查看: 7484|回复: 1
数码管学号滚动显示的单片机程序
源程序
#include <REG51.H>
#define uint unsigned int
uchar code DIS_SEG7[]={0xf9,0x92,0xb0,0xf9,0xc0,0xa4,0xf9,0xb0};//设置学号,共阳字形码
uchar code DIS_BIT[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};// 8位数码管位选
sbit k1=P1^0;
sbit k2=P1^1;
void delay1ms(uint i)
  uint j;
  while(i--)
     for(j=0;j<110;j++);
void main(void)
   uchar cnt,ttt;
   uchar DISP[]={0,1,2,3,4,5,6,7};
       for(ttt=0;ttt<100;ttt++)
    for(cnt=0;cnt<8;cnt++)
    {//点亮数码馆0-7
        P2=0;
     P0=DIS_SEG7[DISP[cnt]];
     P2=~DIS_BIT[cnt];
     if(k1==1&&k2==1)
         delay1ms(1);
      else {
       if(k1==0&&k2==1)
                delay1ms(2);
       else{
           if(k1==1&&k2==0)
                      delay1ms(3);
       else{
                           if(k1==0&&k2==0)
                           delay1ms(4);
ttt=DISP[0];
DISP[0]=DISP[1];
DISP[1]=DISP[2];
DISP[2]=DISP[3];
DISP[3]=DISP[4];
DISP[4]=DISP[5];
  DISP[5]=DISP[6];
   DISP[6]=DISP[7];
DISP[7]=ttt;
ID:738664 发表于 2020-4-26 16:54 | 只看该作者
if(k1==1&&k2==1)
         delay1ms(1);
      else {
       if(k1==0&&k2==1)
                delay1ms(2);
       else{
           if(k1==1&&k2==0)
                      delay1ms(3);
       else{
                           if(k1==0&&k2==0)
                           delay1ms(4);
这个有什么用啊
