26,0x50,0x0d,0x95,0x44,0x46,0xAA,0xB9, // 1904-1906
- 0x05,0x6A,0x4d,0x09,0xAd,0x42,0x24,0xAe,0xB6, // 1907-1909
- 0x04,0xAe,0x4A,0x6A,0x4d,0xBe,0x0A,0x4d,0x52, // 1910-1912
- 0x0d,0x25,0x46,0x5d,0x52,0xBA,0x0B,0x54,0x4e, // 1913-1915
- 0x0d,0x6A,0x43,0x29,0x6d,0x37,0x09,0x5B,0x4B, // 1916-1918
- 0x74,0x9B,0xC1,0x04,0x97,0x54,0x0A,0x4B,0x48, // 1919-1921
- 0x5B,0x25,0xBC,0x06,0xA5,0x50,0x06,0xd4,0x45, // 1922-1924
- 0x4A,0xdA,0xB8,0x02,0xB6,0x4d,0x09,0x57,0x42, // 1925-1927
- 0x24,0x97,0xB7,0x04,0x97,0x4A,0x66,0x4B,0x3e, // 1928-1930
- 0x0d,0x4A,0x51,0x0e,0xA5,0x46,0x56,0xd4,0xBA, // 1931-1933
- 0x05,0xAd,0x4e,0x02,0xB6,0x44,0x39,0x37,0x38, // 1934-1936
- 0x09,0x2e,0x4B,0x7C,0x96,0xBf,0x0C,0x95,0x53, // 1937-1939
- 0x0d,0x4A,0x48,0x6d,0xA5,0x3B,0x0B,0x55,0x4f, // 1940-1942
- 0x05,0x6A,0x45,0x4A,0xAd,0xB9,0x02,0x5d,0x4d, // 1943-1945
- 0x09,0x2d,0x42,0x2C,0x95,0xB6,0x0A,0x95,0x4A, // 1946-1948
- 0x7B,0x4A,0xBd,0x06,0xCA,0x51,0x0B,0x55,0x46, // 1949-1951
- 0x55,0x5A,0xBB,0x04,0xdA,0x4e,0x0A,0x5B,0x43, // 1952-1954
- 0x35,0x2B,0xB8,0x05,0x2B,0x4C,0x8A,0x95,0x3f, // 1955-1957
- 0x0e,0x95,0x52,0x06,0xAA,0x48,0x7A,0xd5,0x3C, // 1958-1960
- 0x0A,0xB5,0x4f,0x04,0xB6,0x45,0x4A,0x57,0x39, // 1961-1963
- 0x0A,0x57,0x4d,0x05,0x26,0x42,0x3e,0x93,0x35, // 1964-1966
- 0x0d,0x95,0x49,0x75,0xAA,0xBe,0x05,0x6A,0x51, // 1967-1969
- 0x09,0x6d,0x46,0x54,0xAe,0xBB,0x04,0xAd,0x4f, // 1970-1972
- 0x0A,0x4d,0x43,0x4d,0x26,0xB7,0x0d,0x25,0x4B, // 1973-1975
- 0x8d,0x52,0xBf,0x0B,0x54,0x52,0x0B,0x6A,0x47, // 1976-1978
- 0x69,0x6d,0x3C,0x09,0x5B,0x50,0x04,0x9B,0x45, // 1979-1981
- 0x4A,0x4B,0xB9,0x0A,0x4B,0x4d,0xAB,0x25,0xC2, // 1982-1984
- 0x06,0xA5,0x54,0x06,0xd4,0x49,0x6A,0xdA,0x3d, // 1985-1987
- 0x0A,0xB6,0x51,0x09,0x37,0x46,0x54,0x97,0xBB, // 1988-1990
- 0x04,0x97,0x4f,0x06,0x4B,0x44,0x36,0xA5,0x37, // 1991-1993
- 0x0e,0xA5,0x4A,0x86,0xB2,0xBf,0x05,0xAC,0x53, // 1994-1996
- 0x0A,0xB6,0x47,0x59,0x36,0xBC,0x09,0x2e,0x50, // 1997-1999
- 0x0C,0x96,0x45,0x4d,0x4A,0xB8,0x0d,0x4A,0x4C, // 2000-2002
- 0x0d,0xA5,0x41,0x25,0xAA,0xB6,0x05,0x6A,0x49, // 2003-2005
- 0x7A,0xAd,0xBd,0x02,0x5d,0x52,0x09,0x2d,0x47, // 2006-2008
- 0x5C,0x95,0xBA,0x0A,0x95,0x4e,0x0B,0x4A,0x43, // 2009-2011
- 0x4B,0x55,0x37,0x0A,0xd5,0x4A,0x95,0x5A,0xBf, // 2012-2014
- 0x04,0xBA,0x53,0x0A,0x5B,0x48,0x65,0x2B,0xBC, // 2015-2017
- 0x05,0x2B,0x50,0x0A,0x93,0x45,0x47,0x4A,0xB9, // 2018-2020
- 0x06,0xAA,0x4C,0x0A,0xd5,0x41,0x24,0xdA,0xB6, // 2021-2023
- 0x04,0xB6,0x4A,0x69,0x57,0x3d,0x0A,0x4e,0x51, // 2024-2026
- 0x0d,0x26,0x46,0x5e,0x93,0x3A,0x0d,0x53,0x4d, // 2027-2029
- 0x05,0xAA,0x43,0x36,0xB5,0x37,0x09,0x6d,0x4B, // 2030-2032
- 0xB4,0xAe,0xBf,0x04,0xAd,0x53,0x0A,0x4d,0x48, // 2033-2035
- 0x6d,0x25,0xBC,0x0d,0x25,0x4f,0x0d,0x52,0x44, // 2036-2038
- 0x5d,0xAA,0x38,0x0B,0x5A,0x4C,0x05,0x6d,0x41, // 2039-2041
- 0x24,0xAd,0xB6,0x04,0x9B,0x4A,0x7A,0x4B,0xBe, // 2042-2044
- 0x0A,0x4B,0x51,0x0A,0xA5,0x46,0x5B,0x52,0xBA, // 2045-2047
- 0x06,0xd2,0x4e,0x0A,0xdA,0x42,0x35,0x5B,0x37, // 2048-2050
- 0x09,0x37,0x4B,0x84,0x97,0xC1,0x04,0x97,0x53, // 2051-2053
- 0x06,0x4B,0x48,0x66,0xA5,0x3C,0x0e,0xA5,0x4f, // 2054-2056
- 0x06,0xB2,0x44,0x4A,0xB6,0x38,0x0A,0xAe,0x4C, // 2057-2059
- 0x09,0x2e,0x42,0x3C,0x97,0x35,0x0C,0x96,0x49, // 2060-2062
- 0x7d,0x4A,0xBd,0x0d,0x4A,0x51,0x0d,0xA5,0x45, // 2063-2065
- 0x55,0xAA,0xBA,0x05,0x6A,0x4e,0x0A,0x6d,0x43, // 2066-2068
- 0x45,0x2e,0xB7,0x05,0x2d,0x4B,0x8A,0x95,0xBf, // 2069-2071
- 0x0A,0x95,0x53,0x0B,0x4A,0x47,0x6B,0x55,0x3B, // 2072-2074
- 0x0A,0xd5,0x4f,0x05,0x5A,0x45,0x4A,0x5d,0x38, // 2075-2077
- 0x0A,0x5B,0x4C,0x05,0x2B,0x42,0x3A,0x93,0xB6, // 2078-2080
- 0x06,0x93,0x49,0x77,0x29,0xBd,0x06,0xAA,0x51, // 2081-2083
- 0x0A,0xd5,0x46,0x54,0xdA,0xBA,0x04,0xB6,0x4e, // 2084-2086
- 0x0A,0x57,0x43,0x45,0x27,0x38,0x0d,0x26,0x4A, // 2087-2089
- 0x8e,0x93,0x3e,0x0d,0x52,0x52,0x0d,0xAA,0x47, // 2090-2092
- 0x66,0xB5,0x3B,0x05,0x6d,0x4f,0x04,0xAe,0x45, // 2093-2095
- 0x4A,0x4e,0xB9,0x0A,0x4d,0x4C,0x0d,0x15,0x41, // 2096-2098
- 0x2d,0x92,0xB5, // 2099
- //月份天数数据表
- Byte code day_code1[9]={0x0,0x1f,0x3b,0x5a,0x78,0x97,0xb5,0xd4,0xf3};
- Word code day_code2[3]={0x111,0x130,0x14e};
- //月修正数据表
- Byte code week_code[12]={0,3,3,6,1,4,6,2,5,0,3,5};
- void Conver_week(void)
- /*=======获取当前日期的星期====================================*/
- Byte temp1,temp2,year,month,day;
- year =Tim[0]&0x7f; //加载年月日数据,如为BCD 则需转为十进制
- month=Tim[1];
- day =Tim[2];
- if(Tim[0]>>7==0){year+=0x64;} //如果为21 世纪,年份数加100
- temp1=year/0x4; //所过闰年数只算1900 年之后的
- temp2=(year+temp1)%0x7; //为节省资源,先进行一次取余,避免数
- 大于0xff
- temp2=temp2+day+week_code[month-1];
- if(year%0x4==0&&month<3)temp2-=1; //如果是闰年但不到3 月则减一天
- Tim[10]=temp2%0x7; //将星期数据写到指定星期变量Tim[9]
- bit get_moon_day(Byte month_p,Word code_addr)
- /*读取数据表中农历月的大月或小月,如果该月大返回1,小返回0*/
- Byte temp,temp1;
- temp1=(month_p+3)/8;
- temp=0x80>>((month_p+3)%8);
- temp=year_code[code_addr+temp1]&temp;
- if(temp==0){return(0);}else{return(1);}
- void Conversion(void)
- /*==转换当前农历信息====================================*/
- Byte year,month,day;
- Byte temp1,temp2,temp3,month_p;
- Word temp4,code_addr;
- bit flag2,flag_y;
- month=Tim[1];
- day =Tim[2];
- code_addr=year-1; //定位数据表地址
- if(Tim[0]>>7==0)code_addr+=0x64;
- code_addr*=3;
- temp1=year_code[code_addr+2]&0x60; //取当年春节所在的公历月
- 份
- temp1=_cror_(temp1,5);
- temp2=year_code[code_addr+2]&0x1f; //取当年春节所在的公历日
- temp3=temp2-1; //计算当年春节离当年元旦的天数,春节只会在公
- 历1 月或2 月
- if(temp1!=1)temp3+=0x1f;
- if(month<10){temp4=day_code1[month-1]+day;}
- else{temp4=day_code2[month-10]+day;}
- if((month<2)||(year%0x04!=0))temp4-=1; //如果公历月小于2 月或者该
- 年的2 月非闰月,天数减1
- if (temp4>=temp3) //判断公历日在春节前还是春节后
- //公历日在春节后或就是春节当日使用下面代码进行运算
- temp4 -=temp3;
- month = 1;
- flag_y = 0;
- month_p= 1; //month_p 为月份指向,公历日在春节前或就是春节当
- 日month_p 指向首月
- flag2=get_moon_day(month_p,code_addr); //检查该农历月为大
- 小还是小月,大月返回1,小月返回0
- if(flag2==0){temp1=29;}else{temp1=30;} //小月29 天、大月30 天
- temp2=year_code[code_addr]&0xf0;
- temp2=_cror_(temp2,4); //从数据表中取该年的闰月月份,如为0 则
- 该年无闰月
- while(temp4>=temp1)
- temp4-=temp1;
- month_p+=1;
- if(month==temp2)
- flag_y=~flag_y;
- if(flag_y==0)month+=1;
- else month+=1;
- if(flag2==0)temp1=0x1d;
- else temp1=0x1e;
- day=temp4+1;
- else
- //公历日在春节前使用下面代码进行运算
- temp3-=temp4;
- if(year==0){year=0xe3;}else{year-=1;}
- code_addr-=3;
- month = 0xc;
- temp2 = year_code[code_addr]&0xf0;
- temp2 = _cror_(temp2,4);
- flag_y = 0;
- if(temp2==0){month_p=12;}else{month_p=13;} //如果当年有闰月,
- 一年有十三个月,月指向13,无闰月指向12
- while(temp3>temp1)
- temp3-=temp1;
- month_p-=1;
- if(flag_y==0)month-=1;
- if(month==temp2)flag_y=~flag_y;
- if(flag2==0){temp1=0x1d;}else{temp1=0x1e;}
- day=temp1-temp3+1;
- Tim[7] = year|(Tim[0]&0x80);; //将农历信息写进指定变量
- Tim[8] = month;
- Tim[9] = day;
- Conver_week(); //最后进行星期转换(根据需要自行选用)
12864资料.zip
(194.46 KB, 下载次数: 35)
