51单片机读写sd卡例程分享给大家
电路原理图如下:
- //------------------ MMC/SD-Card Reading and Writing implementation -------------------
- sbit SPI_DI =P2^1;
- sbit SPI_DO =P2^5;
- sbit SPI_SCL=P2^2;
- sbit SPI_CS =P2^0;
- // Error define
- #define INIT_CMD0_ERROR 0x01
- #define INIT_CMD1_ERROR 0x02
- #define WRITE_BLOCK_ERROR 0x03
- #define READ_BLOCK_ERROR 0x04
- // data type
- // this structure holds info on the MMC card currently inserted
- typedef struct MMC_VOLUME_INFO
- { //MMC/SD Card info
- unsigned int size_MB;
- unsigned char sector_multiply;
- unsigned int sector_count;
- unsigned char name[6];
- } VOLUME_INFO_TYPE;
- typedef struct STORE
- unsigned char dat[100];
- } BUFFER_TYPE; //256 bytes, 128 words
- BUFFER_TYPE sectorBuffer; //512 bytes for sector buffer
- unsigned int readPos=0;
- unsigned char sectorPos=0;
- unsigned char LBA_Opened=0; //Set to 1 when a sector is opened.
- unsigned char Init_Flag; //Set it to 1 when Init is processing.
- void delay(unsigned int time)
- while(time--);
- // Port Init
- void MMC_Port_Init()
- SPI_SCL=1;
- SPI_DO =1;
- SPI_CS=1;
- send_s("Port Init!");
- //Config ports
- SPI_DI=1; //Set Pin MMC_DI as Input
- SPI_SCL=1; //Set Pin MMC_Clock as Output
- SPI_DO=1; //Set Pin MMC_DO as Output
- SPI_CS=1; //Set MMC_Chip_Select to High,MMC/SD Invalid.
- //busy led port init
- //SPI_BY=1; //Set spi busy led port output
- //MMC_BUSY_LED=1; //busy led off
- //Routine for sending a byte to MMC/SD-Card
- void Write_Byte_MMC(unsigned char value)
- unsigned char i;
- //Software SPI
- for (i=0;i<8;i++)
- { //write a byte
- if (((value>>(7-i))&0x01)==0x01)
- SPI_DI=1; //Send bit by bit(MSB First)
- else SPI_DI=0;
- SPI_SCL=0; //set Clock Impuls low
- if(Init_Flag)
- delay(9);
- SPI_SCL=1; //set Clock Impuls High
- if(Init_Flag)
- delay(9);
- }//write a byte
- //MMC_BUSY_LED=1;
- //Routine for reading a byte from MMC/SD-Card
- unsigned char Read_Byte_MMC()
- unsigned char temp=0;
- unsigned char i;
- //Software SPI
- for (i=0;i<8;i++) //MSB First
- SPI_DO=1;
- SPI_SCL=0; //Clock Impuls (Low)
- if(Init_Flag)
- delay(9);
- temp=(temp<<1)+(unsigned char)SPI_DO; //read mmc data out pin
- if(Init_Flag)
- delay(9);
- return (temp);
- //Send a Command to MMC/SD-Card
- //Return: the second byte of response register of MMC/SD-Card
- unsigned char Write_Command_MMC(unsigned char *CMD)
- unsigned char tmp;
- unsigned char retry=0;
- unsigned char i;
- //set MMC_Chip_Select to high (MMC/SD-Card disable)
- SPI_CS=1;
- //send 8 Clock Impulse
- Write_Byte_MMC(0xFF);
- //set MMC_Chip_Select to low (MMC/SD-Card active)
- SPI_CS=0;
- //send 6 Byte Command to MMC/SD-Card
- for (i=0;i<0x06;i++)
- Write_Byte_MMC(*CMD++);
- //get 16 bit response
- Read_Byte_MMC(); //read the first byte,ignore it.
- do
- { //Only last 8 bit is used here.Read it out.
- tmp = Read_Byte_MMC();
- retry++;
- while((tmp==0xff)&&(retry<100));
- return(tmp);
- //Routine for Init MMC/SD card(SPI-MODE)
- unsigned char MMC_Init()
- unsigned char retry,temp;
- unsigned char i;
- unsigned char CMD[] = {0x40,0x00,0x00,0x00,0x00,0x95};
- send_s("SD CARD Init!");
- MMC_Port_Init(); //Init SPI port
- delay(200);
- Init_Flag=1; //Set the init flag
- for (i=0;i<0x0f;i++)
- Write_Byte_MMC(0xff); //send 74 clock at least!!!
- //Send Command CMD0 to MMC/SD Card
- send_s("Send Command CMD0 to MMC/SD Card");
- retry=0;
- do
- { //retry 200 times to send CMD0 command
- temp=Write_Command_MMC(CMD);
- retry++;
- if(retry==200)
- { //time out
- return(INIT_CMD0_ERROR);//CMD0 Error!
- while(temp!=1);
- //Send Command CMD1 to MMC/SD-Card
- send_s("Send Command CMD1 to MMC/SD-Card");
- CMD[0] = 0x41; //Command 1
- CMD[5] = 0xFF;
- retry=0;
- do
- { //retry 100 times to send CMD1 command
- retry++;
- if(retry==100)
- { //time out
- return(INIT_CMD1_ERROR);//CMD1 Error!
- while(temp!=0);
- Init_Flag=0; //Init is completed,clear the flag
- SPI_CS=1; //set MMC_Chip_Select to high
- send_s("SD CARD Init Suc!!");
- return(0x55); //All commands have been taken.
- //Routine for reading data Registers of MMC/SD-Card
- //Return 0 if no Error.
- unsigned char MMC_Read_Block(unsigned char *CMD,unsigned char *Buffer,unsigned int Bytes)
- unsigned int i;
- unsigned retry,temp;
- //Send Command CMD to MMC/SD-Card
- retry=0;
- do
- { //Retry 100 times to send command.
- retry++;
- if(retry==100)
- return(READ_BLOCK_ERROR); //block write Error!
- while(temp!=0);
- //Read Start Byte form MMC/SD-Card (FEh/Start Byte)
- while (Read_Byte_MMC()!=0xfe);
- //Write blocks(normal 512Bytes) to MMC/SD-Card
- for (i=0;i<Bytes;i++)
- *Buffer++ = Read_Byte_MMC();
- //CRC-Byte
- Read_Byte_MMC();//CRC - Byte
- //set MMC_Chip_Select to high (MMC/SD-Card invalid)
- SPI_CS=1;
- return(0);
- //Routine for reading CSD Registers from MMC/SD-Card (16Bytes)
- unsigned char Read_CSD_MMC(unsigned char *Buffer)
- //Command for reading CSD Registers
- unsigned char CMD[] = {0x49,0x00,0x00,0x00,0x00,0xFF};
- unsigned char temp;
- temp=MMC_Read_Block(CMD,Buffer,16); //read 16 bytes
- return(temp);
- //Routine for reading CID Registers from MMC/SD-Card (16Bytes)
- unsigned char Read_CID_MMC(unsigned char *Buffer)
- //Command for reading CID Registers
- unsigned char CMD[] = {0x4A,0x00,0x00,0x00,0x00,0xFF};
- return(temp);
- //returns the :
- // size of the card in MB ( ret * 1024^2) == bytes
- // sector count and multiplier MB are in u08 == C_SIZE / (2^(9-C_SIZE_MULT))
- // name of the media
- void MMC_get_volume_info(void)
- { unsigned char i;
- unsigned char c_temp[5];
- VOLUME_INFO_TYPE MMC_volume_Info,*vinf;
- send_s("SD CARD Information Read!!");
- vinf=&MMC_volume_Info; //Init the pointoer;
- // read the CSD register
- Read_CSD_MMC(sectorBuffer.dat);
- // get the C_SIZE value. bits [73:62] of data
- // [73:72] == sectorBuffer.data[6] && 0x03
- // [71:64] == sectorBuffer.data[7]
- // [63:62] == sectorBuffer.data[8] && 0xc0
- vinf->sector_count = sectorBuffer.dat[6] & 0x03;
- vinf->sector_count <<= 8;
- vinf->sector_count += sectorBuffer.dat[7];
- vinf->sector_count <<= 2;
- vinf->sector_count += (sectorBuffer.dat[8] & 0xc0) >> 6;
- // get the val for C_SIZE_MULT. bits [49:47] of sectorBuffer.data
- // [49:48] == sectorBuffer.data[5] && 0x03
- // [47] == sectorBuffer.data[4] && 0x80
- vinf->sector_multiply = sectorBuffer.dat[9] & 0x03;
- vinf->sector_multiply <<= 1;
- vinf->sector_multiply += (sectorBuffer.dat[10] & 0x80) >> 7;
- // work out the MBs
- // mega bytes in u08 == C_SIZE / (2^(9-C_SIZE_MULT))
- vinf->size_MB = vinf->sector_count >> (9-vinf->sector_multiply);
- // get the name of the card
- Read_CID_MMC(sectorBuffer.dat);
- vinf->name[0] = sectorBuffer.dat[3];
- vinf->name[1] = sectorBuffer.dat[4];
- vinf->name[2] = sectorBuffer.dat[5];
- vinf->name[3] = sectorBuffer.dat[6];
- vinf->name[4] = sectorBuffer.dat[7];
- vinf->name[5] = 0x00; //end flag
- while(1)
- P1=~(unsigned char)((vinf->size_MB)>>8);
- delay(50000);
- delay(50000);
- delay(50000);
- delay(50000);
- delay(50000);
- P1=~(unsigned char)((vinf->size_MB));
- delay(50000);
- delay(50000);
- delay(50000);
- delay(50000);
- delay(50000);
- //LCDclrscr();
- //Print Product name on lcd
- i=0;
- send_s("Product Name:");
- //while((vinf->name[i]!=0x00)&&(i<16)) send(vinf->name[i++]);
- send_s(vinf->name);
- //Print Card Size(eg:128MB)
- //gotoxy(1,0);
- send_s("Tot:");
- send_s(ftoa(vinf->size_MB,c_temp,0));
- send_s("MB ");
- //gotoxy(2,0);
- //writestring("sector_mult:"); writeNumber(vinf->sector_multiply);
- //gotoxy(3,0);
SD卡模块.rar
(277.79 KB, 下载次数: 52)
