这是dsp DM642芯片用定时器点亮LED灯的程序
- // TI File $Revision: /main/1 $
- // Checkin $Date: September 21, 2007 08:58:44 $
- // FILE: Example_2833xLedBlink.c
- // TITLE: DSP2833x eZdsp LED Blink Getting Started Program.
- // ASSUMPTIONS:
- // This program requires the DSP2833x header files.
- // As supplied, this project is configured for "boot to SARAM"
- // operation. The 2833x Boot Mode table is shown below.
- // For information on configuring the boot mode of an eZdsp,
- // please refer to the documentation included with the eZdsp,
- // $Boot_Table:
- // GPIO87 GPIO86 GPIO85 GPIO84
- // XA15 XA14 XA13 XA12
- // PU PU PU PU
- // 1 1 1 1 Jump to Flash
- // 1 1 1 0 SCI-A boot
- // 1 1 0 1 SPI-A boot
- // 1 1 0 0 I2C-A boot
- // 1 0 1 1 eCAN-A boot
- // 1 0 1 0 McBSP-A boot
- // 1 0 0 1 Jump to XINTF x16
- // 1 0 0 0 Jump to XINTF x32
- // 0 1 1 1 Jump to OTP
- // 0 1 1 0 Parallel GPIO I/O boot
- // 0 1 0 1 Parallel XINTF boot
- // 0 1 0 0 Jump to SARAM <- "boot to SARAM"
- // 0 0 1 1 Branch to check boot mode
- // 0 0 1 0 Boot to flash, bypass ADC cal
- // 0 0 0 1 Boot to SARAM, bypass ADC cal
- // 0 0 0 0 Boot to SCI-A, bypass ADC cal
- // Boot_Table_End$
- // DESCRIPTION:
- // This example configures CPU Timer0 for a 500 msec period, and toggles the GPIO32
- // LED on the 2833x eZdsp once per interrupt. For testing purposes, this example
- // also increments a counter each time the timer asserts an interrupt.
- // Watch Variables:
- // CpuTimer0.InterruptCount
- // Monitor the GPIO32 LED blink on (for 500 msec) and off (for 500 msec) on the 2833x eZdsp.
- // $TI Release: DSP2833x Header Files V1.10 $
- // $Release Date: February 15, 2008 $
- #include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
- #include "DSP2833x_Examples.h" // DSP2833x Examples Include File
- // Prototype statements for functions found within this file.
- interrupt void cpu_timer0_isr(void);
- unsigned int Count,Flag;
- void main(void)
- // Step 1. Initialize System Control:
- // PLL, WatchDog, enable Peripheral Clocks
- // This example function is found in the DSP2833x_SysCtrl.c file.
- InitSysCtrl();
- // Step 2. Initalize GPIO:
- // This example function is found in the DSP2833x_Gpio.c file and
- // illustrates how to set the GPIO to it's default state.
- // InitGpio(); // Skipped for this example
- // Step 3. Clear all interrupts and initialize PIE vector table:
- // Disable CPU interrupts
- DINT;
- // Initialize the PIE control registers to their default state.
- // The default state is all PIE interrupts disabled and flags
- // are cleared.
- // This function is found in the DSP2833x_PieCtrl.c file.
- InitPieCtrl();
- // Disable CPU interrupts and clear all CPU interrupt flags:
- IER = 0x0000;
- IFR = 0x0000;
- // Initialize the PIE vector table with pointers to the shell Interrupt
- // Service Routines (ISR).
- // This will populate the entire table, even if the interrupt
- // is not used in this example. This is useful for debug purposes.
- // The shell ISR routines are found in DSP2833x_DefaultIsr.c.
- // This function is found in DSP2833x_PieVect.c.
- InitPieVectTable();
- // Interrupts that are used in this example are re-mapped to
- // ISR functions found within this file.
- EALLOW; // This is needed to write to EALLOW protected registers
- PieVectTable.TINT0 = &cpu_timer0_isr;
- Count = 0; //初始化变量
- Flag=0;
- EDIS; // This is needed to disable write to EALLOW protected registers
- // Step 4. Initialize the Device Peripheral. This function can be
- // found in DSP2833x_CpuTimers.c
- InitCpuTimers(); // For this example, only initialize the Cpu Timers
- #if (CPU_FRQ_150MHZ)
- // Configure CPU-Timer 0 to interrupt every 500 milliseconds:
- // 150MHz CPU Freq, 50 millisecond Period (in uSeconds)
- ConfigCpuTimer(&CpuTimer0, 150, 500000);
- #endif
- #if (CPU_FRQ_100MHZ)
- // 100MHz CPU Freq, 50 millisecond Period (in uSeconds)
- ConfigCpuTimer(&CpuTimer0, 100, 500000);
- #endif
- // To ensure precise timing, use write-only instructions to write to the entire register. Therefore, if any
- // of the configuration bits are changed in ConfigCpuTimer and InitCpuTimers (in DSP2833x_CpuTimers.h), the
- // below settings must also be updated.
- CpuTimer0Regs.TCR.all = 0x4001; // Use write-only instruction to set TSS bit = 0
- // Step 5. User specific code, enable interrupts:
- // Configure GPIO0-3 as a GPIO output pin
- EALLOW;
- GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO0 = 1;
- GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO1 = 1;
- GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO2 = 1;
- GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO3 = 1;
- EDIS;
- // Enable CPU INT1 which is connected to CPU-Timer 0:
- IER |= M_INT1;
- // Enable TINT0 in the PIE: Group 1 interrupt 7
- PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
- // Enable global Interrupts and higher priority real-time debug events:
- EINT; // Enable Global interrupt INTM
- ERTM; // Enable Global realtime interrupt DBGM
- // Step 6. IDLE loop. Just sit and loop forever (optional):
- for(;;);
- CpuTimer0.InterruptCount++;
- GpioDataRegs.GPATOGGLE.bit.GPIO0 = 1; // Toggle GPIO0 once per 500 milliseconds
- GpioDataRegs.GPATOGGLE.bit.GPIO1 = 1; // Toggle GPIO1 once per 500 milliseconds
- GpioDataRegs.GPATOGGLE.bit.GPIO2 = 1; // Toggle GPIO2 once per 500 milliseconds
- GpioDataRegs.GPATOGGLE.bit.GPIO3 = 1; // Toggle GPIO3 once per 500 milliseconds
- // Acknowledge this interrupt to receive more interrupts from group 1
- PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
- // No more.
Ex01_ZQ28335_Timer0_LED.rar
(387.17 KB, 下载次数: 4)
