压缩包内含源程序与仿真图
- #include <reg51.h>
- #include "intrins.h"
- #define SEG P1
- void Delay1ms(unsigned int N);
- unsigned char code DIG_CODE[10]={0xC0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//共阳极
- void SendChar(unsigned char c);
- void SendString(unsigned char *s);
- unsigned char Num;
- unsigned char Sec,Secs,Secg; //Secg代表个位,Secs代表十位,下面Min、Hour同上
- unsigned char Min=14,Mins,Ming;
- unsigned char Hour=8,Hours,Hourg;
- unsigned char RcvStr[2];
- unsigned int NumRcv=0;
- bit FlagRcv=0;
- unsigned char Str[]="学号:160805101";
- void main( ) /*主程序*/
- //初始化
- TMOD=0x21;
- TH1=0xf3;//2400bps
- TL1=0xf3;
- TR1=1;
- SCON=0x50;//方式1允许接收
- IE=0x92;//EA=1 ES=1
- IP=0x10;//PS=1
- TH0=(65536-50000)/256;//定时50ms
- TL0=(65536-50000)%256;//定时50ms
- TR0=1;
- ET0=1;
- while (1)
- if(FlagRcv==1)
- FlagRcv=0;
- if(RcvStr[0]=='S' && (RcvStr[1]=='J'))
- SendChar(Hours+0x30);
- SendChar(Hourg+0x30);
- SendChar(':');
- SendChar(Mins+0x30);
- SendChar(Ming+0x30);
- SendChar(':');
- SendChar(Secs+0x30);
- SendChar(Secg+0x30);
- SendString(Str);
- SendChar(0x0D);//发送回车
- SendChar(0x0A);//发送换行
- Delay1ms(1000);
- else
- SendString("ERR");
- void ISRUSART() interrupt 4
- if(RI==1)
- RcvStr[NumRcv]=SBUF;
- NumRcv++;
- RI=0;
- if(NumRcv==2)
- NumRcv=0;
- FlagRcv=1;
- void ISRTimer0() interrupt 1
- Num++;
- if(Num==20)
- Sec++;
- Num=0;
- Secs=Sec/10;
- Secg=Sec%10;
- if(Sec==60)
- Sec=0;
- Secs=Sec/10;
- Secg=Sec%10;
- Min++;
- Mins=Min/10;
- Ming=Min%10;
- if(Min==17)
- Min=0;
- Mins=Min/10;
- Ming=Min%10;
- Hour++;
- Hours=Hour/10;
- Hourg=Hour%10;
- if(Hour==24)
- Hour=0;
- SBUF=c;
- while(TI==0);
- TI=0;
- while(*s!='\0')
- SendChar(*s);
- s++;
- void Delay1ms(unsigned int N) //@12.000MHz
- unsigned char i, j;
- while(N--)
- i = 2;
- j = 239;
- do
- while (--j);
- } while (--i);
实验9 串行通信实验.zip
(123.85 KB, 下载次数: 51)
