查看: 17307|回复: 0
HT7133引脚图与pdf规格书资料下载
ht7133规格书:
General Description
The HT71XX-1 series is a set of three-terminal low
power high voltage regulators implemented in CMOS
technology. They allow input voltages as high as 24V.
They are available with several fixed output voltages
ranging from 3.0V to 5.0V. CMOS technology ensures
low voltage drop and low quiescent current.
HT7133引脚图
HT7133 Block Diagram
完整的pdf格式文档51黑下载地址:
ht7133-1sot-89东品.pdf (146.83 KB, 下载次数: 34)
