查看: 15473|回复: 11
arduino ps2遥控小车基于无线模块
基于无线模块的遥控控制小车
手柄按键
发送字符
接收十六进制代码
小车动作
按键上或左摇杆上
a
0x61
前进
按键下或左摇杆下
b
0x62
后退
按键左或左摇杆左
c
0x63
左转
按键右或左摇杆右
d
0x64
右转
红圆圈
e
0x65
左原地转圈
粉方块
f
0x66
右原地转圈
绿三角
g
0x67
划弧度
1或右1
h
0x68
左平移
2或右2
i
0x69
右平移
右摇杆上
g
0x6a
45度左前
右摇杆下
k
0x6b
45度右后
右摇杆左
l
0x6c
45度右前
右摇杆右
m
0x6d
45度左后
标志位
n
0x6e
停止
arduino源程序如下:
  1. #include <PS2X_lib.h>  //for v1.6
  2. PS2X ps2x; // create PS2 Controller Class
  3. //right now, the library does NOT support hot pluggable controllers, meaning
  4. //you must always either restart your Arduino after you conect the controller,
  5. //or call config_gamepad(pins) again after connecting the controller.
  6. //不支持热插拔,连线后需要重新启动Arduino板
  7. int PS_LX;//PS2手柄左摇杆X轴数据
  8. int PS_LY;//PS2手柄左摇杆Y轴数据
  9. int PS_RX;//PS2手柄右摇杆X轴数据
  10. int PS_RY;//PS2手柄右摇杆Y轴数据
  11. int error = 0;         //连接正确与否的判断标志
  12. byte type = 0;         //ps2x.readType()转换判别标志
  13. byte vibrate = 0;
  14. int banduan=0;
  15. void setup(){
  16. Serial.begin(57600);
  17. //CHANGES for v1.6 HERE!!! **************PAY ATTENTION*************
  18. error = ps2x.config_gamepad(13,11,10,12, true, true);   //setup pins and settings:  GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
  19.                                                          //检查引脚是否有连接错误
  20.
  21. if(error == 0){
  22.    Serial.println("Found Controller, configured successful");
  23.    Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
  24.   Serial.println("holding L1 or R1 will print out the analog stick values.");
  25.   Serial.println("Go to [url]www*billporter*info[/url] for updates and to report bugs.");
  26. }  //0号错误的串口提示信息
  27.   else if(error == 1)
  28.    Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit [url]www*billporter*info[/url] for troubleshooting tips");
  29.                   //1号错误的串口提示信息
  30.   else if(error == 2)
  31.    Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit [url]www*billporter*info[/url] for troubleshooting tips");
  32.                  //2号错误的串口提示信息
  33.   else if(error == 3)
  34.    Serial.println("Controller refusing to enter Pressures mode, may not support it. ");
  35.                  //3号错误的串口提示信息
  36.    //Serial.print(ps2x.Analog(1), HEX);
  37.    type = ps2x.readType();    //正确连接后串口提示的信息
  38.      switch(type) {
  39.        case 0:
  40.         Serial.println("Unknown Controller type");
  41.        break;
  42.        case 1:
  43.         Serial.println("DualShock Controller Found");
  44.        break;
  45.        case 2:
  46.          Serial.println("GuitarHero Controller Found");
  47.        break;
  48.      }
  49. }
  50. void loop(){
  51.    /* You must Read Gamepad to get new values
  52.    Read GamePad and set vibration values
  53.    ps2x.read_gamepad(small motor on/off, larger motor strenght from 0-255)
  54.    if you don't enable the rumble, use ps2x.read_gamepad(); with no values
  55.
  56.    you should call this at least once a second
  57.    */
  58. //用Read Gamepad函数读取按键值
  59. if(error == 1) //skip loop if no controller found
  60.   return;
  61.
  62.
  63.
  64.   /******************************************************
  65.    Guitar Hero Controller不是手柄选用的控制器
  66.   //Guitar Hero Controller
  67. if(type == 2)
  68. {
  69.   ps2x.read_gamepad();          //read controller
  70.    if(ps2x.ButtonPressed(GREEN_FRET))
  71.      Serial.println("Green Fret Pressed");
  72.    if(ps2x.ButtonPressed(RED_FRET))
  73.      Serial.println("Red Fret Pressed");
  74.    if(ps2x.ButtonPressed(YELLOW_FRET))
  75.      Serial.println("Yellow Fret Pressed");
  76.    if(ps2x.ButtonPressed(BLUE_FRET))
  77.      Serial.println("Blue Fret Pressed");
  78.    if(ps2x.ButtonPressed(ORANGE_FRET))
  79.      Serial.println("Orange Fret Pressed");
  80.     if(ps2x.ButtonPressed(STAR_POWER))
  81.      Serial.println("Star Power Command");
  82.     if(ps2x.Button(UP_STRUM))          //will be TRUE as long as button is pressed
  83.      Serial.println("Up Strum");
  84.     if(ps2x.Button(DOWN_STRUM))
  85.      Serial.println("DOWN Strum");
  86.     if(ps2x.Button(PSB_START))                            //will be TRUE as long as button is pressed
  87.          Serial.println("Start is being held");
  88.     if(ps2x.Button(PSB_SELECT))
  89.          Serial.println("Select is being held");
  90.     if(ps2x.Button(ORANGE_FRET)) // print stick value IF TRUE
  91.     {
  92.         Serial.print("Wammy Bar Position:");
  93.         Serial.println(ps2x.Analog(WHAMMY_BAR), DEC);
  94.     }
  95. }
  96. **********************************************************************/
  97. else { //DualShock Controller手柄选用的控制器
  98.     ps2x.read_gamepad(false, vibrate);          //read controller and set large motor to spin at 'vibrate' speed
  99.
  100.     if(ps2x.Button(PSB_START))                      //start选中 //will be TRUE as long as button is pressed
  101.       Serial.println("Start is being held");
  102.     if(ps2x.Button(PSB_SELECT))                     //select选中
  103.       Serial.println("Select is being held");
  104.     PS_LX=ps2x.Analog(PSS_LX);           //把PS2手柄左摇杆X轴数据读到变量PS_LX
  105.    PS_RX=ps2x.Analog(PSS_RX);           //把PS2手柄右摇杆X轴数据读到变量PS_RX
  106.    PS_LY=ps2x.Analog(PSS_LY);           //把PS2手柄左摇杆Y轴数据读到变量PS_LY
  107.    PS_RY=ps2x.Analog(PSS_RY);           //把PS2手柄右摇杆Y轴数据读到变量PS_RY
  108.   if(PS_RX<5)                  //从左到右0~255,从上到下0~255
  109.   { banduan=1;
  110.         Serial.print("l");
  111.       }
  112.    if(PS_RX>250)
  113.    { banduan=1;
  114.         Serial.print("m");
  115.       }
  116.     if(PS_RY<5)
  117.   { banduan=1;
  118.         Serial.print("j");
  119.       }
  120.       if(PS_RY>250)
  121.   { banduan=1;
  122.         Serial.print("k");
  123.       }
  124.     if(PS_LY<5||ps2x.Button(PSB_PAD_UP)) //上                   //will be TRUE as long as button is pressed
  125.     {  banduan=1;
  126.        Serial.print("a");
  127.      }
  128.
  129.      if(PS_LY>250||ps2x.Button(PSB_PAD_DOWN))//下
  130.       { banduan=1;
  131.        Serial.print("b");
  132.       }
  133.
  134.          if(PS_LX<5||ps2x.Button(PSB_PAD_LEFT))//左
  135.       { banduan=1;
  136.       Serial.print("c");
  137.       }
  138.
  139.      if(PS_LX>250||ps2x.Button(PSB_PAD_RIGHT))//右
  140.      { banduan=1;
  141.         Serial.print("d");
  142.       }
  143.
  144.
  145.      if(ps2x.Button(PSB_RED))               //红圆圈
  146.          { banduan=1;
  147.         Serial.print("e");
  148.       }
  149.     if(ps2x.Button(PSB_PINK))             //粉方形
  150.        { banduan=1;
  151.         Serial.print("f");
  152.       }
  153.
  154.
  155.
  156.
  157.       vibrate = ps2x.Analog(PSAB_BLUE);        //this will set the large motor vibrate speed based on how hard you press the blue (X) button
  158.      if(ps2x.NewButtonState(PSB_BLUE))        //蓝叉叉
  159.         Serial.print("XX");
  160.     if (ps2x.Button(PSB_GREEN))              //绿三角   //will be TRUE if any button changes state (on to off, or off to on)
  161.      { banduan=1;
  162.         Serial.print("g");
  163.       }
  164.
  165.     if(ps2x.Button(PSB_L1) || ps2x.Button(PSB_R1)) //左1右1// print stick values if either is TRUE
  166.      { banduan=1;
  167.         Serial.print("h");
  168.       }
  169.    if(ps2x.Button(PSB_L2) || ps2x.Button(PSB_R2)) //左2右2// print stick values if either is TRUE
  170.      { banduan=1;
  171.         Serial.print("i");
  172.       }
  173.   if( banduan==0)
  174.       Serial.print("n");
  175.      else
  176.          banduan=0;
  177.
  178. }
  179. delay(50);
  180. }
遥控小车.rar (12.07 MB, 下载次数: 155)
收藏收藏5 分享淘帖 顶 踩
ID:18156 发表于 2018-9-9 16:29 | 只看该作者
看轮子应该是可以横向运动的。
ID:32574 发表于 2018-10-17 14:13 | 只看该作者
楼主厉害,轮子是叫什么名字?
ID:79544 发表于 2018-10-19 08:25 | 只看该作者
楼主  接收是用的什么模块?
ID:390585 发表于 2018-11-8 19:06 | 只看该作者
redtxd 发表于 2018-10-17 14:13
楼主厉害,轮子是叫什么名字?
麦克纳姆轮
ID:460190 发表于 2019-2-15 21:00 | 只看该作者
感谢分享
ID:448145 发表于 2019-11-7 12:22 | 只看该作者
感谢分享
ID:676603 发表于 2019-12-29 15:03 | 只看该作者
很棒,一会研究源码
ID:646222 发表于 2020-2-5 19:14 | 只看该作者
感谢分享
ID:652804 发表于 2020-2-25 21:37 | 只看该作者
感谢分享
ID:643484 发表于 2020-3-3 15:07 | 只看该作者
感谢分享
ID:171746 发表于 2021-1-26 16:57 | 只看该作者
有ARDUINO 小车程序吗?     哪个是51单片机的
