查看: 4626|回复: 0
温度传感器MLX90164引脚图与数据手册下载
一个很高端的温度传感器
MLX90164引脚图:
数据手册:
2 General Description
The  MLX90614  is  an  Infra  Red  thermometer  for  non
contact  temperature measurements.   Both  the  IR sensitive
thermopile detector chip and  the signal conditioning ASSP
are integrated in the same TO-39 can.
Thanks  to  its  low  noise  amplifier,  17-bit  ADC  and
powerful DSP  unit,  a  high  accuracy  and  resolution  of  the
thermometer is achieved.
The  thermometer comes  factory calibrated with a digital
PWM and SMBus (System Management Bus) output.
As  a  standard,  the  10-bit  PWM  is  configured  to
continuously  transmit  the measured  temperature  in  range
of -20…120˚C, with an output resolution of 0.14˚C.
The factory default POR setting is SMBus.
Features and Benefits
  Small size, low cost
  Easy to integrate
  Factory calibrated in wide temperature range:
  -40…+125˚C for sensor temperature and
  -70…+380˚C for object temperature.
  High accuracy of 0.5° C over wide temperature
range (0…+50° C for both Ta and To)
  High (medical) accuracy calibration
  Measurement resolution of 0.02° C
  Single and dual zone versions
  SMBus compatible digital interface
  Customizable PWM output for continuous
reading
  Available in 3V and 5V versions
  Simple adaptation for 8…16V applications
  Sleep mode for reduced power consumption
  Different package options for applications and
measurements versatility
  Automotive grade
完整的pdf格式文档51黑下载地址:
MLX90614.pdf (4.57 MB, 下载次数: 12)
